Old 01-10-2013, 07:54 PM   #181
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,159
DOH I guess I am stupud, I keep wanting to register my bike with NHTSA but can never find the right site to do it at. If someone could shoot me a link that works it would be greatly appreciated.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is online now   Reply With Quote
Old 01-12-2013, 08:32 PM   #182
1200gsceej
1200gsceej's Avatar
Oddometer: 1,262
Marc
Post #117 or #164 maybe?
Or yet again - File a Vehicle Safety Complaint
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej screwed with this post 01-12-2013 at 08:37 PM
1200gsceej is offline   Reply With Quote
Old 01-13-2013, 05:33 AM   #183
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,970
BMW has a chance to fix 3 defects all in one shot. New flange caps that are shaped properly to not puddle water, made out of a proper material that doesn't crack, with new fuel strips attached. Wishful thinking, probably they will just put on some clamps. Oh wait, that is their solution so far. Pitiful.
bemiiten is online now   Reply With Quote
Old 01-13-2013, 12:00 PM   #184
jachard
Oddometer: 603
My apologies if this has been answered in this thread earlier but I didn't see it.....
Does this effect 2012 MY bikes? Just wondering since I just got a 2012 GS and will be using it for some longer trips and would like to address this now. Also, do the new bikes come with metal or plastic quick disconnects?
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
http://octaneworks.wordpress.com/
jachard is offline   Reply With Quote
Old 01-13-2013, 01:46 PM   #185
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,531
Cheers, James
2012 bikes have a ring attached to prevent cracking. You still have the plastic Quick Disconnects. I wouldn't sweat the QDs for now. When you get around 36K you ming want to consider upgrading the QDs to metal.
Jim
JimVonBaden is online now   Reply With Quote
Old 01-13-2013, 01:58 PM   #186
jachard
Oddometer: 603
Jim, Great, thank you for the response!
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
Old 01-13-2013, 03:23 PM   #187
TuefelHunden
TuefelHunden's Avatar
Oddometer: 600
Jim
My 2011 has the metal ring. Probably a mid-year production change. IMO, plastic quick disconnects are crap. Ask any of the 955i Triumph guys. The plastics would crack and leak like a sieve. Metal with viton o-rings are the best.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 01-13-2013, 03:57 PM   #188
JimVonBaden
"Cool" Aid!
Oddometer: 53,531
True, I should have said mid 2011 bikes and forward. I was just responding to his question about a 2012.
Thanks,
Jim
Old 03-01-2013, 06:44 AM   #189
StormTrooper
Enough Already!!!!!!
StormTrooper's Avatar
Oddometer: 197
There might be hope yet!
I took my 2008 GSA into Alamo BMW in San Antonio yesterday to see if BMW would do a good will warranty as some other had suggested and BMW came back 5 hours later that they would replace all of the parts of both the right and left side of the tank if I would agree to pay fro the labor which I am completely fine with!
It was some of the best news I had received all day!
2008 R1200 GSA - "I am sorry but I am out of cell phone range"
1974 CB750 - you want this for your man cave!
StormTrooper is offline   Reply With Quote
Old 03-08-2013, 09:17 AM   #190
StormTrooper
Oddometer: 197
BMW stood up and did the warranty on not just the fuel pump flanges but also the fuel pumps themselves. As I agreed to the out the door cost was 206.80 for the labor costs which I felt more than reasonable since the bike has been out of warranty for some time now.
So take your bike on down and it should not be too much of a problem.
Cheers,
Darin
Old 03-27-2013, 12:22 PM   #191
Visian
Look out!
Visian's Avatar
Oddometer: 1,689
Now the freakin' gasket is leaking!
Having gone through the process with the Beemer Boneyard collar and metal connectors, things were going pretty good on my HP2e for nearly 6 months.
Then, on the last ride, after filling the tank, I had gas leaking out from underneath the whole plastic plate.
I checked to see if the collar that holds the whole assembly into the tank was tight enough, and it was a tiny bit loose. After tightening using the two screwdriver method I still had a leak when the tank was full. The leak is very minute, but enough to catch fire, eh?
I've ordered a new gasket and plan to put in shortly.
Has anyone had issues with the gasket before, and is there anything special I need to know about putting a new one in?
'67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e
Visian is offline   Reply With Quote
Old 04-02-2013, 12:05 PM   #192
Visian
Look out!
Visian's Avatar
Oddometer: 1,689
Answering my own question for others to learn from....
The gasket that seals the junction between the fuel pump assembly and the tank is fitted to a lip on the tank first... and then the fuel pump assembly is pushed in. The fit is pretty tight.
My bike's previous owner had the HPN tank fitted by a dealer (not my dealer, Bobby), and when I removed the fuel pump assembly to fix the leaking flange, the gasket came with it. So the dealer must've put it in wrong too because I can't see how it would come out this way if assembled correctly.
It's hard to believe that it didn't leak sooner!
Old 04-13-2013, 05:44 PM   #193
flemsmith
lurk
Oddometer: 667
What are my best options???
....I have two 051200GS bikes, one is my wife's. Getting ready for a 2-up trip, I kept smelling gas on my bike, I've already had problems early in this or similar thread, tried JB-Weld, didn't hold for long, so tried the loctite epoxy that is supposed to be gas impervious, but put it over the failed JB weld. That held for a coupla years, but is now leaking. So I swapped tanks with my wife's bike, which is pretty unmolested, put a Beemer Boneyard clamp around her flange which had a slight crack, but no leaking gas, and now I'm all ready to leave.....but when I get back I need to deal with Cyndi's bike and my old tank.
Only two options I can think of are to empty it, try using my dremel tool to cut thru all the epoxy without damaging the flange, (yeah, right) and buy another boneyard clamp to see if that stops the leaks. (My flange was much more cracked than Cyndi's).
Or else to buy a whole fuel tank top end assembly and replace the whole damn thing. Pretty sure it's over $400. Is there another option I'm not tuned into because I haven't been worrying about this until today?
thanks for any advice.
roy
flemsmith screwed with this post 04-14-2013 at 08:33 PM
flemsmith is offline   Reply With Quote
Old 04-17-2013, 02:35 PM   #194
cnj3
Oddometer: 59
Same problem on my 2006 GS with 59000 miles, leaking around cracked flange. Anyone had luck with Beemer Boneyard fix of JB Weld and their collar on the flange with cracks? Leaving for Alaska in 6 weeks and looking for a good solution
cnj3 is offline   Reply With Quote
Old 04-17-2013, 04:07 PM   #195
mikegc
mikegc's Avatar
Oddometer: 1,667
1200GS Fuel Pump Flange Crack
Before repairing my '09 GSA, I read too many reports about JB Weld failures. I used the stuff Beemer Boneyard sends with the clamps. It's been in place about 5 months and I've had no problems at all.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Times are GMT -7.   It's 05:54 PM.
