Old 09-06-2011, 05:28 AM   #16
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
Plugged
Cut a slot in it with a dremel and use a thick washer clamped in a wrench as a screwdriver blade. Flatten one of the sides of the washer to get more contact and make sure the fit is tight. I have the 10mm replacement sitting in my toolbox so I'm hoping I can get the 24 out....
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 10-27-2012, 12:01 PM   #17
4TooMany
4TooMany's Avatar
Oddometer: 321
Originally Posted by B-B View Post
Yeah mine is like 24mm bolt, no hex cap type.
Just in case anyone's reading this (like I did) before their first oil change, on my 2012 the drain plug is a 10mm Allen. I have no idea when they changed exactly, but be aware to check before you go out and buy a 24mm socket (like I did).
MSF RiderCoach
2012 BMW F800GS Trophy
2011 Suzuki DRZ-400S
4TooMany screwed with this post 10-27-2012 at 02:03 PM Reason: initially thought it was a Torx
4TooMany is offline   Reply With Quote
Old 10-27-2012, 07:16 PM   #18
Flashdog
Oddometer: 343
Always use new oil to lube the fresh filter's o-ring.
Flashdog is offline   Reply With Quote
Old 10-28-2012, 07:07 AM   #19
malloy
Oddometer: 732
OZZY-GS: Take a chisel to one of the flats on your 24mm bolt head and hit it hard in the off (counter clockwise) direction, getting it to dig into the flat. This should "unfreeze" it. You can use a bolt grabber (http://www.sears.com/craftsman-10-pc...1&blockType=G1) if the head is severely damaged.
CheckarD's advice "Tap it LIGHTLY with a hammer to help it break loose." is a minimum when removing the drain bolt. Some BMW techs say to set your allen key or 24 mm socket in place on a breaker bar and bang it hard on the off direction or lightly in the on direction then hard in the off direction. So OZZY, you are not alone .
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 10-28-2012, 09:59 AM   #20
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Avoid all this in first place by doing your own oil changes and tighten the drain bolt nice and snug.
Get a Sharpie and put a nice thick line on the drain bolt at the 12 o'clock position and look at it from time to time.
The 10mm bolt is not a good idea IMHO, it looks like it was made simply to have people have difficulty removing it.
Amazing how Motorrad can source a 10mm drain plug but not decent front disk bolts.
Only use a 6 point socket on the conventional drain bolt. Forget the copper washer, I have reused mine a half a dozen times
and it doesn't leak a drop, the drain bolt never comes loose, and you can forget the idea of torquing the oil filter, too.
Old 10-28-2012, 02:23 PM   #21
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
Originally Posted by CheckerdD View Post
Now pour in your 3 quart containers of MOTORCYCLE grade 10w-40 oil. Run the bike looking for leaks, and top up as necessary. Dispose of the old oil in an environmentally friendly way. Dave
So why can't I use 10w-40 CAR oil?
and when will a decent person put up some pics (just kidding :o)
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 10-28-2012, 02:35 PM   #22
Motoriley
Motoriley's Avatar
Oddometer: 2,684
Oil Change
Use any oil that meets the spec in your owners manual. I've used "car" oil in all my bikes for years. Wet clutch and dry and I've never had a problem except I've saved a crap load of money. But many will tell you that if there isn't a picture of a motorcycle on it and it doesn't cost twice as much you will die in a fiery engine explosion...
Old 10-28-2012, 06:24 PM   #23
sorebutt
Oddometer: 1,838
I use Rotella in all my motorcycles and atv. It is a diesel oil, which generally holds up better on schear forces, plus it is motorcycle certified.
sorebutt is offline   Reply With Quote
Old 10-28-2012, 07:38 PM   #24
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
and If I don't?
Motorfiets is offline   Reply With Quote
Old 10-29-2012, 04:19 AM   #25
LukasM
Oddometer: 5,418
Originally Posted by Motorfiets View Post
and If I don't?
... then your engine will probably sell destruct and require a rebuild after only 25k.
Old 10-29-2012, 05:44 AM   #26
dirtysouthjacket
dirtysouthjacket's Avatar
Oddometer: 559
2 Reasons, it makes it easier to remove the next time and prevents O-ring failure. The o ring will be dry and "could" freeze to the surrounding metal. It can cause the o-ring to stick to the filter or engine case and make it a lot harder to remove the filter the next time. I had a friend have this happen to his boat. Once he finally got the filter off (which was apparently a PITA), he didn't check for the old o-ring. It was stuck up on the engine where he couldn't see. He put a new filter on with a new o-ring, which then resulted in the new o-ring AND the old (or whatever was left of the old) o-ring being between the filter and engine. Ended up blowing out one of the o-rings, lost all the oil and seized the engine.
Regardless of the engine type, I've always checked to make sure the entire old o-ring comes out and that the new one goes on correctly and is lubricated with oil. Its probably just going the extra mile and won't always cause failures, but not a lot of extra work.
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams
2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa
DSJ's Shenanigans
dirtysouthjacket is offline   Reply With Quote
Old 10-29-2012, 05:53 AM   #27
4TooMany
4TooMany's Avatar
Oddometer: 321
Originally Posted by dirtysouthjacket View Post
...and that the new one goes on correctly and is lubricated with oil.
At risk of putting words in his mouth, I think he was asking what happens if he doesn't use NEW oil like Flashdog suggested. The OLD oil works fine for lubing the O-ring. If the oil coming out of your engine isn't good enough to lube the O-ring, it should have been changed LONG ago.
MSF RiderCoach
Old 10-29-2012, 07:36 AM   #28
dirtysouthjacket
Oddometer: 559
Agreed. Maybe subconsciously I just wanted to share my own 2nd hand horror story.
DSJ's Shenanigans
Old 10-29-2012, 08:16 AM   #29
johnparjr
johnparjr's Avatar
Oddometer: 203
Oil change whats that? My dealer does oil changes for $39 so I don't bother to do it myself anymore
johnparjr is offline   Reply With Quote
Old 10-29-2012, 08:22 AM   #30
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
Don't get me wrong I do it every time...... just never bothered with coating it in new oil.... working at a dealership I've had days where I'll do a dozen oil changes in one day and the process involves draining the oil. new filter and then grab the jug of new oil before filling the bike. So old oil is just fine to coat the new filter ring
Motorfiets screwed with this post 10-29-2012 at 09:02 AM
Times are GMT -7.   It's 05:27 PM.
