Go Back   ADVrider > Riding > Epic Ride Reports
Old 09-18-2011, 09:23 AM   #211
blaster11 OP
Where to go......
blaster11's Avatar
Oddometer: 7,158
Gros Morne Back Country Aborted Route
This track was nice, but did have a few obstacles. We would have crossed the river, assuming we had knowledge that the trail was not going to degrade any further.
Attached is the "aborted" section of the GPX file.
For more information, on condition see day 12 in post 122 of this RR.
blaster11 screwed with this post 09-18-2011 at 10:27 AM
blaster11 is offline   Reply With Quote
Old 09-18-2011, 09:24 AM   #212
blaster11 OP
Where to go......
blaster11's Avatar
Oddometer: 7,158
Gros Morne As Rode
Gros Morne As Rode
blaster11 screwed with this post 09-18-2011 at 10:03 AM
Old 09-18-2011, 09:24 AM   #213
blaster11 OP
Where to go......
blaster11's Avatar
Oddometer: 7,158
Gros Morne as planned
blaster11 screwed with this post 09-18-2011 at 10:02 AM
Old 09-18-2011, 12:38 PM   #214
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,637
Originally Posted by blaster11 View Post
There are 10 parts of the GPX as ridden. It has been cleaned up of extraneous u-turns, however is largely original. It has been separated into 10 files, to meet the upload requirement of <1.9M.
thanks!
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
2014 Yamaha FZ-09 Adventure
Kyler screwed with this post 09-18-2011 at 12:52 PM
Kyler is offline   Reply With Quote
Old 09-18-2011, 12:42 PM   #215
blaster11 OP
Where to go......
blaster11's Avatar
Oddometer: 7,158
Originally Posted by FWIW View Post
thanks! Is it safe to assume they are roughly 1-day ride each?
Negative. The file breaks are not based on days, rather sized for uploading. Our trip was 22 days, with only a few short days, and 1 non-riding day.
Old 09-18-2011, 01:10 PM   #216
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,637
cool - I wish I could take 3-weeks off but our trip will be shortened to 2-weeks. About a year from now, Boothdoc and I'll buy you copius quantities of beer and pic your brains.
Old 09-18-2011, 03:48 PM   #217
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 834
Bruce
I did that same Goose arm road out of Deer Lake up over the Mountain and came out in Conor Brook.
wow great minds think alike.
I went around the bridge that is washed out, after you go pass the feild with the Horses (well, there were horsse in it when I went pass on thrusday)
anyway, when I back tracked back to that bridge there was a lot more water to deal with and then going south towards Conor Brook the trail closed up and had to go futher east to get threw.
that was one of the best days of the trip.
there are more trails and logging roads from Conor Brook down to Stevenville but I was running out of time and want to get down to ferry befor it got dark
I am in Wallace NS.now
I had a couple down days staying at my cousin cottage, did some maitains and laundry on sat, and did some more trail riding today around here, there is a trail rail from Picto threw Oxbow ( near Springhill) that is a nice option to the trans-can aswell.
leave early for Boston in am, back to work
get out and live
sailer is offline   Reply With Quote
Old 09-22-2011, 05:35 AM   #218
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
thanks for those files, I'll try to get out that way to look more closely next year. Due to the hurricane last Friday canceling too many ferries I ran out of time and booked it back to PAB and across Maine to Montreal so I could make the airport this am. 3rd try to run the TLH this year foiled
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 10-24-2011, 07:40 AM   #219
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,742
Tire choice
Bruce, Dana, Lance, et al.....
Would you mind posting what tire/tire combination everyone was running?
I'd also like to know how well (or not well) whatever combination you chose worked; what particular fault the combination may have had; whether you'd use the same combination for the CDT; whether you would recommend whatever combination you used. In other words, what works and what doesn't.
We are trying to come up with a combination for Alaska that will work and if we can comfortably do the trip without a tire change (doubtful - too much hard road).
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 10-24-2011, 11:56 AM   #220
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
Dunlop 908 rear 606 front, the front was badly ramped after 4500 km's and the 908 lasted 7500 km's and could have gone further. 99% pavement, 2000 2up. Great combo on my 640, will run it again for sure. Make sure you have at least 3 tire irons
Beerthief
Old 10-24-2011, 03:20 PM   #221
blaster11 OP
Where to go......
blaster11's Avatar
Oddometer: 7,158
Mike,
The Heideneau tires are a good 50/50 tire which should get you about 10K miles, but be forewarned they are not mud tires. We ran a TKC on the front and a K60 Heidi on the back and probably could of gotten several thousand
more miles out of the combination on the TLH trip. I would run that combination again, and may run it on the Continental Divide adventure. I may run street tires like Anakees or Tourances out to the beginning and then prior to starting the CD section change over to the TKC/K60 combo for the CD and ride home...time will tell. I hope this helps.
Old 10-24-2011, 08:35 PM   #222
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,742
Thanks Bruce.
Can you think of a better rear tire than the Heidenau K-60?
Did you come across any slurry (maybe a bad name) - but it results from finely ground gravel - not quite sand - that when wet makes for a very slippery surface. We occasionally see it around here and it is almost as slippery as mud but not as bad as wet clay.
Mike -
Old 10-25-2011, 02:16 AM   #223
blaster11 OP
Where to go......
blaster11's Avatar
Oddometer: 7,158
Originally Posted by 6USMC6 View Post
Thanks Bruce.
Nothing wet, our trip was amazingly dry but the gravel went from large size gravel to marble like on a hard surface, I think we saw most of the conditions for gravel.
The problem with tires is that all conditions are different and each tire has its strong point, K60's in my opinion have a weak spot with mud. My opinion is that on big trips mileage is a big factor which by default makes the tire weak in another area....like mud. The TKC front K60 rear is a strong combination considering I did 5800 miles with 1500+ of it gravel and still had tire left when I got home....it was good piece of mind not having to worry about tires.
Old 10-25-2011, 08:16 AM   #224
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,742
Thanks, I was thinking along those same lines, unfortunately, Alaska will require at least one tire change and I am wondering if I should simply run a street tire combo until we get there and then just change to a full set of knobbies or to go with the K-60/TKC combo all the way with a replacement in kind at some point.
BTW, I will start an Alaska thread shortly and I'll post the link to the SMIB thread.
Mike -
Old 04-18-2012, 05:10 AM   #225
REAPER_ONE
YOU'RE DONE
REAPER_ONE's Avatar
Oddometer: 3,215
I would run Michelin Pilot 2 to the dirt and Karoo Traveler on the dirt.
REAPER_ONE is offline   Reply With Quote
Times are GMT -7.   It's 02:47 PM.
