Old 07-12-2011, 12:05 PM   #1
Giggity OP
Giggity's Avatar
Oddometer: 754
Question F150 won't shift out of Park....Help...
The truck was parked on Friday. Went to use it Monday morning and it will not shift. ABS light is flashing (was not last week). It is as though foot is not on brake while trying to shift. Something was messed up with the wiring for the trailer lights but not sure what. Company truck, not mine.
I looked on the F150 forum and found no solution there.
TIA
Giggity is offline   Reply With Quote
Old 07-12-2011, 12:38 PM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Brake lamp switch.
you don't see luggage racks on a hearse..........act accordingly
Old 07-12-2011, 12:59 PM   #3
ttpete
Rectum Non Bustibus
Oddometer: 5,990
Originally Posted by anotherguy View Post
Brake lamp switch.
Or a blown fuse from screwing around with trailer lights.
15 BMW RnineT
09 Kaw Versys
Old 07-12-2011, 01:25 PM   #4
ragtoplvr
Oddometer: 6,421
You probably have one of those shift interlocks that will not let you shift until you put on the brake.
Something in trailer lights wiring was messed up, fuse blown
Rod
ragtoplvr is offline   Reply With Quote
Old 07-12-2011, 01:30 PM   #5
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,078
shift interlock . . . likely a pressure switch in teh brake light circuit -- there may be an override under s small lastic plug in the console -- if there is such a plg, remove it, and press down with a small screwdriver
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 07-12-2011, 01:36 PM   #6
Dan Diego
Oddometer: 964
Yup, this happened to my brother's F150 recently. Fuse that controls the back-up light.
Piece of cake, quick fix.
I have no interest in living a balanced life. I want a life of adventure.
Dan Diego is offline   Reply With Quote
Old 07-12-2011, 02:52 PM   #7
Giggity OP
Giggity's Avatar
Oddometer: 754
I checked all the fuses. None were blown.
Where is the interlock, exactly?
Old 07-12-2011, 02:56 PM   #8
mcma111
mcma111's Avatar
Oddometer: 12,410
Put key in ignition
turn to on position but do not start engine
shift to neutral
start engine
shift into gear
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-13-2011, 08:35 AM   #9
bomber60015
Oddometer: 14,078
Can't say on your trunk -- on my Frontier, there was a small cover in the console (made of the same material, and flush, so tough to find) . . . remove the cover, and, poof, zippo bang!
Old 07-13-2011, 09:41 AM   #10
the kaz
has become "FERAL"
the kaz's Avatar
Oddometer: 1,689
Originally Posted by mcma111 View Post
Put key in ignition
shift to neutral
start engine
shift into gear
actually you turn the key to just before the ignition comes on. if you turn it far enough for the dash to light up the shift lock will engage.
Then to neutral and so on
works on all modern F or E series
< spell cheqeur is bustimicated >
the kaz is offline   Reply With Quote
Old 07-13-2011, 10:51 AM   #11
Switchblade315
Switchblade315's Avatar
Oddometer: 5,704
yeah he probably thinks the dumbass switches that keep you from shifting the truck without pressing the brake won't be on unless the motor is actually running. oops did i say that out loud... No i didn't I typed it with out thinking.. wait no i thought about that... Oh hell I bet he puts you on ignore as well because you corrected him. He don't like it when someone points out he's partly wrong.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 07-13-2011, 02:46 PM   #12
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,225
I had that happen to mine. It was the brake light fuse. Pull the brake light fuse out and see if it will shift. Don't trust looking at it.
rufus is offline   Reply With Quote
Old 07-13-2011, 09:27 PM   #13
Giggity OP
Giggity's Avatar
Oddometer: 754
This worked. At least now I can move the truck. ABS light is still flashing.....
Old 07-14-2011, 12:57 PM   #14
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
... and I'll bet your brake lights aren't working either!
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 07-14-2011, 06:22 PM   #15
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,120
My 05 need a new shifter. It was covered by Ford.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Times are GMT -7.   It's 09:19 AM.
