04-05-2012, 03:58 PM
#106 |
Addlepated
Oddometer: 2,060
04-05-2012, 09:28 PM
#107 | |
Two Wheeled Addict
Oddometer: 5,246
2. The empty tanks with no hardware weighed the same as my stock tanks with no hardware. Tells me they weigh less than the stocker/fairings combo 3.Well the Neduro tank holds 2.4 (Thats the most I got into mine) and that gives you a total of 8.2 gallons. the Safaris hold an average of 11 gallons.
Speed bumps never seem to make me go any faster |
04-05-2012, 10:32 PM
#108 |
990 Adventure
Oddometer: 62
Does anyone know, how much there is still gas, when the fuel light goes on?
04-05-2012, 10:38 PM
#109 |
Two Wheeled Addict
Oddometer: 5,246
Easy way to check. When the light comes on. Pull over and shut the crossover petcock off. Ride till the bike dies. Times 2 and there ya go,
04-05-2012, 10:41 PM
#110 | |
Dans le doute...gaz!
Oddometer: 1,722
2. Yep they weigh 0.8lbs less actually 3. On a 990 with the neduro I could only get 7.5 gallons
The race is long and, in the end, it's only with yourself...
bikyto screwed with this post 04-06-2012 at 08:49 AM |
04-06-2012, 05:49 AM
#111 |
Oddometer: 384
ONLY 7.5 gallons he says
"I have no idea what I am doing... yet" - me Husqvarna 2011 te630 |
04-06-2012, 06:58 AM
#112 |
W. F. O.
Oddometer: 556
The love of the road is not something you can explain to someone who does not understand it.
2008 KTM 990 ADVENTURE ![]() |
04-06-2012, 08:06 AM
#113 |
Two Wheeled Addict
Oddometer: 5,246
Versus the 11.5 he gets with the Safari's. Yeah thats All.
04-06-2012, 11:30 AM
#114 |
Oddometer: 384
If they will let me save some weight vs stock tanks, fairings, and crash bars... I would go with it. Otherwise I think am kind of liking the neduro tank on my left behind me. (Sure wish I could preserve the locking fuel cap too. People are assholes... yall ever worry about that? I do.)
Now if I need to outrun humungus and his gang of juice stealing hooligans, that might change and seal the deal. "Just walk a-way" not on your life, ugly
"I have no idea what I am doing... yet" - me Husqvarna 2011 te630 BaronVonDarrin screwed with this post 04-06-2012 at 11:37 AM |
04-07-2012, 07:55 AM
#115 |
Oddometer: 43
here a pic with my spermwhite Safaris
[Honda Varadero 125 2000 & 2003] [Honda Varadero SD02 2004] [Honda Varadero SD02 ABS 2005] [KTM 990 Adv N 2006] [KTM 990 Adv N/S 2007] |
04-07-2012, 12:24 PM
#116 |
Oddometer: 2,377
![]() Nice bike, great set up!!!
Jeff B In Maine BLACK 05.5 KTM 950 Adventure, Mine Electric Orange 06 BMW F650GS, Hers "We don't quit playing because we grow old, we grow old because we quit playing." |
04-08-2012, 04:02 AM
#117 |
Oddometer: 81
Safari tanks suck
I've had my Safari tanks for a year now and I sort of still like them but I'm getting real sick of the expansion problem.
The bottom mount has moved atleast 20mm maybe more, the headlight bolt holes have moved about 10mm. The rear of the tank has no more room to move, I have already ground the front edge of the side covers to make more room. The bottom brace has been extensively modified, it is not only the mount hole that needs to be moved but the clearance around the fuel hose/fuel petcock has been ground out several times. I went to refit my tanks today and again had to do more work to the bottom mount. DO THESE THINGS EVER STOP GROWING? I am a professional with all the gear and know how to modify things as needed but I often wonder what the average punter does about this. I shudder to think what butchery takes place at a workshop when some of those so called mechanics are refitting the tanks after a valve check or a water pump job. One of the reasons I go to alot of effort to have this right is so that, if I ever have to take the tanks off while on tour I've already got a problem, I dont need anymore! I think the tanks should have been made smaller and pre-expanded before sale. Has anyone got any stories to tell?
BMW Adventure bikes..... just an excuse to go home early |
04-08-2012, 05:02 AM
#118 | ||
Fluid Journey
Oddometer: 723
One of my ideas was to wrap the tank while it was still new .... Quote:
Signed ... Seeking The Collective Wisdom ...
04-08-2012, 06:30 AM
#119 | |
Addlepated
Oddometer: 2,060
FYI, Getting the Safari Aquiline tanks on with little effort |
04-08-2012, 07:22 AM
#120 |
oot & aboot
Oddometer: 25,818
David: they'll distort enough that kamanya's technique simply won't reach. My tanks had 3 gallons in each of them yesterday and the right tank had the bottom hole off by 30+mm and the windshield holes couldn't even see the holes they were destined for.
@ any given moment my tanks have various bolts missing because I gave up trying to get them to reach. As long as the tank doesn't fall off.. I don't sweat it. ![]() Oh snap! ![]() p.s. I have better results without even doing the top bolt up.. I start with the bottom and do the top bolt last as it is the easiest to line up. when things are super out-of-whack (like right now) I'll do the top bolt up about 4 threads and then bottle jack the bottom of the tank to bow it enough that I can reach the hole. Unlike Kamanya 's tanks.. my tanks have zero overlap with my rear fairings and always line up at the back without tension. I think these tanks have a lot of variance between sets?
www.motogeek.com Geek screwed with this post 04-08-2012 at 07:28 AM |
