Old 04-30-2014, 10:09 PM   #1
drapes17 OP
keep on trucking
Oddometer: 67
Tkc front with kenda big block rear , anyone tried it ?
I just swapped out my shinko 705 to a tkc 80 front and a new big block rear , I made sure the big block was a 2013 , while at the shop I compared a 2011 date with the 13 and there's a big difference in block size , I hope it's the revision and may last longer , anyway anybody run this combo ? I realize the tkc will go around 6k on the front but if the big block goes 3 to 4000 miles it's not bad for 100 bucks ? I just hope I didn't screw up by changing from shinkos , they have been great tires and I've run Death Valley and baja a few times on them with no problems , watch me crash now I have knobbies on the dirt !! Ha ha
drapes17 screwed with this post 05-01-2014 at 08:18 PM
drapes17 is offline   Reply With Quote
Old 05-01-2014, 04:54 AM   #2
AdvMoto18
AdvMoto18's Avatar
Oddometer: 594
That'll work!
I like the TKC up front and the new version of the K60 on the rear. Not as good hookup on gravel as the older version but, better on the black top.
Compromises abound!
Think positive! Think bad things and bad things will happen!
2015 KTM 690 ENDURO R
2015 KTM 350 EXC-F
AdvMoto18 is offline   Reply With Quote
Old 05-01-2014, 05:31 AM   #3
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 18,176
that's the best set up I have found
I have gotten as much as 11,000 from the front tkc if you turn the tire around on the rim after about 5000 when the blocks start to wedge shape
the older big blocks on the rear were slick down the center by 3000 miles but I left it on until 6500 since the tire carcas is about 2 inches thick in that area
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 05-01-2014, 08:08 PM   #4
drapes17 OP
keep on trucking
Oddometer: 67
Cool , thanks guys , I do have to say the knobbies do make the bike look better !
I'll post my miles on the rear , I'm not worried about the front ,
I'll hit some trails on sat and report back , thanks
Times are GMT -7.   It's 05:58 AM.
