Old 12-11-2012, 11:01 AM   #121
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
1. I'm gonna go visit my dealer first, tell them I have filed with the NHTSA and see if they will do something for me. Can't hurt.
2. ALSO - I have the 90-degree QD and flange cracking on *both* sides of my tank (not just the pump). Has anyone seen BMW address the right side with any changes? Is there a part (other than the whole tank) for replacing that flange?
-ceej
My bike: Yellow '05 1200GS - on the Spotwalla ADV location page as CJ3.
My solo trips: 2014 Natl Park triangle, SF-Colorado-SF 2011 and 2013, SF-LA loop, Pinnacles and Carmel Valley loop
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is offline   Reply With Quote
Old 12-11-2012, 12:44 PM   #122
TXjames
High Sider
TXjames's Avatar
Oddometer: 1,082
Yes! I just had my right side ("sucking jet pump") flange replaced due to cracks and major leakage. It's under extended warranty or I would have used the 10ovr clamp. The replacement for this side has been upgraded with a metal collar just like the left hand pump side. Unfortunately, I don't have any pics but the collar looks just like the upgrade on the other side.
EDIT: Here's my upgraded pump side collar from page four of this thread...
Roll The Bones V - No premature incinerations. Oct 24-26, 2014.
http://www.rollthebonesrally.com/
TXjames is offline   Reply With Quote
Old 12-11-2012, 08:09 PM   #123
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by bkshovel View Post
I wonder what this means?? I just heard on the radio that Big Brother is investigating gas leaks on BMW motorcycles.
Originally Posted by Anorak View Post
Here it is.
It's good that the NHTSA is looking into this issue, but they might be the wrong agency for the job. A fuel leak is more an emissions-related issue. You folks should get the EPA and CARB (California Air Resources Board) involved. They'll go bananas over a defect-related fuel leak. Especially on a vehicle with a fuel vapor recovery system (aka charcoal cannister).
Note also that vehicle emissions equipment has a federal and state mandated warranty structure.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 12-11-2012, 09:59 PM   #124
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,412
Have there been any fires related to this leak?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 12-12-2012, 06:03 AM   #125
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,905
None that I have heard of.
I had a QD fail on an 1100GS and it was pissing gas everywhere. Gas doesn't catch fire as easily as people think. My ST was leaking too, and it dripped right on the exhaust. Nothing but stink.
Jim
Old 12-12-2012, 09:46 AM   #126
Rinty
Rinty's Avatar
Oddometer: 546
I had one loosen up on my 1150RS. Fuel sprayed out, but it didn't catch fire. An observant cage driver alerted me, while we were stopped at a light.
Rinty screwed with this post 12-13-2012 at 10:38 AM
Rinty is offline   Reply With Quote
Old 12-12-2012, 04:39 PM   #127
UAS
Oddometer: 106
QD Failures
Does the female quick disconnect ever fail? Or is almost 100% of the time the male quick disconnect fails?
The reason for asking is I think there is more potential for causing damage as it is way easy to over-tighten the female QD exacerbating any existing cracks. The female is a tapered thread IIRC and the sealant on the threads is acting as lubricant thereby making it hard to "feel" how tight.
I am pretty certain the metal male QD will work with the plastic female. Replace the male with a metal one and carry the female as a spare.
2012 GSA Triple Black
UAS is offline   Reply With Quote
Old 12-12-2012, 06:50 PM   #128
Mike Figielski
Oddometer: 490
The female fittings do fail quite often, actually. If you are carefull and do not overtighten the female fitting installing the complete set of metal fittings is the way to go. Just tighten by hand and then maybe 1/2 a turn with a wrench - max. If there is any cracking at all on the threaded boss where the female fitting screws in I highly recommend the repair clamp (even if you don't have any leaks yet). The repair clamp is worthwhile even if there are no signs of cracking. Hope this helps.
Mike
Mike Figielski
Check Out:
beemerboneyard.com
Mike Figielski is offline   Reply With Quote
Old 12-13-2012, 04:10 AM   #129
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,041
I'm afraid to look at mine. (2005 w/over 50k miles...)
Old 12-16-2012, 09:57 PM   #130
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
mostly male
{snip}
When I talked to the owner of my dealership I was told that it was primarily the male part of the QD that failed. They recommended swapping in the metal ones. The owner was not aware of their having seen the cracks in the flange.
I just looked at my buddy's '07 (right angle QD only on the pump) and he has some cracks. He has an extended warranty. I'll post (or ask him to) what he is told when he goes in.
-ceej
Old 12-17-2012, 07:44 AM   #131
JimVonBaden
"Cool" Aid!
Oddometer: 52,905
-ceej
The OEM originally started offering only the male side in metal as a replacement. However, the female side has it's weaknesses as well. I wonder if BMW had used a metal female on the bike from the start if the flange would crak as much? Seems that the movement and vibration of the hose could cause cracking of the flange potentially.
Jim
Old 12-19-2012, 11:43 AM   #132
1200gsceej
1200gsceej's Avatar
Oddometer: 1,259
Question certified BMW diagnosis ??
I just got off the phone with Mediha, a Resolution Specialist at BMW (motorcycle) customer service. She said that I would need to get a "certified BMW diagnosis" (from a certified dealer, at my cost) before they could go forward with any resolution investigation.
I"ll go back to my dealer about this, but I am wondering if this is Standard Operating Procedure (they certainly don't want to just take my word for it), or if this is a stall.
Edit: took bike in; they will take a look, then file a "puma" (not sure of spelling). I'll pass it's ref# to the Resolution Specialist and we'll go from there.
Thanks,
-ceej
1200gsceej screwed with this post 12-19-2012 at 08:10 PM
Old 12-19-2012, 04:53 PM   #133
JimVonBaden
"Cool" Aid!
Oddometer: 52,905
Both flanges on my new (to me) R1200GS are cracked. I'm going with the BBY flange clamps and metal QDs.
Jim
Old 12-20-2012, 11:11 AM   #134
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,041
Jim
I'll be interested to hear (see?) how it goes. I expect that this winter I will get around to looking at mine and will not be pleased by what I see.
Old 12-20-2012, 03:22 PM   #135
tank slappa
Let's just ride!
tank slappa's Avatar
Oddometer: 90
Can cheap hose clamps provide the same support as the $35 clamp from BBY?
tank slappa is offline   Reply With Quote
Times are GMT -7.   It's 11:00 AM.
