Old 02-13-2013, 03:53 PM   #661
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,195
Originally Posted by Emmbeedee View Post
Ordered a stator from RM today. Should be here early next week.
If you got overnight delivery you could have gift wrapped it for "her". A rose and a stator.
My girl's getting white turn signals for Valentines. If only the damn mailman would cooperate! To hell with $80/doz roses, I want something that will last longer than a week.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 02-13-2013, 04:17 PM   #662
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Interesting idea. Too bad she reads this thread.
Old 02-13-2013, 05:24 PM   #663
JRWooden
Oddometer: 4,267
Originally Posted by ebrabaek View Post
Epoxy is not a good conductor. I was under the impression that the insulation on the wire itself was the baked on shellack. And the epoxy added strength, and stability....... At least the copper coil wires I worked with.... That was the case. But again..... I know nothing about winding a stator.....
sorry, I should have been more clear ... it was after 5PM when I posted that ...
I was thinking in terms of thermal conductivity ... not electrical ...
I know some epoxy resins are designed with thermal conductivity in mind, but for most formulations nobody cares.
I wish I had asked more questions about the potting compound Westinghouse used .... but that was a long time ago ...
Old 02-13-2013, 05:29 PM   #664
ebrabaek
Oddometer: 4,763
Ha ha ha..... I am not sure of how that would apply here. In a CF matrix, the thermal coefficient of expansion, and thermal conductivity is very small. But as this stuff is lung around in ( flywheel, not stator) about 3-400 deg F. temps.... eventually it will pass through that temperature......
Erling
ebrabaek is online now   Reply With Quote
Old 02-13-2013, 05:30 PM   #665
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Back when you were interested in "pot", right?
Old 02-13-2013, 05:33 PM   #666
JRWooden
Oddometer: 4,267
There might be a hint of truth to that .....................
Old 02-13-2013, 05:36 PM   #667
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 987
What a good idea. Flowers are a waste of money!
Stephanie
'01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
'....and I shall baffle you with cabbages and rhinoceroses in the kitchen, incessant quotations from "Now We Are Six" through the mouthpiece of Lord Snooty's giant, poisoned, electric head. ' from My Pink Half of the Drainpipe by Bonzo Dog Doo Dah Band.
dresda is offline   Reply With Quote
Old 02-13-2013, 05:50 PM   #668
WayneC1
Oddometer: 2,578
Re the F650 stator mentioned earlier in the thread, there are differences between the F650 and F650GS
The F650 is only 280 watts and the GS is 400 watts, some of the Co's offering stators get confused and lump them together
On the GS we have seen stators cook and epoxy break up and go through oil ways so I would not expect using one from the GS would be a good idea
WayneC1 is offline   Reply With Quote
Old 02-14-2013, 01:49 PM   #669
vtbob
wanderer
Oddometer: 595
It is almost up to 40F here today so I opened up my f650 to look at the stator.
Yep it is pretty toast..black. Pretty much like Emmmbeedee's wife's. Mine has not failed but I order a Electrosport today..mainly because they ship with connectors on.
when looking at the black stuff on the stator...I could not help but think of cabonized oil....not just the stator epoxy failing.
The carbonization is clearly worst on just some of the poles.
A wild an no way substantiated though that oil carbonizes on overly hot stator, build up the oil based carbon crud which act as insulation and accelerates the over heating process till hard failure occurs. could this mean that using more temperature resistant full syn oil would delay stator failure?
is this a case for only running full syn oil in the f800 engine?
vtbob is offline   Reply With Quote
Old 02-14-2013, 02:10 PM   #670
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,195
Originally Posted by WayneC1 View Post
The F650 is only 280 watts and the GS is 400 watts, some of the Co's offering stators get confused and lump them together.
I had heard that the early 650 singles were lower wattage(ie. carbureted versions). Both my 650CS and GS manuals for the later injected bikes rate the alt at 400W/14V. I'm no expert but I believe a lower W stator would have less windings or like on Honda XR R's, some poles aren't wound where the XR L's are fully. It was a trick to rewind the whole stator for more output on thr R's.
In any case, when the time comes I'll compare side by side. In an emergency, I'll take those lower watts over pushing.
Old 02-14-2013, 02:23 PM   #671
ebrabaek
Oddometer: 4,763
Interesting assessment. After things have been cooked at 400 F., for a good long while, I would be hard pressed to, to id the diff. between a Polymer, and carbonized oil. It does seem plausible to me, that if oil caking builds up topside, it could add a heat insulator, preventing the coil from releasing enough heat to sustain itself.... Maybe.
Erling
Old 02-15-2013, 03:51 AM   #672
JRWooden
Oddometer: 4,267
I agree, looks like only the "bottom" coils have the caking
(if I'm looking at it correctly ... the wires come out the top/back of the side cover IIRC?)
Which would make those coils hotter making them cake more ... etc....
How high up in the side cover does the oil level come when the bike is running and on level ground...
Compared to the height of the stator ... I would think the oil level would not come up high enough to even partly submerge the stator ... but would have to hold the dip stick up to the side of the bike and "draw" the level lnie around the crankcase to be sure .... Anybody know off hand?
Before he shoved off to work for the competition Joel had made a "stator detunning" modification that he guessed would shave ~100W off the output of the stator ... which would still leave adequate output for use w/o heated clothing and would sure keep stator cooler ... but I don't think we'll ever find out how well that worked out
Maybe as a maint. item we need to clean the gunk off the stator every 12K miles or so? Sheezzzzzzzzzz
Old 02-15-2013, 12:03 PM   #673
bross
Where we riding to?
bross's Avatar
Oddometer: 4,601
I don't own an F800 but had a Honda CBF1000, which are known to fry stators on a regular basis, mine fried at 22,000kms. I always run Amsoil full synthetic and that's what was in the bike from it's first service so I don't think synth is going to save the stator. My solution on the CBF was to install a CompuFire R/R along with the new stator and that setup ran to 38,000kms when I traded in the bike so not sure if that second stator is still running or not.
Old 02-15-2013, 12:11 PM   #674
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,405
Yeah I bit the bullet and went Compufire on the new stator and redesigned flywheel! $1,000 later I better not see that stator burn up for at least another 60,000 miles.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 02-15-2013, 12:18 PM   #675
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,195
With the bike running the oil level would be next to nothing. Remember also that the stator is surrounded by the rotor, which rotates? So any oil would be flung centrifugally (today's word) all over the hot stator, which just screams as anyone would in that situation. The only time the oil level would possibly submerge it is when the bike is hot, upright and off. Further theorizing necessary on your part. I'm more of a criticizer.
Huh? That's just silly. Might as well unplug an injector to save gas while you're at it.
Times are GMT -7.   It's 06:51 AM.
