Old 12-07-2012, 09:43 AM   #1
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,811
Plastic Gear for Speedo
Hi!
My speedo cable jammed and stripped the plastic gear a bit that goes into the speedo drive. Can you purchase the plastic gear only. I think it will work the way it is, but if I can replace the plastic gear, I would prefer that. I have a 3-0 drive and a 2.9, both plastic gears were damaged before I realized the real problem! The plastic gear seems to be the same in both. I guess the metal gear in the speedo drive determines the ratio. The moto is a 1996 R1100GS. Thanks!
Donnie
Donnie - Retired & Riding - 2010 990ADV - 51,036 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is online now   Reply With Quote
Old 12-07-2012, 10:07 PM   #2
vintagerider
vintagerider's Avatar
Oddometer: 1,964
Is it the drive dog that contacts the aluminum piece? Often you can bend the aluminum. Only the aluminum piece is replaceable. Tried to swap gears from an R-R but in to the GS. Would not mesh up. For most cars you can buy the friggin nylon gear, not BMW.
vintagerider is offline   Reply With Quote
Times are GMT -7.   It's 09:14 AM.
