Old 12-20-2012, 03:45 PM   #136
Mike Figielski
Oddometer: 494
Originally Posted by tank slappa View Post
Can cheap hose clamps provide the same support as the $35 clamp from BBY?
I might be a little biased but, uh.... No!
Mike
Mike Figielski
Check Out:
beemerboneyard.com
Mike Figielski is offline   Reply With Quote
Old 12-20-2012, 03:55 PM   #137
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,532
Originally Posted by Emoto View Post
I'll be interested to hear (see?) how it goes. I expect that this winter I will get around to looking at mine and will not be pleased by what I see.
I ordered them a couple days ago. They should be there when I get home.
Jim
JimVonBaden is online now   Reply With Quote
Old 12-28-2012, 07:24 PM   #138
StormTrooper
Enough Already!!!!!!
StormTrooper's Avatar
Oddometer: 197
I have the same issues here in TX
After finally getting some time to look into where the fuel was leaking from I have the same issues with my pump flange.
Mike expect a call in the next couple of days!
I also did go ahead an file a NHSTA complaint to add another one to their records since this does need to be taken care of.
if you want to file here is the link
https://www-odi.nhtsa.dot.gov/Vehicl.../confirm.xhtml
Cheers,
Darin
2008 R1200 GSA - "I am sorry but I am out of cell phone range"
1974 CB750 - you want this for your man cave!
StormTrooper is offline   Reply With Quote
Old 12-29-2012, 05:41 AM   #139
John Smallberries
John Smallberries's Avatar
Oddometer: 1,301
Clamp on '05
I ordered the special clamp and installed it on my '05 last weekend. It was easy to access and seems to be the right tool for the job. Mine had not developed any cracks yet - but I store it outside in Michigan. I'm worried that if any tank will crack, it would be mine. I feel a bit better with the gadget in place.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 12-30-2012, 06:43 PM   #140
Virtual Farmer
Virtual Farmer's Avatar
Oddometer: 91
BMW recall?
Has anyone heard if BMW has issued a formal recall on this issue? I noticed this on a recent(ish) WSJ article and it looks like there might be some movement towards BMW taking some responsbility for this. I'd be interested to hear if any dealers have any additional info.
http://blogs.wsj.com/drivers-seat/20...al-fuel-leaks/
'11 BMW R1200GS | '07 KTM 690 SM
Virtual Farmer is offline   Reply With Quote
Old 12-30-2012, 07:17 PM   #141
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,159
Excuse me for being an ID10T on this matter, But what do I need to take off to see these flanges?
Marc 2007 R1200GS.
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is offline   Reply With Quote
Old 12-30-2012, 07:44 PM   #142
JimVonBaden
"Cool" Aid!
Oddometer: 53,532
Marc 2007 R1200GS.
On a GS take off the left large side cover and the black dome cover on the fuel pump. Look for cracks like this:
Jim
PS I doubt BMW will issue a recall for this. There have been many cracks, but few dangerpur leaks. My 120K mile GS has huge cracks, but is not yet leaking. I will be fixing it anyhow.
Old 12-30-2012, 07:44 PM   #143
meerobus
meerobus's Avatar
Oddometer: 474
Marc,
Pull the black plastic side panels number #1.
On the left side, remove the fuel pump cover at the top. Should be able to see what you're looking for. Mine's been cracked for a while but I think I'll be taking some precautionary measures before it leaves me stranded on some dirt road. We got to get together for a ride or two once all this snow goes away.
meerobus is offline   Reply With Quote
Old 12-30-2012, 07:47 PM   #144
Lomax
Lomax's Avatar
Oddometer: 9,159
Thanks.
Marc
Old 12-30-2012, 09:56 PM   #145
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,959
Marc 2007 R1200GS.
I didn't take off anything, I just used a streamlight and looked. If you can take a picture, the image will show the cracks better than you can see with your naked eye. However, taking the panel off will give you a much better view all the way around. Once I saw the cracks on mine I figured there was no need to take the panel off, just needed to make arrangements with the dealer for the repair.
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 12-31-2012, 05:05 AM   #146
JimVonBaden
"Cool" Aid!
Oddometer: 53,532
Since it is out of warranty the repair is going to cost you big!
Why don't you get the BBY clamp and save a bunch of money?
Jim
Old 12-31-2012, 08:40 AM   #147
WeazyBuddha
Oddometer: 4,959
My repair was under warranty, unfortunately the dealer used the old style parts not the new and improved so I am going to order the beemerboneyard clamps as I suspect the new clamp will eventually crack.
Old 12-31-2012, 10:04 AM   #148
JimVonBaden
"Cool" Aid!
Oddometer: 53,532
I probably will. MOST are cracked, most won't leak if not messed with too much.
For all, if it is cracked, clamp it!
My 120K mile GS is cracked on both sides, pump and return sides, but does not leak, yet. Still has the original QDs on it too. Not for long.
Jim
Old 12-31-2012, 11:52 AM   #149
duke944
Oddometer: 69
That's what I used. A hose clamp offers way more force than necessary to keep the flange from expanding/cracking, I just lightly snugged the screw up so I can still spin the clamp when turning it hard. I did have to partially cut the top half of the clamp to clear the quick disconnect release, but $1 sure beats $30.
duke944 is offline   Reply With Quote
Old 12-31-2012, 12:31 PM   #150
JimVonBaden
"Cool" Aid!
Oddometer: 53,532
The force from a cheap hose clamp is not equally distributed, but if it works for you...
Jim
Times are GMT -7.   It's 10:04 PM.
