Old 03-09-2005, 12:03 PM   #1
Drif10 OP
Accredited Jackass
Drif10's Avatar
Oddometer: 46,705
Goddamn bearing help
So I'm changing out the LC4 mainshaft bearing. Much head banging, I finally get it out. Put in the new bearing, and now the shaft is very hard to turn. According to the KTMTalk thread, one guy had this problem, used the basket as a slide hammer back against the nut, and it spun free.
Wanna guess what isn't working for me? I wish this was JM, I need to SCREAM!!!
Any ideas guys?
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 03-09-2005, 02:09 PM   #2
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
Any ideas guys?
Hi Drif,
After installing the new bearing, you have to give the schaft a good blow with a plastic hammer.
I was told to do that by two different KTM Dealerships, so I did and "tara" works perfectly.
Did it now on two engines
Go for it kick it
extreme bearing make over
cheers
Stefan
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe is offline   Reply With Quote
Old 03-09-2005, 02:23 PM   #3
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,076
Drif, I am not looking forward to this. I going to do mine in the next few months. Sounds like your about there. Have a beer, take a deep breath and count to 53.
Happe, Looked at your pic. What did you use as a bearing puller? Thanks.
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 03-09-2005, 02:27 PM   #4
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
why can't anyone get a bearing shop to do this? i had an old fashioned shop do the bearings on the steering column of the 65 ford f100 i used to ride and it was CHEAP. plus i didnt have to get the ford part (if it was even available anymore.
just a thought; might be hard with it being on the bike but who knows?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-09-2005, 02:39 PM   #5
Drif10 OP
Accredited Jackass
Drif10's Avatar
Oddometer: 46,705
Originally Posted by Happe
Hi Drif,
Go for it kick it
cheers
Stefan
Cool, I'll try it. Thx.
Old 03-09-2005, 06:10 PM   #6
dagwood
dagwood's Avatar
Oddometer: 35,427
remember...the first tool was a Hammer. so when in doubt reach for the first tool. when in real dought get a bigger hammer.
I hope your documenting this as I'm gonna have to do it sometime soon also
dagwood is offline   Reply With Quote
Old 03-09-2005, 08:14 PM   #7
Drif10 OP
Accredited Jackass
Drif10's Avatar
Oddometer: 46,705
Hammer didn't work. phucke!
Next idea?
Old 03-10-2005, 01:37 AM   #8
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
Next idea?
Hi Drif,
just to get this straight.
You have pulled out the old ball bearing, put in the new roller bearing.
first the washer than the bearing than the inner ring. Now the bearing is flush with the engine chassis?
Now you tried to turn the shaft and it is going very sturdy?
While you put the new bearing in place the mainschaft may have moved a bit. Normally after a good blow on the shaft it will run free again. And I mean a good blow
If not try something in the other direction, but I wouldn't use the clutch parts.
Edit: is the engine in gear?
cheers
Stefan
Old 03-10-2005, 01:44 AM   #9
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
Dear Mr. God,
I used this one from RS Components UK, 513-720
Twin Pull Ball Bearing Puller Kit
And can you make me dick a bit longer?
cheers
Stefan
Old 03-10-2005, 03:48 AM   #10
Drif10 OP
Accredited Jackass
Drif10's Avatar
Oddometer: 46,705
Hi Drif,
cheers
Stefan
Correct on all. Tried it in and out of gear. I was wacking it pretty hard, I'll try hitting it harder, just hard to hit it flat without smacking my knuckles on something.
Old 03-10-2005, 05:27 AM   #11
meat popsicle
Ignostic
Oddometer: 14,247
do you have something suitable (material) to use as a punch? maybe an oak dowel or even a 2x4 if it will transfer yer mortal blow to the shaft. just a thought - hope it lets go...
Hi Drif,
cheers
Stefan
i don't think i could'a posted that even if i'd thought of it! that would get a laugh outa drif10 4sho.
Old 03-10-2005, 05:28 AM   #12
Drif10 OP
Accredited Jackass
Drif10's Avatar
Oddometer: 46,705
That didn't work.
How hard is it to get to the other end of the shaft? Can't see how I can pull that bearing back out now, puller won't fit.
For the longest time, I thought KTM stood for Kan't Take Motorcycle. Tempermental to start, finicky about fuel, no where near as reliable as a Honda, constant repairs, now faulty bearings and water pumps.
The more I own this bike, the less I like it. It's qualities are being outweighed by it's difficulties.
Old 03-10-2005, 05:36 AM   #13
meat popsicle
Ignostic
Oddometer: 14,247
primadonnas look good in the playground, but once you get out on a date they can really piss ya off!
Old 03-10-2005, 07:05 AM   #14
gybeman
gybeman's Avatar
Oddometer: 633
That didn't work.
For others who will try this, the last few mm's of tapping it in is when you should be checking for play and only tap it in til you get the right amount.
If you go too far, it may be time to split the cases. If you are truly fed up I'll give you $500 for the remaining junk that works.
gybeman is offline   Reply With Quote
Old 03-10-2005, 07:09 AM   #15
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,745
is the bearing loaded up from pressing it in? my bet is yes. if you pushed on the outer race to get it in give the inner race a bump with a brass drift and hammer. whack the outer if you used the inner to push.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Times are GMT -7.   It's 03:30 AM.
