12-27-2011, 08:32 AM
#166 | |
Oddometer: 3,441
Has BMW acknowledged the problem? I'm sure average riding speed & temperature has a lot to do with it, also if bash plate shields air flow ... and so on... Perhaps German riders as a group are riding faster in cooler weather, while US riders are riding slower and in hotter weather? |
12-27-2011, 10:44 AM
#167 |
Oddometer: 118
Are the only bikes that are having the stator failures have the bash plate installed?
12-27-2011, 11:18 AM
#168 |
I want to ride
Oddometer: 1,764
Please don't let the bash plate be the cause, then mother ship will tell us in order to fix the problem you must take off the bash plate.
2010 F800GS Stone Road Touring bike! |
12-27-2011, 11:24 AM
#169 | ||||||
Oddometer: 1,353
I wouldn't think exhaust temp is going up over time, but thats an interesting possibility. The F8, as apposed to the F650 DOES have air injection. Air is injected straight into the exhaust to allow the catalyst to do a better job, if for any reason there is more fuel in the exhaust, the bike is running richer or injectors are shooting a poorer pattern, after burning will occur and the exhaust will get considerably hotter. Magnets don't get stronger with age, ever. That would be contrary to laws of the universe. But as to the rest, you seem to be thinking along the lines that the stator has to get hotter to fail. As described above, it doesn't. It ages over time and heat greatly influences the rate, then when the insulation finally breaks down too much, it shorts and turns into a mega burnt thing all at once rapidly. Thats why the picture shortly above is of great interest to me. Every failed stator I have seen has been a piece of slag thats not informative. The stator above was removed before it finished burning to death. Quote:
It is difficult to imagine BMW getting the math wrong as the above principals have been in use well before BMW came into existence, but the failure rate would imply that at the leads, our stators are set up on the raggedy edge. What I find more likely is that the stator insulation or rotor magnets, or centering of the stator are NOT to design specifications. Or the housing is getting hotter then expected, oil isn't cooling as expected and this COULD change over time, or something in the oil is reacting to age stator insulation more then expected. Quote:
The copper does not age as long as the insulation remains intact. As iterated above, the insulation on all stators DOES age. Quote:
Poor insulation would certainly speed this up. Contamination in the oil or a bad batch of stator insulation would certainly be possible. Vibration will cause stator failure ONLY if the stator was not dipped correctly. Tho whole stator is normally dipped in varnish, epoxy, or glass to prevent this type of failure. Every stator I have seen has been too far gone to learn anything meaningful from. There is also one more cause of failure that is not unheard of which is a 3rd harmonic induced failure. Essentially switching loads or noisy loads such as arc loads can induce a resonance of the 3rd harmonic and overheat the Y connection of the stator or add on delta legs. Its hard for me to imagine why a battery wouldn't buffer this or how it would get through the rectifier, but it's not my primary field of study and I may not know something. There have been semi credible reports of HID lighting causing stator failures and for that matter the fuel pump control module is a switching controller that could be implicated in this kind of failure but I'm out of my area of expertise in how these things would affect a stator behind a rectifier. Also peak voltages will cause stator aging through something called "partial discharges". This is why I don't know if a series regulator is a good idea or not. Heat and PD will compete for causing the failure. An EE would need to answer this question and need a laboratory to do it as it could go either way. The stator may be aged very little by peak voltages or very fast. Depends on how well these stators are insulated from such and I have no idea. There, a whole lot of typing with absolutely no definitive answers lol, but perhaps interesting reading?
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250 I love and miss you Jeneca and I'm sorry. |
12-27-2011, 12:06 PM
#170 | ||
Oddometer: 470
Nope, at least I can not prove it and I have nothing heard from BMW so far. But I think it is legal to assume that they know about it. It seems sure that they know how many alternator warranty requests they have and we all know there are many. The big works always know what's going on and BMW claims to have very good service and customer relationship, at least over here in Europe.
