Old 08-05-2011, 09:07 AM   #31
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,674
Originally Posted by ragtoplvr View Post
They make heat shrink metal rings. They shrink completely at 100C so should be safe for the plastic.
Here is a link.
http://www.intrinsicdevices.com/
They are not cheap, but if they have one the right size these could fix a flange, they can exert a huge amount of force in a completely uniform manner.
If they work there is a vendor opportunity for someone.
Rod
It's a liability opportunity.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 08-05-2011, 08:07 PM   #32
Jason1202GStime!
Jason1202GStime!'s Avatar
Oddometer: 251
Hi Jim,
Instead of going hrough the hassle of making the collar, why not just pour epoxy over is like what I did?
Once it filled to the top of the collar, basically it is holding up the female thread like the collar you mention?
I am sure it will be much easier this way...
Jason1202GStime! is offline   Reply With Quote
Old 08-05-2011, 09:10 PM   #33
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,475
Mainly because I have little faith in epoxy in this application. It might work fine, but I have rarely had good luck with it under tension.
A collar will ensure that the plastic doesn't expand. I am hoping to find one and not have it made.
Jim
Old 08-05-2011, 10:08 PM   #34
Jason1202GStime!
Oddometer: 251
Oh... I agree with you to a certain extend! Let us know once you have found the solution to it!
Cheers!
Old 08-25-2011, 06:12 AM   #35
davegaz OP
Oddometer: 58
Update. BMW comped parts and labor for a new pump. It took a while to get it done but all is well.
Shout out to Victory BMW in Chandler for making it happen.
Dave
davegaz is offline   Reply With Quote
Old 08-25-2011, 06:28 AM   #36
weld86
Weld86 Motoparts
Oddometer: 196
Dave
That's good news.
weld86 is offline   Reply With Quote
Old 08-25-2011, 07:47 AM   #37
JimVonBaden
"Cool" Aid!
Oddometer: 54,475
500 miles so far and holding with a washer and thread tape. I really need to locate a collar though.
Jim
Old 12-02-2011, 11:40 PM   #38
bajarider
bajarider's Avatar
Oddometer: 406
Same problem either.
Flange failure in a 2006 model, Fuel Pump Assembly is $474.69
Ouch!!!
Bajarider
Se habla español, and a little english.
When the U.S. and Canada enter rehab, we can kiss drug cartels goodbye.
bajarider is offline   Reply With Quote
Old 12-04-2011, 06:26 PM   #39
JimVonBaden
"Cool" Aid!
Oddometer: 54,475
Jim
Never needed a collar, and at 1500 miles, it is still tight and not leaking.
Jim
Old 12-04-2011, 07:11 PM   #40
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 5,000
This is getting old.
I was aware of some of the other flaws such as EWS, FD, brake flange but was not aware of this problem. Just went out to check my 08 GS and it seems to have cracks.
I'll take the cover off in the next few days to get a better look.
What a burden we carry liking, no loving, these bikes.
The good thing is that mine is still under warranty.
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 12-10-2011, 02:09 PM   #41
WeazyBuddha
Oddometer: 5,000
Better pictures.
Old 12-10-2011, 03:13 PM   #42
JimVonBaden
"Cool" Aid!
Oddometer: 54,475
If it is under warranty, have it fixed. If not, and it is not leaking, do not touch it, or it will leak.
Jim
Old 12-25-2011, 03:18 PM   #43
WeazyBuddha
Oddometer: 5,000
Update:
My dealer (Lonestar BMW in Austin) managed to snag the last Fuel Pump Flange in-country and the part is now on my GS--picture below. Apparently I get a two year warranty on this so I'll be covered past my warranty end-date.
Service rep told me they'd been having a few failures and they attribute it to the heat but I'm not buying that. When I asked, they told me the replacement part is exactly like the part coming off i.e. not an improved design and I was also told there was no BMW bulletin on the failures.
I just took the body panels off and I see where the part was scratched and it looks like metal to me so maybe it is an improved part.
I am filing a report with NHTSA; if enough of us file something may be done i.e. a recall. NHTSA reporting webpage LINK.
Old 01-06-2012, 09:56 AM   #44
TXjames
High Sider
TXjames's Avatar
Oddometer: 1,106
I would recommend that you guys with the failure file with the NHTSA like these fellows: The dreaded R1200RT Fuel Pump Leak Strikes Again
Looks like my pump will be replaced under warranty for the all-too-common regulator problem but if a recall does happen you can bet I'll be swapping it out again for a pump with the upgraded flange.
TXjames is offline   Reply With Quote
Old 01-09-2012, 04:59 AM   #45
OoPEZoO
Dirtball Extraordinaire
OoPEZoO's Avatar
Oddometer: 260
Add mine to the list. '06 1200GS with around 26k miles on it. I pulled the side panel last night and right away saw at least 3-4 big cracks in the flange. I don't know if had been leaking, but I had a few strong wiffs of raw fuel the last couple of times I was out on the bike. I won't be riding it until I can come up with a solution. Camera was dead, so I'll get pics tonight when I get home. Disappointed to say the least.
I'll be filing it with the NHTSA asap. For you guys that have the issue.....PLEASE file a report, it can actually make a difference. I had an issue with the fuel tank on my '08 Jeep Wrangler, where fuel would gush back out of filler neck when the gas pump would shut off. It was a well known issue on the internet forums, but Chrysler wouldn't do anything about it besides replacing the tank on the owners dime ($700 in parts + labor). Eventually, the NHSTA put pressure on them to replace the fuel tanks free of charge and include a lifetime warranty against it happening again.
My Pics. Looks like 5-6 cracks at least
'98 Buell S1
'06 R1200GS
'00 R1100RT (parting out, PM me)
OoPEZoO screwed with this post 01-09-2012 at 03:00 PM
OoPEZoO is offline   Reply With Quote
Times are GMT -7.   It's 12:22 PM.
