Old 03-03-2013, 08:48 PM   #781
ebrabaek
Oddometer: 4,710
Erling
Old 03-05-2013, 02:47 AM   #782
mmmmbeeeeer
Oddometer: 30
2013 model?
Hi all,
I read earlier in the thread that the new flywheel design might solve the problem. Does any one know if the 2013 F800GS models have the new flywheel design?
mmmmbeeeeer is offline   Reply With Quote
Old 03-05-2013, 03:50 AM   #783
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,520
Originally Posted by mmmmbeeeeer View Post
Hi all,
I'd be very surprised if they didn't.
Emmbeedee is online now   Reply With Quote
Old 03-05-2013, 03:16 PM   #784
vtbob
wanderer
Oddometer: 535
I agree, my guess all F800 after mid 2012 had the new stator/fly wheel-rototor
but if anyone knows different let us know
vtbob is offline   Reply With Quote
Old 03-05-2013, 11:59 PM   #785
WayneC1
Oddometer: 2,424
What's the bet they used up old stock before fitting the new one in production ? or perhaps I should be less cynical ?
WayneC1 is offline   Reply With Quote
Old 03-06-2013, 01:44 AM   #786
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,304
Hi all,
Yes all new bikes have the new flywheel.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is online now   Reply With Quote
Old 03-06-2013, 07:03 AM   #787
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,039
It's all about economics. Since there was no Gov't mandated recall, and it's not life threatening (to the avg GS that never sees dirt) then the Bean counter would evaluate the leftover stock vs the cost of warranty work anticipated from inaction and come to some conclusion. You bet they used all the old stock. If they're like most manufacturers today then the qty of old stock would be limited at least. Just in time manufacturing, kaizen, Lean, Kanban, gazuntite... whatever.
You bet there is an inacessable record of affected bikes. Like with the chain recall, they knew right down to the last sn which bikes were affected. Mine was the second last 800 made with the crappy chain. Regulations and all.
But go ahead and be cynical, it's all about saving money. Like what we do by just changing the stator.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 03-06-2013, 01:46 PM   #788
JRWooden
Oddometer: 4,230
WANTED: Dead R/R from a twin....
WANTED: Dead OEM R/R from a twin....
Here's the deal:
OEM R/R is shunt style causing high heat in unventilated stator assby.
While I'm sure the FH020AA R/R is a good quality product and regulates at a more proper charging voltage, it's still a shunt regulator, so I'm not sold on it personally.
Not sure if it's true, but have heard some less than stellar feedback on the CompuFire unit, so for about the same money or less I found this unit which it talked up on various other forums:
http://roadstercycle.com/Roadstercyc...Regulators.htm
It is made by this company: http://www.cycleelectricinc.com/
I have an Electrical Engineer buddy that has an oscilloscope, and Joel has agreed to "provide technical guidance" to the project in an attempt to see if potential fears of possible harmful side-effects of using a series style regulator (posted a few pages back) are proven out or not....
I'd like to be able to do quick "side-by-side" testing so would very much like to have a spare set of BMW harness plugs that I can solder to the CE 605 SB regulator. Does anybody have a dead OEM R/R laying around they'd like to donate to this project?
I'd be happy to PayPal you some green to cover shipping ...
Thanks,
Jim
JRWooden screwed with this post 03-06-2013 at 09:48 PM
Old 03-06-2013, 06:36 PM   #789
WayneC1
Oddometer: 2,424
If I had one it would be all yours but I dont, will ask around for you
Old 03-06-2013, 09:48 PM   #790
JRWooden
Oddometer: 4,230
Thanks .............
Old 03-09-2013, 03:25 PM   #791
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 975
Well, the RM stator that EmmBeeDee installed in my '08 '650'GS last month passed its shake-down run with flying colours today - had the Gerbing heated jacket (75W) and the Warm and Safe heated socks (9W) on at about 80% power today with the heated grips on 'grill' and did 278 kms without any problems with starting or battery lights coming on.
eta: That's 9W per sock so 18W
Stephanie
'01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
'....and I shall baffle you with cabbages and rhinoceroses in the kitchen, incessant quotations from "Now We Are Six" through the mouthpiece of Lord Snooty's giant, poisoned, electric head. ' from My Pink Half of the Drainpipe by Bonzo Dog Doo Dah Band.
dresda screwed with this post 03-09-2013 at 03:35 PM Reason: eta: That's 9W per sock so 18W
dresda is offline   Reply With Quote
Old 03-09-2013, 03:34 PM   #792
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,520
Fingers crossed... but looks good so far.
Old 03-10-2013, 12:18 PM   #793
Cippy
Oddometer: 3
I've installed the Compufire on mine F800GS and the stator's carter is cold like clutch's one..or even colder.
Compufire works for me.
Cippy is offline   Reply With Quote
Old 03-10-2013, 03:52 PM   #794
JRWooden
Oddometer: 4,230
Thanks Cippy!
I expect they are very similar designs, hope to capture some OScope data sometime between now and June and "upgrade" my bike before my long-distance summer excursion!
Jim
Old 03-18-2013, 07:59 AM   #795
fernan_ci
fernan_ci's Avatar
Oddometer: 201
I'd like to see people post pictures like this of their replacement (Rick's/Electrosport/What Have You) stator.
I was comparing the RM Stator to the BMW and found the RM version is quite a bit thinner.
I emailed them to see what they had to say about that but I have not heard back from them yet.
I wonder if this is the difference between a 280 and a 400 watt stator?
Just for the record, the part number for the F650GS single and F800GS twin is the same on Rick's web site, part number 21-023.
Could F800GS stator be replaced by this one?
fernan_ci is offline   Reply With Quote
Times are GMT -7.   It's 07:47 AM.
