12-12-2011, 07:07 PM
#106 |
back in the saddle again
Oddometer: 590
OH - me likey!!! I've already wrapped my exhaust with heat wrap BUT wow this has potential.... I would like to try it for sure!!!
TheCowboy |
12-13-2011, 07:53 AM
#107 |
Wicked Slow
Oddometer: 316
this should be a very easy part to make....I will look into it. and keep you posted. how hot do you think it gets? i just need to find the correct resin
1995 R1000 GS 1998 R850 GS 1999 R1000Gs ![]() 2007 KTM ADV 990 2009 R1200GS ![]() 2012 F800GS Special Edition
Astolfo screwed with this post 12-13-2011 at 08:03 AM |
12-13-2011, 09:58 AM
#108 |
Oddometer: 3,441
Since the oil cools the cover, and the coolant cools the oil, I would hope that whole mess should never exceed 200F?
As a high-side estimate I would guess (hope?) that the side cover never exceeds ~250F / 120C. There is going to be some radiant heat gain from the exhaust which is going to be hard to estimate. Maybe someone with an IR temperature gun could shoot a reading on the bottom-side of their stator cover after a good hard ride? |
12-13-2011, 11:22 AM
#109 | |
Oddometer: 1,353
I know IR guns look neat and have a pleasant number of buttons and big lCD digits that seem all high tech, but they are perhaps the most grossly misused tools on the planet. IR thermometers are for highly trained professionals and novices that have studied hard to take QUALITATIVE readings of prepared surfaces that can not easily be measured by direct contact. IR thermometers are never for taking QUANTITATE readings unless the instrument costs thousands of dollars and the user has a masters or better in thermodynamics. In addition to the laser pointer, stun-gun, and torch lighter, IR guns are fun toys, but thats all they are unless you know a hell of a lot about how to use them. I don't say this to be arrogant, but because I see IR guns cause needless worry when they are continuously misused. An ir thermometer reads emitted infrared energy in a given portion of the EM spectrum. Cheepo IR guns are not well calibrated and read outside of the bandwidth of heat. In addition, different substances radiate at higher and lower bandwidths at the same temperature. Thickness of a substance also affects the radiated wave length. this is just for starters. The biggest affect to an IR guns reading is going to be how the surface differs from a black body. Chepo IR guns are usually calibrated loosely and inaccurately to an emissivity of 0.95. This works well with many organic objects but won't be accurate at all for our stator cover surface which is glossy enamel paint usually having an emissivity of around 0.8. Further, there is reflectance. The surface of our stator is reflective and is going to reflect a lot of IR energy from near by emitters such as the exhaust down tubes. Back to the subject at hand which is the stator cover temperature. Using an accurate CONTACT probe after a hard ride in a 36 F ambient, the surface of the stator cover was 213 F and varied just 4 degrees in the 8 places I measured it. Back to the subject of IR guns, using my upper end toy IR gun it varied from 189 to 257 degrees. The IR gun is not wrong. I have little doubt that it is accurately measuring emitted IR, but emitted IR is of no relevance to the question of the stator cover temperature nor most of the other things people use IR guns for. Heres an accurate surface probe http://www1.mscdirect.com/cgi/NNSRIT...-SearchResults 1/4 the price and reads temperature, not emitted IR :)
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250 I love and miss you Jeneca and I'm sorry. |
12-13-2011, 01:31 PM
#110 | |
Wicked Slow
Oddometer: 316
so...a 400F resin should be good enough? I do not want to end up with a bunch of melted resin on my bash plate....
12-13-2011, 02:23 PM
#111 | |
Oddometer: 3,441
Likewise ... thanks on the surface probe vs. IR... I just ordered a surface probe! I don't own an IR gun and ... don't think I'll buy one ... ![]() Astolfo - I'm just guessing, but yeah I would think that if the carbon fiber part is going to be attached to (or even better yet) spaced slightly away from the bottom of the stator cover that 400-degree resin should be fine. I'm curious - Is the higher temp. resin more expensive? Harder to work with? |
12-13-2011, 03:50 PM
#112 | |
Wicked Slow
Oddometer: 316
12-13-2011, 04:51 PM
#113 | |
Oddometer: 2,820
![]() Erling |
12-13-2011, 07:50 PM
#114 | |
Wicked Slow
Oddometer: 316
12-13-2011, 08:53 PM
#115 | |
Oddometer: 2,820
Erling |
12-13-2011, 09:00 PM
#116 | |
Wicked Slow
Oddometer: 316
maybe we can exchange ideas here and see what we can come up with
12-14-2011, 05:37 AM
#117 | |
Oddometer: 2,820
Erling |
12-14-2011, 06:17 AM
#118 |
wanderer
Oddometer: 417
[QUOTE=JRWooden;17507394]Since the oil cools the cover, and the coolant cools the oil, I would hope that whole mess should never exceed 200F?
As a high-side estimate I would guess (hope?) that the side cover never exceeds ~250F / 120C.) end quote I believe most water / oil cooled engine design try to keep oil tempature above 225F so it is above the boiling point for water. This make any water in the oil, water is a combustion by product, boil off and vent. I believe the top temperature is around 275F. Synthetic oil can tolerate higher. The temperature range between these is normal. This makes sense in a water oil cooled engine as the water temp(under pressure so it is higher) is limited by venting/blow off at around 230F. It is clear that the oil is always (nearly anyway) hotter that the water so the water cools the oil. In reading all these post it would seem ( but not enough facts to say for sure ) that the problem is in failing regulators and the burning of the stators is a symptom of that failure. The write up on the SCR (fail short) and FET(fail open) failure modes ring true to me. Does any one know of a FET based regulator as a replacement for the stock unit? I'm planing on a taking my 17K mile bike on a 10K mile trip to alaska next spring....so that replacement regulator may be prudent |
12-14-2011, 09:35 AM
#119 |
Oddometer: 1,353
I'm confused vtbob.
I've only ever heard of 3 regulators failing on one of these bikes, this thread is about stator failures. As to the failure modes of FET versus SCR, same experience here, but the SCR doesn't fail closed for very long as it burns up. In any case, failing open is the worst possible outcome, once open nothing shunts current to ground, voltages go through the roof, all lights burn out, then all 7 of the onboard ECU's. There is some interest in a series regulator rather then the parallel one that comes stock, but the difference between SCR or FET in either one has nothing to do with reliability. What is your thinking on a FET R/R making your bike more prepared for a trip?
12-14-2011, 10:21 AM
#120 |
wanderer
Oddometer: 417
I must admit, I do not understand this stator failure problem. I've been trying to glean a better understanding from all the posts and the article in the MOA mag.
My, admittedly uninformed bias has been toward an electronics failure..ie the regulator. the Stator is a lump of metal and some type of insulation polymer. It seems to me that it is so easy to design the stator to withstand over currents and over temps...with essentially no cost penalties....that is would be so dumb not to have huge design margins...it would not be the root cause. Over my experience Iv've replace several regulators and a few alternator diodes....never had a stator problem. Yep I know this has no direct mean to this problem...but my bias is there till I understand the root cause. Thanks for the additional info |