I think to isolate the problem its necessary to have some kind of matrix telling exact mileage when the stator failed, under which circumstances were the bikes mainly ridden (lots of low speed off road, highway use, commuting etc), what oil has be used, bash plates yes/know, additional electrical devices (lights, heated clothing, etc.)... Not easy to find out.... |
12-27-2011, 12:12 PM
#171 | |
Oddometer: 1,353
It is a problem they are aware of but just one of 5000 they are looking into. I know its no consolation, but if you worked in the industry, you would have a different perspective. Based on my past experiences, the morning conversation between an FSE and technical boss could go something like this: Anything new FSE1? Yeah, I finally got through to the service manager at BMW X and had a talk about x's bike. They have no idea what they are doing, were gonna end up lemoning that. With franchises like this, who needs competition. What about the engine failures on the k16's anything further on that? Yeah, the guy in Florida died today but were no closer to why that engines exploding. Shit, nothing form germany yet? Who's the point guy there working this? xxx is but nothing new. Ok, He's good, hopefully we get something soon. We need to involve risk and get them up to speed and start start a conversation with NHTSA so were ready once we know whats going on. I want everybody ready to move on this one. Will do boss. FSE2, hows your area? It's going, I'm going to have to visit one of my dealers thats warranted about 100 ESA's in the past year. get warranty involved, have them draft up something friendly and scary on letterhead and mark it for principal only, then maybe that farmer cum service manager will listen Anything else? Read on a forum this morning that stators are failing early on the k7's. Oh my goodness, not a forum! What shall we do?? (general laughs around the room) Yeah yeah, we are starting to see an up tic, I know, warranty says were up to 12% in warranty. I forwarded it to Germany 6 months ago. Any thoughts to why they are failing when they are? Yeah, they suck, perhaps our german colleagues shouldn't have sourced a stator from an old yamaha a and figured it would bolt straight in. now now, they do hold the purse strings and remember, they build superior motorcycles (general laughs) I can't remember the name, but someone's working it there FSE3 speaks up "I got one in Cali that didn't burn all the way, want me to have him post it here? Nah, were spread too thin, I need you to get me answers on the K16 engine and work with x on homulgation of our new scooter. EPA hates anything fuel efficient that GM didn't make and there giving us grief any other bodies I need to know about?...... Above is totally fictitious, but every part of it I have heard while with one manufacture or another. We think about things in a vacuum on this forum. I know the USA guys are working a dozen problems that make the Stator look like nothing and Germany is working thousands. BMW USA has 4 field service engineers that report to one technical boss. Germany has less then a dozen engineers that are on motorcycles full time and have less then 10% of their time devoted to in warranty failures unless there are bodies attached. In any case, they are probable contractually tied to this stator. God forbid it's not the stator. If for instance its heat from the exhaust. Well adding a heat shield will change emissions and likely increase NOX emissions an infinitesimal amount. Even an infinitesimal amount triggers a new round of emissions proving and homulgation which always costs 10's or hundreds of thousands. As for disclosing the problem. Throughout time it has been proven that nothing good comes from disclosure till a working fix ix in place. Look at apple. The worlds largest electronics manufacture has built it's company on the bedrock of NEVER admitting a problem till it's fixed. Frustrating to the knowledgeable user, but it's the way the world works.
