Old 05-31-2013, 12:51 PM   #106
liftedlimo
PNW Stump Jumper
liftedlimo's Avatar
Oddometer: 66
Who is this inmate?
'12 KTM 990 Adventure
'12 Yamaha Wr450F
'08 Can-Am Ds450X
'05 BMWDakar(sold)
liftedlimo is offline   Reply With Quote
Old 08-10-2013, 01:11 AM   #107
MudratinOz
Adventurer in training
MudratinOz's Avatar
Oddometer: 913
I'm about to follow the lead of others here and mount two 2 gallon Rotopax to the ktm racks.
but I wonder if anyone (apart from me) has considered plumbing them into the fuel tank crossover tube.??
Similar to a nomad rear tank.
KTM 2012 990 ADV ABS - BLUE
The orange does grow on you. You will not notice it at first..but it starts with a few innocent KTM stickers,.progresses to a KTM key ring, to KTM coffee mug and next thing you know, you have gone completely mad and start wearing orange tee shirts.It is a very bad infection..is this yeast infection (Bronx)
MudratinOz is online now   Reply With Quote
Old 08-10-2013, 01:36 AM   #108
corsaire1773
World Pirate
corsaire1773's Avatar
Oddometer: 4
Hello on the French KTM Adventure someone did something little bit similar.
The extra tankers were the ACERBIS one
They were fixed on the front crash bar ( both side)
And connected to the KTM main tanker ( probably connected to the pump)
But one day the guy felled and the KTM burned..
Here a thread that can help you .. the guy build an extra tanker and fixed a mikuni pump .. it is all in French
Below some pic I found that show the rotopax fixed on support
http://ktmadventure.asiafreeforum.co...ight=reservoir
corsaire1773 is offline   Reply With Quote
Old 08-10-2013, 06:19 AM   #109
beergut
Thumper
beergut's Avatar
Oddometer: 414
Whoa! Sounds like an awesome idea!
Also, the inmate who cuts these for me is off the grid for about another 10 days. I am not keeping a 'inventory' so they are cut to order.
My KLR
beergut is offline   Reply With Quote
Old 08-10-2013, 06:22 AM   #110
beergut
Thumper
beergut's Avatar
Oddometer: 414
Also, I have a DIY top rack which can also fit a rotopax on a ktm (or any other bike) perfectly. To get an idea of the size, they are the same size as a medium flat rate USPS box.
I have a few ready to go. (I bought a qty of these and still have a few left)
http://www.advrider.com/forums/showthread.php?t=894973
My KLR
Old 12-31-2013, 06:06 PM   #111
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Sold the 990 Adv and got an 1190 Adv R. Decided to keep the rotopax tanks and boxes. Drilled the stock rack as a start. Maybe we need another thread.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 01-16-2014, 12:16 PM   #112
WhicheverAnyWayCan
Deaf Biker
WhicheverAnyWayCan's Avatar
Oddometer: 915
Originally Posted by Hondo View Post
I like this idea very much and that definitely gave me idea for my sportster project because I was juggling with many different idea how to give myself extra fuel to carry on top of my 2.5 gallons. This is what I think I will go with!! (with Wolfman luggages on sides, not merriman's can.)
Originally Posted by mechanical View Post
Originally Posted by beergut View Post
Looks like a solution, but that is a lot of weight up high!
In my opinion, I like the bulk of my weight to be as low as possible. The bike is designed in the same fashion.
Beergut, I assume you are thinking of similar thing what Mechanical posted?? Maybe it is decent if you are in the USA or off-roading.. but when traveling outside USA where you can split lane and get through traffic to front of stop light.. forget it! Too wide to weave around.. You will appreciate Hondo's work assuming you use wolfman luggages or smaller panniers.
WhicheverAnyWayCan is offline   Reply With Quote
Old 01-16-2014, 01:05 PM   #113
superhak31
superhak31's Avatar
Oddometer: 91
Originally Posted by HickOnACrick View Post
I hate to be a buzz-killer, but if you do any serious off-roading, I am afraid the bracket for the Rotopax will put too much stress on the cutting board and will eventually fail. Adding fender washers may help with lateral loads, but the vertical forces, especially with 2 Rotopax, will be significant. It may be worth using compression straps to strap the Rotopax to the rack, just in case it fails. In that way, your ruck doesn't wind up lost in a desert, or worse, in the wheel of your riding buddy.
In addition, having used those rubber hose clamps before, I can attest that they do not hold up well to the rigors of off-road riding.
Sorry, dude. A very creative solution, but I am afraid that you are setting yourself up for a yard sale
+1
superhak31 is offline   Reply With Quote
Old 01-21-2014, 02:17 PM   #114
Alleycatdad OP
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
16k miles later I replaced the cutting boards with aluminum. No wear or cracks were apparent in any part of the system, it just seemed like time....
Sa
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 01-21-2014, 04:25 PM   #115
turdfergeson
Oddometer: 40
Busted Sub Frame
I broke both sides of my sub frame (thank you KTM warranty) with only a front tube and pair of tire irons in my knockoff brand pelican case, and the 2 gal Rotopax(full) on top of the case.
This was my setup all because I was too cheap to get the Giant Loop Coyote saddlebag, which I've since purchased. So now, ideally, the Rotopax will be the only thing attached to the rear rack. I'm toying with the idea of removing the case handle and re-installing the Rotopax mount so that it sits vertical, with the Coyote bag sitting against it.
[IMG]
photo sharing[/IMG]
upload
[IMG]
screen shot on pc[/IMG]
[IMG]
image upload no compression[/IMG]
2013 990 Adv Baja
turdfergeson is offline   Reply With Quote
Old 01-21-2014, 07:01 PM   #116
PS-RagE
PS-RagE's Avatar
Oddometer: 648
http://www.cs.trinity.edu/~jhowland/1190-rotopax.jpg
Same here. Working on a design now to use the "negative space" on the shifter side.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
PS-RagE is offline   Reply With Quote
Old 01-22-2014, 12:49 PM   #117
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,047
I'lll just leave this here...
Kriega Overlander ADV Platforms / Overlander 60. Fits KTM PowerParts or standard shaped Touratech pannier racks on all models, including the 9X0.
Cheers,
Michael
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 03-12-2014, 09:38 PM   #118
rallyman99
Let's do it!
Oddometer: 4
Wolfman bags over Rotopax for KTM
A few more pictures of the setup, fully loaded.
Mechanical, do you mind if I ask how much it cost for the aluminum, laser cutting, and custom mounting stuff? I have the identical Wolfman bag setup and was thinking of doing the same thing. Nice to know someone else has already done it!
Also, what size are those gas cans? I'm looking at the 2 gallon but not sure that the pannier mounting straps will reach around...
Thanks in advance!
rallyman99 is offline   Reply With Quote
Old 03-13-2014, 03:15 AM   #119
corsa996
Oddometer: 34
Rotapax
Nice setup,
corsa996 is offline   Reply With Quote
Old 03-14-2014, 06:27 PM   #120
Tomah
Riding the Northeast
Tomah's Avatar
Oddometer: 215
Anybody sell these commercially?
TOMAH
KTM 990 Adventure-R
Tomah is offline   Reply With Quote
Times are GMT -7.   It's 06:34 AM.
