Old 07-15-2011, 03:52 PM   #1
Waco OP
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,963
What is the best adhesive for reattaching my rear view mirror to my windshield?
I've been using the Loctite stuff and it keeps falling off, regardless of how carefully I follow the directions.
Support the AMA.
Waco is offline   Reply With Quote
Old 07-15-2011, 04:00 PM   #2
Hammerspur
Hammerspur's Avatar
Oddometer: 1,138
Wish I could offer advice, but have tried several times on different vehicles over the years with same results as you've gotten.... nothing worked more than temporarily.
Hammerspur is offline   Reply With Quote
Old 07-15-2011, 04:18 PM   #3
tedder
irregular
tedder's Avatar
Oddometer: 8,802
using their rearview mirror adhesive? And it's failing? That means you have a poorly prepped surface on one or both sides. Take it to a glass shop, I bet they will do it for cheap.
tedder is offline   Reply With Quote
Old 07-15-2011, 04:19 PM   #4
P B G
Oddometer: 10,001
I've never had a problem with that stuff when you just use it as directed.
Old 07-15-2011, 05:49 PM   #5
cagiva549
whats a cagiva
Oddometer: 2,480
When you find something that works let me know , I been trying for years without luck . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 07-15-2011, 07:04 PM   #6
Switchblade315
Switchblade315's Avatar
Oddometer: 5,944
I've always just went to a parts house and got what ever brand glue they have for that and used it. let the little mettle tab sit there for a few days before i hang the mirror on it never had a problem with it.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is online now   Reply With Quote
Old 07-15-2011, 07:43 PM   #7
bisbonian
bisbonian's Avatar
Oddometer: 1,054
Isn't Texas in the middle of a heat wave?
That stuff doesn't work that well with temps like the surface of the sun, hell high temps are usually when you find the mirror laying in your front seat.
Are you getting it all from the same place? Maybe it's old.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 07-16-2011, 12:16 PM   #8
FatDog
Oddometer: 852
Forget it. Just buy another car. Seriously, I've tried everything and none of them worked once the got super hot.
FatDog is offline   Reply With Quote
Old 07-16-2011, 04:56 PM   #9
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Try taping the area on the glass and scuffing it up a little. Easily said than done I know with tempered glass, but the scratches will give the glue a tooth to hold on to.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 07-16-2011, 06:10 PM   #10
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,723
Loctite has always worked for me. I'd clean the areas with a razor blade first, then use an alcohol wipe, applied the brush stuff, let dry and then the drops from the tube. Even at the dealership I used to work at used the Loctite stuff.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 07-16-2011, 06:22 PM   #11
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,169
Oh snap, a car...I was baffled for awhile..motorcycle website and all.
Kid, you're not trying to glue the whole mirror on are you? You're taking the mounting puck out and gluing that on, then snapping the mirror in later, right?
larryboy is online now   Reply With Quote
Old 07-16-2011, 06:36 PM   #12
forrestlaw
forrestlaw's Avatar
Oddometer: 306
Haven't used any to reattach rear view mirror, but 3M adhesives usually do work for me.
forrestlaw is offline   Reply With Quote
Old 07-16-2011, 08:36 PM   #13
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,169
Maybe swing by your local auto body shop and ask them to stick it on. There are some amazing glues for putting window latches and stuff on that are incredibly strong.
Old 07-16-2011, 08:54 PM   #14
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,906
I recently bought the Go Pro grab bag of camera mounts. They have the 3M VHB adhesive thats like F'n stupid glue. I had to pry it off with a screwdriver. Luckily it didn't take the paint off with it...
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 07-17-2011, 09:43 AM   #15
ttpete
Rectum Non Bustibus
Oddometer: 6,149
Go to the local Ford dealer and get one of their one-use kits.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Times are GMT -7.   It's 09:51 AM.