12-27-2011, 12:46 PM
#172 |
Oddometer: 470
@Joel
Joel, thanks for your long answer. Most appreciated. I admit that I did not get everything due to my limited abilities concerning the English language and especially the many abbreviations you use, but sure understood the most important things...so I got the essentials. Long, long time ago I used to work for Chrysler and helped them settle the factory in Graz, Austria. I'm an engineer myself and I think your example is very true but has been "turned off" by the "forum vacuum" as you describe it. I did not see it that way, but it seems that it is how it goes as it was almost the same when discussing quality issues with Chrysler. Zillions of automatic transmissions died and the ynever said "hey we know its a poor design but we'll fix it!" And like Aplle they fixed it (in this case an improved transmission oil cooler) and AFTER that they said "yep we had a LITTLE probem." This little problem affected 70% of all Chrysler Voyager vans sold on the German and Austrian market in the first two years. So now that we have most probably uncovered what BMW does, or better NOT does, what will lead us to our target? Tomorrow morning I'll try to reach an electrician I know. He once gave me an adress of a small shop who did alternator repairs. I want to see if they still do such repairs and I'd like to speak to them concerning the coating of the copper wire. Thanks again, Steve |
12-27-2011, 12:56 PM
#173 | |
Oddometer: 1,353
12-27-2011, 05:32 PM
#174 |
Ridin' in MT
Oddometer: 986
Do the rewind shops have a way to rig up a test to see what temp we are looking at? Maybe an embedded RTD with leads coming out with the power leads? If you do this with a couple stators and install them you may get an idea what temps the stators have to live with.
David
'07 VFR800, '09 F800GS, 07 CRF250X Riding roads in Montana - Big Sky Country www.mtrider16.smugmug.com Alaska Trip Report |
12-27-2011, 06:00 PM
#175 |
Oddometer: 1,353
I don't know if rewind shops do, but anyone could buy 2 digital cooking thermometers. Pull the guts out, pop the case off the engine and epoxy the thermistors to the winding. I'd do it but I don't have an F8 anymore.
12-27-2011, 06:25 PM
#176 |
wanderer
Oddometer: 417
[QUOTE=JoelWisman;17600104]This IS the way stators fail. There are a few other types of failures but they are extremely uncommon. There is going to be more then one cause and different bikes may have a different primary cause.
I wouldn't think exhaust temp is going up over time, but thats an interesting possibility. The F8, as apposed to the F650 DOES have air injection. Air is injected straight into the exhaust to allow the catalyst to do a better job, if for any reason there is more fuel in the exhaust, the bike is running richer or injectors are shooting a poorer pattern, after burning will occur and the exhaust will get considerably hotter. Joel Thanks for the detail reply. The above quote high light your idea of possible extra heat in the pipes, stands out to me. Do we have any logged stator failures of F650GS? i.e. the one with out air injection? Please Speak up if you know of one. With out the air injection aka oxygenating the exhaust gas to finish the burn in the exhaust pipes. Have the bikes with the failure had the mapping tweaked to make the engine run richer? again producing more unburnt fuel in the exhaust pipe to burn there? FWIW in stator insulation quality. In a past life we made coils (similar but not stators) that live in jet engines. Some live in 800F continuous. Could not use solder as it melts around 475F. While I've long since forgotten the 'potting" material, it was not outrageously expensive. The point is it is easy and not very costly to get stator insulatin/potting materials that will survive high temps. Temps much higher than being seen on the BMW stator |
12-27-2011, 11:24 PM
#177 | |
Oddometer: 470
Steve |
12-28-2011, 04:27 AM
#178 | |
HoosierDaddy?
Oddometer: 83
My 2009 F650GS's stator failed at 28,000 miles.
![]() ![]() [QUOTE=vtbob;17602702] Quote:
12-28-2011, 07:25 AM
#179 |
Oddometer: 3,441
Heat shield for the exhaust........
12-28-2011, 07:26 AM
#180 | |
Oddometer: 262
As Joel said this stator is interesting as it was only starting to fail. The shop which rewinded it is closed this week for x-mas (hey , we are in Latin America. but as soon as they open I will go and stay there while they unwind it, and I'll take a few pictures. but what is interesting to note is that the varnish is cracking only on the engine side (it appears there is more heat on that side). On the outside side, the wiring is only slightly discolored and only the 3 poles right behind the connection are black, as seen on the picture. I have no idea if the charred connection is the source of the problem (an elecric problem) or the consequence, (melted because in contact with the casing cover, which would be too hot).
http://www.newfrontiersadventures.com/MC/CentralAm.html C5! screwed with this post 12-28-2011 at 07:33 AM |
