Old 08-11-2011, 08:18 AM   #1
troyslegacy OP
PigGS Feet
troyslegacy's Avatar
Oddometer: 134
Shorai Battery review on my 2008 R1200GS
Recently I picked up a new LFX14A1-BS12 from Shorai Battery Company. I have one of their batteries on my 2006 CRF450X. It has been awesome and weighs about a pound compared to the six or so for the original. Significant weight savings on such a small bike. The battery started strong every time, always spinning the starter and firing right up. I have run the bike from the mountains of Arizona to North Carolina and have had no issues.
I was in the market for a new battery for my 08 GS and decided that with the great results I had on the CRF that I would pick one up for my GS, and save some weight while I was at it. I went to the shorai website, punched in my bike type and was given two options. A standard and a duration model. Shorai claims that their batteries CCA are rated more accurately then that of AGM or standard lead-acid batteries. I have a regular GS, minimal electrical farkles (GPS, heated gear in the winter) and decided that the standard was good enough. Big effin mistake.
After installing the battery I attempted to start the bike (click…click…ok, wait a second). The next time I hit the starter it turned the starter over, but struggled and acted like the battery was weak. It has done this constantly since then, first it will click, and then it will sluggishly turn over. Obviously this battery is far too under-powered for this bike. I will be contacting Shorai, unfortunately I cannot ship it back right now as the bike is in storage and I am in Afghanistan. I just wanted to let everyone know to stay away from this specific battery for this bike. The more powerful one is probably fine, but the standard recommendation is under-powered.
Other than that the weight savings, reliability, and discharge rates were the selling points for me.
troyslegacy is offline   Reply With Quote
Old 08-11-2011, 08:26 AM   #2
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,675
Try one of these, http://www.racetech.com/HTML_FILES/L...ngBattery.html, it will start a full size Mercedes. It's also honestly rated at 4.6 amp hours, not some sort of made up equivalence. It also has built in battery management hardware to balance the cells. It's lithium nano phosphate, A123 cells.
Let me add a disclosure, I know the manufacturer. The reason I evangelicize his product is because I've seen what they can do.
Here it is starting my Mercedes 420SEL.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 08-11-2011, 10:45 AM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,490
Did you charge it first?
These are in a growing number of bikes without this issue. Maybe yours is defective?
Jim
Old 08-11-2011, 02:49 PM   #4
PETDOC
User Awaiting Email Confirmation
Oddometer: 1,212
I just put the Shorai battery in my '04 1150 GS. I had purchased the Shorai battery charger and charged the battery. I then disconnected the charger and the voltage settled at 13.35. The bike sat for about a week and the voltage dropped about 0.01 volts/day. This seems to match with their comment that riding the bike for a couple of hours once a month will keep the battery adequately charged (i.e., >13.00 volts). With the resting voltage sitting at 13.29 I started the bike without difficulty and rode it for about 5 miles. When I stopped the voltage again settled at 13.35.
I'll post which battery I purchased after I go look at the box.
OK! So I purchased the LFX18L1-BS12
PETDOC screwed with this post 08-11-2011 at 04:47 PM
PETDOC is offline   Reply With Quote
Old 08-11-2011, 03:54 PM   #5
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,674
I ordered the smaller of the two Shorai batteries and was disappointed with its performance on my '11 GS. I put that battery in my Ducati Streetfighter (works perfectly, also the recommended size) and ordered the stronger one for the GS and it too works perfectly.
Very happy with both, but the GS definitely requires the higher cca version between the two.
2016 Aprilia Tuono Factory | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is online now   Reply With Quote
Old 08-13-2011, 05:37 AM   #6
BoatDoc
BoatDoc's Avatar
Oddometer: 34
Thanks for sharing this with us, very useful! I'm on my fourth battery for my '08 gs and can relate. The OEM lasted nearly 3 years, then I went through two Yuasa "high capacity" batteries in 7 months. Both gave the same "click-click" after about two months. No amount of consulting from Yuasa or the battery seller would address it and they eventually gave me a partial refund. The second finally refused to start right outside a BMW dealer (coincidence?), so I put another OEM in ($ ouch) and it works just fine. I've been using the Shorai 6v in other projects for about six months and find them great, but wouldn't be surprised if what the gs/gsa needs is more than the minimum specified.
_______________________________
The solution to global warming is nuclear winter.
2008 R12gs, 1966 R27
2008 TAT trip
BoatDoc is offline   Reply With Quote
Old 08-14-2011, 09:10 AM   #7
troyslegacy OP
PigGS Feet
Oddometer: 134
Jim
Jim,
It was charged before I installed it. I am going to contact Shorai and recommend to them that the bigger battery be the "standard" recommendation. Hopefully I can get a partial refund on mine when I get back from Afghanistan in October. The battery on my CRF450X discharges extremely slowly, then again the stock AGM battery has lasted without charge on my GS for months in storage as well. It's just frustrating to spend that much and have it end up being under-powered.
Old 08-15-2011, 12:43 PM   #8
J Lewis
Numb Nuts
J Lewis's Avatar
Oddometer: 510
I had the same issue on my 12 GSA and found this on the Shorai web page and have found the second crank works after the warming takes place.
Q. I hear that lithium crank poorly when it gets cold, is that right?A.Lithium do increase in resistance more as temperature drops, compared to lead-acid. However, they also react to cranking under cold conditions in a much better way. Lead-acid will increase resistance on each subsequent cranking attempt, until it won’t turn over. If your LFX fails to start the engine on first crank, that first crank has warmed the battery, and the second attempt will be much stronger, and so on until you get a good start.
