Old 09-20-2011, 03:04 PM   #391
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
What? My plans for long-stroke domination are ruined?
Just kidding... Chris has a 530, I've got a 450. Some of the pics are from his bike.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 09-20-2011, 05:18 PM   #392
AKjeff
AKjeff's Avatar
Oddometer: 5,165
So there IS more than one faring out there.
That faring is beautiful, it's making me rethink my DR purchase earlier this year.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 09-21-2011, 10:53 AM   #393
Parm
Exiled Swede
Oddometer: 126
Just paid for a Race Supporter kit.
Best of luck Ned!
Parm is offline   Reply With Quote
Old 09-21-2011, 09:18 PM   #394
colinsonic
Master Lurker
colinsonic's Avatar
Oddometer: 34
Clamps
- Clamping to the frame making a rock solid mount.
Here is a little preview of the lower mount.
This may be a silly question, but is there any concern that the clamp will work loose from the vibrations and abuse it will take?
colinsonic is offline   Reply With Quote
Old 09-21-2011, 10:03 PM   #395
DasMatti
DasMatti's Avatar
Oddometer: 263
not at all, if you loctite it
DasMatti is offline   Reply With Quote
Old 09-21-2011, 10:34 PM   #396
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,033
Aye, and the radiators will fall off before the nav tower does!
Great design fellas, very neat and minimalist - way to go!
Jx
JMo (& piglet) is offline   Reply With Quote
Old 09-22-2011, 01:16 PM   #397
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
So the signs the nav tower may be loose is a lack of power and some overheating.
Not to mention the clouds of billowing stream...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 09-22-2011, 01:48 PM   #398
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,876
Lower supports are a clearance fit around the studs. It is not a weight bearing location. The weight is carried from the friction by the clamping force of the 4 bolts in front of the head tube, bolt below the steering stop & a 6th bolt above the frame.
c.vestal screwed with this post 09-22-2011 at 11:30 PM
c.vestal is offline   Reply With Quote
Old 09-22-2011, 02:05 PM   #399
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
Those nav tower mounts aren't going anywhere. I had a very crude version on my 525 when I wrecked spectacularly last spring. Im pretty sure the bike did a full front flip, twisted the forks in the triple, and launched me and my tail bag at least 10 ft. The mount had a slight bend in one of the front uprights.
His version is alot more robust than the one I made.
What's the worst that could happen?
Junglerot is offline   Reply With Quote
Old 09-22-2011, 07:27 PM   #400
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,641
Originally Posted by c.vestal View Post
Lower supports are a clearance fit around the studs. It is not a weight bearing location. The weight is carried from the friction by the clamping force of the 4 bolts in front of the head tube, bolt below the steering stop, bolt above the frame.
True work of art c.vestal... Absolutely incredible. You've got some mad fab skills.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 09-22-2011, 09:22 PM   #401
colinsonic
Master Lurker
colinsonic's Avatar
Oddometer: 34
I should have prefaced my question by saying that the nav tower looks amazing. As does the rest of the build on the bike.
I work in construction and love well made things, and this definitely falls into that category, hence my curiosity. (It takes some effort to pull me out of lurker mode).
If you don't mind one more clamp related question, here goes:
Are the clamped pieces metal to metal, or is this there some kind of gasket or spacer between the metals?
Wishing you all the best on the Dakar.
Old 09-24-2011, 04:40 PM   #402
Qivittoq
Desert Dreamer
Qivittoq's Avatar
Oddometer: 26
push on and keep it comming
Ned! I was suppose to be sleeping, but I got stop reading the thread and seeing the awesome build! Cash support went your way immediately!
I am sure you have done the math, but do you have enough fuel capacity? A heavy 450 gets pretty thirsty in sand from my experience
Keep the dream and story alive!
Qivittoq is offline   Reply With Quote
Old 09-28-2011, 08:17 PM   #403
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,976
Shirt and stickers arrived! Go Ned.
"If you don't know where you're going, any road will get you there." -Henry Foster
Eurobiker is offline   Reply With Quote
Old 09-28-2011, 08:54 PM   #404
Mark950
Mark950's Avatar
Oddometer: 398
Subscribed .....
Shit happens - pick it up, start, ride
Mark950 is offline   Reply With Quote
Old 09-28-2011, 08:58 PM   #405
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,719
Munny sent. :)
GO NED!!!
MoBill is offline   Reply With Quote
Times are GMT -7.   It's 02:46 PM.
