Old 10-20-2012, 09:37 AM   #76
jm65
jm65's Avatar
Oddometer: 177
hi guys
do you know if the mount bracket "rotopax tank"is compatible with the "kolpin tank"(1.5Gal) ?
Kolpin
Uploaded with ImageShack.us
Rotopax
Thanks in advance
jm65 is offline   Reply With Quote
Old 03-29-2013, 07:24 AM   #77
mechanical
Oddometer: 96
I cut the side plates out of 3/16" 5052-H36 aluminum to mount the Rotopax cans to the racks. I bobbed the corners of the plates so I can still mount wolfman soft bags over the gas cans.
Cut out on laser
The plates just cover the center line of the tubing for the pannier racks. They are held in place with the top halves of 1/2" hydraulic hose retainers. The clamps are built out of polyethylene with a stainless steel backing plate. These are much stronger than conduit clamps, and if I ever break one I can just turn the clamp 180 deg and use the other side. I'm not sure where we get these things, but I would guess your local John Deere / Case dealer may have some. I also cut out a few spacers to ensure the clamps would be properly aligned.
Clamp Assembly
Plates fit pretty well
Bolted on the Rotopax mounts
I still need to find some rubber feet to protect the cans from rubbing the bolt heads/plates. But other than that, this should work pretty well.
mechanical screwed with this post 03-29-2013 at 03:10 PM
mechanical is offline   Reply With Quote
Old 03-29-2013, 08:43 AM   #78
John_L
Oddometer: 527
Nice work. Any chance of a pic from the rear with the bags on?
Also, did you make that clamp setup or buy it somewhere?
cheers
John_L is offline   Reply With Quote
Old 03-29-2013, 10:02 AM   #79
mechanical
Oddometer: 96
cheers
"They are held in place with the top halves of 1/2" hydraulic hose retainers. The clamps are built out of polyethylene with a stainless steel backing plate. These are much stronger than conduit clamps, and if I ever break one I can just turn the clamp 180 deg and use the other side. I'm not sure where we get these things, but I would guess your local John Deere / Case dealer may have some."
Old 03-29-2013, 11:52 AM   #80
John_L
Oddometer: 527
cool, thanks for the info.
Old 03-29-2013, 11:57 AM   #81
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 736
Any industrial plumbing supplier has the pipe clams in many sizes and configurations they are quite common just not at Lowes or Home Depot..
They are required for hydraulics and steam piping.. The come in single double triple etc..
Cheers
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 03-29-2013, 01:46 PM   #82
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 518
Can you help a guy out that can't find those clamps?
I searched but found no clamps like that. And those clamps look good too.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 03-29-2013, 02:05 PM   #83
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
Great ideas!. Agree that the gobies are too wide for back country expedition. Slim & trim is the way to go.
Mechanical- very -nice- work. I would buy a set of those from you if you had the inclination to make some up. Or send a drawing.....
Wondering how the giant loop coyote or great basin or similar would work along with that set up.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 screwed with this post 03-29-2013 at 02:13 PM
ABuck99 is offline   Reply With Quote
Old 03-29-2013, 02:19 PM   #84
Supahflid
Wheelieless
Oddometer: 3,705
Rotopax on Wolfman racks:
With saddlebags not completely installed:
Supahflid is offline   Reply With Quote
Old 03-29-2013, 02:40 PM   #85
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
Supah- We can tell which bike gets all the attention, that LC8 looks cleaner than the hog. Show that harley some love- its even asking to be cleaned...
Old 03-29-2013, 03:49 PM   #86
Supahflid
Wheelieless
Oddometer: 3,705
:grin. I know. I just bought a battery for that pig. It's been sitting there leaking oil for a year.
Old 05-01-2013, 08:54 PM   #87
beergut
Thumper
beergut's Avatar
Oddometer: 426
Lots of inmates have asked and the product is being delivered.
Rotopax mounts for the KTM 950/990
http://advrider.com/forums/showthread.php?t=883775
My KLR
DIY rear top rack
beergut is offline   Reply With Quote
Old 05-03-2013, 02:53 PM   #88
mechanical
Oddometer: 96
A few more pictures of the setup, fully loaded.
Old 05-04-2013, 08:55 AM   #89
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,513
Here's how I mounted Rotopax cans on my 990 -
http://advrider.com/forums/showthread.php?t=795348
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 05-04-2013, 09:13 AM   #90
beergut
Thumper
beergut's Avatar
Oddometer: 426
Looks like a solution, but that is a lot of weight up high!
In my opinion, I like the bulk of my weight to be as low as possible. The bike is designed in the same fashion.
Sent from my iPad using Tapatalk
My KLR
DIY rear top rack
Times are GMT -7.   It's 02:00 PM.