Shorai LFX are much better in cold-weather conditions than other-brand lithium starter batteries, due to our eXtreme-rate formulation with low resistance. Down to about 20 degrees fahrenheit (-7C) most users find that they can start normally on first crank. If your headlight comes on at key-ON, it is good for the batteries to flow some current before cranking in cold weather. The suggested headlight-on time before cranking depends on the temperature. If starting at 40f (5C), 30 seconds will help wake the battery and increase cranking performance. If at 0f (-17C), leave the lights on for 4~5 minutes before cranking. The result will be a better first crank, and longer battery life. Any other accessories that can be turned on before cranking can also be used for this purpose, such as heated gear, radio, etc...
J Lewis is offline   Reply With Quote
Old 08-15-2011, 04:30 PM   #9
PETDOC
Oddometer: 1,212
The list on Shorai batteries I consulted before purchasing one for my 1150 GS indicated that the 18 amp battery (LFX18L1-BS12) is the one. I looked at my deceased OEM Exide Gel battery and the Panasonic AGM which followed the Exide battery; they are rated at 19 and 20 amps, respectively. I'm not sure how a 14 amp Shorai got in the mix. Does someone have a Shorai recommendation for the 14 amp battery for the GS?
Old 08-17-2011, 03:30 AM   #10
troyslegacy OP
PigGS Feet
Oddometer: 134
It is the same for me regardless of how warm or cold the bike is. It is just plain underpowered. Shorai isn't responding to my emails regarding this battery. I won't be buying from them again.
Old 08-17-2011, 02:43 PM   #11
PETDOC
Oddometer: 1,212
Interesting, when I went to the site (http://www.epmperf.com/shorai.html) I used to identify the correct Shorai for my 1150 GS and typed in a 1200 GS it does recommend the 14 amp battery vs the 18 amp for the 1150.
What is the amp rating on the OEM battery in the 1200 GS?
Old 08-17-2011, 03:39 PM   #12
SCflyer
SCflyer's Avatar
Oddometer: 1,657
I have the 18amp in my 09 GSA and no problems. The info. stated to get the 18amp if you have the accessories to run when the bike is off and I generally get the max available anyway. Also had some percieved problems but ended up being my fault but they still covered a battery under warranty. I can't speak to the the 14amp but understand the dissapointment since that's a recommend on the site. During my head scratching electrical problem I called them and was able to speak to someone each time so try that unless the email was ur only option. If you can call I think David was one of the managers I spoke to. TOLL FREE: 888-477-4848
Just spoke to them on another question, asked about this concern and the rep said they were going to be changing the recommendation to the larger as the primary option but still call them maybe they'll help.
They seemed nice and were helpful.
Good luck
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer screwed with this post 08-17-2011 at 04:17 PM
SCflyer is offline   Reply With Quote
Old 08-17-2011, 04:45 PM   #13
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,675
The Shorai amp rating is some arbitrary number that isn't a good comparison with lead acid ampere hour. Read this from the Shorai faq, the red portions.
Lead-acid makers have therefore used AHr(capacity) ratings as shorthand to indicate cranking ability, rather than a real usable capacity. The lead-acid capacity rating itself is based on a complete discharge at a low discharge rate. Under actual cranking conditions they will deliver considerably less than spec capacity. And because lead-acid batteries begin sulfating when only a small percentage of the capacity has been used, and their internal resistance rises as they are discharged, the actual capacity which can be USED may be as little as 20% of the mfg. rating. Discharge in excess will not only damage the lead-acid battery, it may not allow proper starting as voltage sags.
Cranking ability is rated in cold cranking amps or cranking amps. Amp hours is a measure of the energy capacity over time.
Look what the other super battery, Odyssey, says.
Q. What is the pulse cranking amp rating?
A. Unlike CCA and MCA the pulse cranking ampere (PCA) rating does not have an "official" definition; however, we believe that for true engine start purposes, a 30 second discharge is unrealistic. With that in mind, the PCA is a very short duration (typically about 3 seconds) high rate discharge. Because the discharge is for such a short time, it is more like a pulse.
Watch the video of the Lightning starting my Mercedes, no warmup needed and that's at 4.6 amp hours.
Old 10-27-2011, 07:03 PM   #14
Strange Rider
Oddometer: 5
When the 1200GS came out, apparently BMW was trying to cut so much weight from the 1150 that they skimped on battery size to save weight. The battery was underpowered, which is why the stock 1200GS batteries don't crank well. Shorai probably used the stock specs as a reference of appropriate battery size, without actually testing it's capability on the 12GS. Use the larger 18A Shorai and you will probably be fine, and also save much more weight than bmw ever could at the time.
Strange Rider is offline   Reply With Quote
Old 10-16-2012, 06:13 AM   #15
MizzouRider
MizzouRider's Avatar
Oddometer: 1,800
I know this is a old thread, but I was checking to see if anyone was having trouble with the Shorai Battery?
My OEM battery on my 08GSA died this weekend, I was at the falling leaf rally in Missouri, and the Gateway BMW shop was selling these.. ($200 ouch!)
They only had one that would fit a 1150, but I made it work on the 1200.. (the poles were reversed)
So, now I have one.. Hope they are working well. I did get the 21 or 23 amp one.. Sorry, Sr moment.. So I'm hoping it's got enough power.. Did anyone buy the special charger/tender for it? Not sure how much that will be, but I want to get a long life out of a $200 battery.
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Times are GMT -7.   It's 05:46 AM.
