08-08-2011, 08:47 AM
#1 |
Oddometer: 19
front brakes squeak loudly at full stop
I have an 07 Yamaha WR450F. I noticed Saturday that the front breaks let out a pretty loud noise when you apply them to a full stop. They're quite until right when the bike stops, then as they grab the rotor it makes a pretty loud noise. Does anyone know how to correct this?
All the break components are in great shape, this is more of just a friction issue. I'm not sure why the front breaks make this noise and the rear brakes don't. |
08-08-2011, 04:03 PM
#2 | |
Easily trainable
Remove the caliper
remove the pads scrub the pads with a toothbrush and brake cleaner clean the rotor with brake cleaner Reassemble Done.
08-08-2011, 04:41 PM
#3 |
Oddometer: 1,832
WD40?
no sorry but a friend really did exactly that and wondered, why his brakes did o longer brake |
08-09-2011, 03:30 AM
#4 |
CDI REPAIR
Oddometer: 3,337
I sand the pad friction material with sandpaper to clean them up,,,,,,,then use Synthetic Brake lube(made for caliper slides) on the back of the pads that contact the caliper,,the noise is caused by the pads vibrating against the caliper piston and front pad holder......i`ve done this on cars/bikes for 25 years in the garage,works great,no squeel
![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
08-09-2011, 08:44 AM
#5 |
Oddometer: 339
as techforlife, also for sanding the pads use something flat as a base, not your leg, hand or the gravel outside
but also make sure the anti rattle springs aren't missing, often thats the real cause. Also if its a floating style disc make sure its not rattling about to much, this can cause a squeal when coming to a full stop.
1984 Honda CBX 750 FE 1985 Honda VF 750 F 1987 Honda CBR 1000 F 1988 Honda CB 350 SG |
08-09-2011, 06:17 PM
#6 |
Yinzer
Oddometer: 1,209
