Old 07-16-2011, 08:56 PM   #1
thelouv OP
ocd
Oddometer: 105
F800GS oil change
So I can't seem to get the search box to work on here. Keeps giving me some sort of Error 505 message. I know there are great posts on "how to" things here. Can anyone direct me to an oil change for the F800GS? Time for me to start doing it myself and I just want to make sure there aren't any little things I could miss (like on my previous Aprilia Capo and its 2 drain bolts).
Troy
BMW K1200S (sold)
Aprillia Capo (sold)
Triumph Rocket III (sold)
F800GS (got mine)
Next? Duc 1098 ADV? nope,
went back to a Jeep, and still lovin the GS
thelouv is offline   Reply With Quote
Old 07-17-2011, 06:04 AM   #2
CheckerdD
CheckerdD's Avatar
Oddometer: 1,295
I did not take pics last time I did it.
Looking forward on the left side, do you see that Aluminum colored bolt? Tap it LIGHTLY with a hammer to help it break loose. Then you stick your 10mm hex head into the hole and twist. I needed a little cheater bar since the dealer did the 600 mile, and it was really tight. Note the oil is going to come out nearly horizontally. So you need to have the pan below and to the side in such a way the oil lands in it. Next remove any crash plate you might have that prevents you from accessing the filter. Insert the tool you have to remove oil filters over the head and twist off. Make sure the rubber O' ring comes out with the filter. a portion of the oil in the filter is going to drain as you remove it. Then you put a bit of old oil on the new o'ring from your finger so it seals easily and twist on the new filter. Do not over torque it. I hold my socket close to the center (meaning my hand next to the socket) and twist firmly, but no harder.
Now put a new washer on the drain plug and insert. Dont over torque it. It made of soft metal and it gets heated by the motor. Maybe some nice person will post the torque setting. Its not a lot.
Now pour in your 3 quart containers of MOTORCYCLE grade 10w-40 oil. Run the bike looking for leaks, and top up as necessary. Dispose of the old oil in an environmentally friendly way. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 07-17-2011, 07:56 AM   #3
thelouv OP
ocd
Oddometer: 105
Sounds pretty straight forward. Thanks for the hint about how the oil projects out. The most difficult part may be getting a new crush washer ahead of time. Start adding to the list of chores for next weekend.
Thanks again!
Troy
BMW K1200S (sold)
F800GS (got mine)
Old 07-17-2011, 08:58 AM   #4
mitchapalooza
Rider is Air-cooled
mitchapalooza's Avatar
Oddometer: 114
The drain plug torque spec (per service dvd) is 40nm or 29.477ft/lb.
The filter (who torque checks this anyway..) is 14nm or 10.317ft/lb.
The drain plug crush washer is part number "11 41 7652949"
What other specs can I spew out from the service dvd for you?
Hope this helps.
-mitch
mitchapalooza is offline   Reply With Quote
Old 07-18-2011, 07:26 AM   #5
thelouv OP
ocd
Oddometer: 105
Hope this helps.
-mitch
It does help. Any idea if I can get a proper size crush washer from a normal auto parts house? The closest BMW dealership is over an hour drive away. Although perhaps I can convince them to drop one in an envelope & mail it to me. Then they know what I am doing. But alot of us do our own maintenance. Especially given the sparsity of the dealer network. I might chat with a friend of mine that is the German service mgr at the local MB,BMW auto dealership here. For kicks, I'll give him that part #.
Thanks again.
Troy
BMW K1200S (sold)
F800GS (got mine)
Old 07-18-2011, 09:01 AM   #6
jessehere
Ridin'
jessehere's Avatar
Oddometer: 777
I just anneal the old copper crush washer and reuse if I dont have one handy.I heat it up till its red hot on the stove and reuse.
jessehere is offline   Reply With Quote
Old 07-18-2011, 09:04 AM   #7
thelouv OP
ocd
Oddometer: 105
someone else told me you can just flip it over and get 2 uses from 1 washer. then get a new one for the next time.
Troy
BMW K1200S (sold)
F800GS (got mine)
Old 07-18-2011, 08:16 PM   #8
L8APX
Slightly Oversquare
L8APX's Avatar
Oddometer: 38
In a pinch, I have used the old copper washer up to 3 times without a leak. I always torque the drain bolt to spec (about 30 lb-ft).
L8APX is offline   Reply With Quote
Old 07-19-2011, 03:00 AM   #9
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,401
10mm hole? Gotta be a feature added to newer models. My '09 doesn't have this.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 07-19-2011, 04:23 AM   #10
B-B
Oddometer: 171
Yeah mine is like 24mm bolt, no hex cap type.
B-B is online now   Reply With Quote
Old 07-19-2011, 09:18 AM   #11
Tor
Native Viking
Tor's Avatar
Oddometer: 805
I have used the washer on my ST ever since it was new. It now has 70000 miles on it. 70000/4000=17 point 5. Never a leak. Doing the same on my F8GS.
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 08-31-2011, 07:45 PM   #12
jkosc1
Oddometer: 2
the 10 mm "hole" appeared on the 2010 model
jkosc1 is offline   Reply With Quote
Old 09-01-2011, 12:02 PM   #13
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,613
BMW recommends replacing the older style with the new as the bolt-head strips pretty easily.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 09-02-2011, 11:51 PM   #14
Stackator
F800GS goodness
Stackator's Avatar
Oddometer: 1,343
Read your bike manual in particular the part about getting the bike up to temperature (when the fan kicks in) prior to checking your oil volume. It's a very straight forward oil and filter change to do.
Golf courses are Enduro parks waiting to be discovered
Refresher for the Australian forum: http://www.deakin.edu.au/current-stu...outs/apost.php
Stackator is offline   Reply With Quote
Old 09-06-2011, 04:12 AM   #15
OZZY-GS
OZZY-GS's Avatar
Oddometer: 426
wow I can't believe it but I managed to round off the head of my drain plug(by the way I have a 2010 model and it sill has a 24mm Aluminium plug?)
Anyone have any good advice as to how I can get the bastard out?
Any help would be appreciated!
Riding
BMW F800GS
OZZY-GS is offline   Reply With Quote
Times are GMT -7.   It's 09:59 AM.
