Old 07-25-2011, 08:27 AM   #1
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,173
Drive sprocket loose???
So im putting a new drive chain on the old DR200 today. In my many years of owning and maintaining bikes I have somehow managed to avoid ever doing a chain before... so here goes the questions..
The front drive sprocket has some side to side "play" and was wondering if this is normal ??
The bolt is tight and my guess is since the bike only had about 2K on it that the sprocket has never been removed. Sprokets are good. Replacing the chain due to dry rot on the O Rings.
before I go taking off the sproket and trying to solve a problem that may not exsist...
is this side to side "play" normal ???
thanks in advance
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 07-25-2011, 01:26 PM   #2
JensEskildsen
Oddometer: 1,041
Hi, sounds normal to me :)
JensEskildsen is offline   Reply With Quote
Old 07-25-2011, 03:28 PM   #3
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Some end play is OK. How much are we talking about?
you don't see luggage racks on a hearse..........act accordingly
Old 07-25-2011, 04:06 PM   #4
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,345
WTF I have literally the same problem with my VFR 750!
Tighten the bolt and the drive sprocket can slide laterally along the splines about a millimeter. Can't get a straight answer if this is normal or not.
Note that it is NOT the shaft moving in and out of the case -- it is the sprocket sliding ON the shaft, even with the bolt tight.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 07-26-2011, 06:06 AM   #5
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,907
A little "wiggle" is fine...for both of you ;)
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 07-26-2011, 07:07 AM   #6
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Hold on a minute. Is it the countershaft that has endplay or the sprocket moving on the countershaft?
Old 07-26-2011, 09:37 AM   #7
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,173
Thanks for the replies..
for me its 100% the sproket wiggling a bit.. not much.. just enough to notice that it seemed loose.. but the bolt was tight.
New master-link chain on and rode out 50 or so miles.. all is well..
EXCEPT....
4 bikes with chains... the DR is the ONLY one that "clicks" (chain noise) when I roll it around... it did this before and after the new chain.. not sure what the "clicking" is... its almost like the chain/sprockets mayh not be lined up correctyl.. but the adjusters are matched and tire spins evenly...any ideas???
Old 07-26-2011, 10:05 AM   #8
anotherguy
anotherguy's Avatar
Oddometer: 6,631
I bet one of the sprockets is worn like this. My Tuono does this to C/S sprockets so I replace them every 15K miles.
Old 07-26-2011, 11:50 AM   #9
LuciferMutt
Oddometer: 11,345
Sprocket sliding ON the countershaft, with the bolt tight.
Old 07-26-2011, 12:05 PM   #10
groundrules
groundrules's Avatar
Oddometer: 1,804
I'm about to do the chain/sprocket swap on my DR, so I'm reading with interest. It seems in this thread, a little slop is acceptable, but that doesn't reconcile with the thread a few doors down. I don't want to end up in this situation.
groundrules is offline   Reply With Quote
Old 07-26-2011, 02:50 PM   #11
anotherguy
anotherguy's Avatar
Oddometer: 6,631
If the sprocket is sliding on the C/S something isn't right. The C/S on my Tuono has .040" end play but the sprocket is solid. 80K miles and no problems. But you've got something that needs attention.
Old 07-26-2011, 02:58 PM   #12
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,809
Yes, it's normal.
Al Tuna is online now   Reply With Quote
Old 07-27-2011, 01:21 AM   #13
chammyman
Oddometer: 423
It is indeed normal.
1984 Honda CBX 750 FE
1985 Honda VF 750 F
1987 Honda CBR 1000 F
1988 Honda CB 350 SG
chammyman is offline   Reply With Quote
Times are GMT -7.   It's 09:21 PM.
