Go Back   ADVrider > Riding > Regional Forums > Tejas and the Gulf States
Old 05-12-2013, 06:47 AM   #811
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,850
Originally Posted by RoyQ View Post
They look the business if nothing else
That's all that really matters, right?
Thanks for the write up. I mount my tires with tire irons, so I'm thinking I would not attempt these.
Anticyclone is offline   Reply With Quote
Old 05-12-2013, 07:14 AM   #812
RoyQ
RoyQ's Avatar
Oddometer: 2,218
Surprising the front was no easier than the rear to mount. With irons you would do serious damage to a wheel mounting these things. I have mounted a truck load of race tires which are known for stiff sidewalls but these things topped any of those. I am not sure what perssure I should be running currently investigating that. Lower pressure made them feel better on pavement verses S10 recommended pressures.
2012 YAMAHA Super Ténéré
'11 GSXR750
'11 GSXR1000 racebike
WERA Expert #826
RoyQ is online now   Reply With Quote
Old 05-22-2013, 06:04 PM   #813
RoyQ
RoyQ's Avatar
Oddometer: 2,218
More Tenere upgrades
Penske rear shock and it was due!! Stocker just was not good enough for much of anything.
'11 GSXR750
WERA Expert #826
Old 05-22-2013, 07:28 PM   #814
OTRATT
On The Road All The Time
Oddometer: 178
K60
Got over 8k on my K60's now. Rear is getting a good flat spot, but still alot of tread on it and the front is getting a little more vibey. They are a bitch to get on but will definitely get another set.
OTRATT is offline   Reply With Quote
Old 05-25-2013, 01:06 PM   #815
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,735
New farkles: Triumph Tall Windshield, Twisted Throttle GPS mount over dash (moved from handlebar), Triumph Centerstand.... and a good scrubbing!
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 05-26-2013, 08:40 AM   #816
Trophy1298
Vicarious Cowboy
Trophy1298's Avatar
Oddometer: 5,512
Looking good BW. Have you had the Tiger a year already? Annual bath time came fast.
I'll be back....
Trophy1298 is offline   Reply With Quote
Old 05-26-2013, 09:06 AM   #817
backwoodsKLR
Oddometer: 9,735
Will hit 6000 miles this afternoon. Had it since November.
2013 Tiger 800XC
Old 05-31-2013, 06:06 AM   #818
carabnsol
should have been a cowboy
carabnsol's Avatar
Oddometer: 2,167
Nothing exciting but new chain and sprockets really smooth out the ride. This was my first rivet master link. With the right tool, no problem!
Mommas don't let your cowboys grow up to be babies
carabnsol is online now   Reply With Quote
Old 05-31-2013, 08:23 AM   #819
Supahflid OP
Wheelieless
Oddometer: 3,795
I need to do the same soon. What chain breaker do you have?
Supahflid is offline   Reply With Quote
Old 05-31-2013, 10:46 AM   #820
carabnsol
carabnsol's Avatar
Oddometer: 2,167
I borrowed my brother's... It's a Motion Pro. It seemed to work well. Of course I didn't really have anything to compare it to since I had never done a rivet link before. I feel sure he wouldn't mind you using it.
Old 05-31-2013, 11:19 AM   #821
tslaw
aged n00b
tslaw's Avatar
Oddometer: 2,653
Remember to dremel the flared part of the rivit before pushing it out or you might bend the pin in the tool - motion pro will send you a new one though :)
tslaw is offline   Reply With Quote
Old 05-31-2013, 11:20 AM   #822
Supahflid OP
Wheelieless
Oddometer: 3,795
I appreciate that. I may ask when I get ready!
Old 05-31-2013, 11:27 AM   #823
carabnsol
carabnsol's Avatar
Oddometer: 2,167
I believe that was a lesson learned the hard way
Old 05-31-2013, 11:32 AM   #824
tslaw
aged n00b
tslaw's Avatar
Oddometer: 2,653
yep - wasn't smart enough to figure that out on my own and it wasn't in the directions. Very easy if you grind off the flare.
Old 05-31-2013, 01:45 PM   #825
MSrider
Rebel with a sixfiddy
MSrider's Avatar
Oddometer: 4,275
Laugh You're ruthless
In the tslaw's defense, seems the press pins supplied in the MP chain breaker kit will break at any given time, whether you grind the pin flush or not.
FWIW, I've never broken one, but have seen several people break them even after grinding the ML pins. The JUNK steel they use is weak and isn't tempered well at all. They send out replacements quite often, seems like they could use a bit closer QC.
I picked up one from Cycle Gear for $30 shipped. Similar to MPs design. Haven't broken it yet
knock on wood
KOKA
MSrider screwed with this post 05-31-2013 at 02:07 PM
MSrider is offline   Reply With Quote
Times are GMT -7.   It's 11:44 AM.
