Old 03-10-2005, 07:28 PM   #1
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
KTM Factory “Blueprinting”
I received the bulk of my KTM LC4 inventory on Monday from Penco in Montana, including a new ’03 to ’05 “high flow” cylinder head.
I was completely surprised to see that KTM is hand finishing these heads. They have taken the time to match and blend seats and ports, as well as deburr the combustion chamber.
Photos are of the head as it came out of the box… all I’ve done is to begin measuring things.
It is a very rough finish… not at all “pretty”, but certainly effective. Suzuki is the only other major player I am aware of that does this is, specifically on the GSXR 750 sport bike series.
It would have been nice to see what the head looked like before someone at KTM attacked it with a porting bit… but it serves as an example of a company aware of the potential for improvement and willing to put in the extra time and effort to obtain it.
There is a bit more to be had by additional blending and smoothing … I’m sure the worker that performed the task had no idea this head would land in my lap to be scrutinized, with observations posted on the internet, rather than go on to become part of a motorcycle.
There are a few sharp edges left in the combustion chamber… potential “hot spots”, as well as quite a few casting “buggers” in all the ports. The happy-go-lucky KTM employee may have gotten a little over zealous around the spark plug hole, leaving some very thin areas… I’ll have to get a spark plug and see if I have room to remove the exceedingly skinny spots without exposing the plug threads to the combustion chamber.
Also of note are the valve guide shapes in the ports. The intake guides have a nice flow-enhancing taper on them while the exhaust guides are of full diameter and are supported by the head casting almost to the end of the guide.
Part of this disparity in shape is the size of the ports themselves, the tapered guides help to improve intake air flow... and with the exhausts, to improve in heat absorption and transfer.
The new seats are fully 3-angle cut and have contact angle widths of .045” for the intake and .050” for the exhaust.
All in all, it’s nice to see that KTM puts in the extra effort, and I’m sure there is a flow improvement vs. the as-cast version… but it may take more work to “clean up” what was done than if I had done it myself.
What will happen to this head?
At some point, after I’ve dissected it as far as I can, I’ll finish what KTM started as far as blueprinting, assemble it and offer it as a premium exchange piece for 2003 to 2005 LC4s.
That's about it.
Chris
So... how's tricks?
creeper screwed with this post 03-11-2005 at 08:46 AM
creeper is offline   Reply With Quote
Old 03-10-2005, 08:10 PM   #2
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,316
I'm glad to see your having fun playing with your parts.
When the bearing went out in my transmission, I had to split the cases on my 01. I was constantly impressed with the quality and level of engineering of the LC4. Almost everything has a bearing instead of a cheap bushing, easy to work on, dual oil pumps, lightweight bolts, and more.
2013 Husky TE511
2014 KTM 350 XC-F
2006 KTM Adv 950
2001 KTM 640 LC4 Sold
I only like two kinds of women, foreign and domestic
dirtrider is offline   Reply With Quote
Old 03-10-2005, 08:30 PM   #3
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
The way I look at it, for a factory to do this kind of hand work, there has to be justification... major justification. I would love to know the difference in CFM numbers before and after.
Somebody at KTM did this to a head, tossed it on a flow bench and said "holy crap!"... showed it to someone up the food chain who said "holy crap!"... and so it went until someone at the top said "thats going into production"... all in German of course.
Relatively small companies like KTM are good for this kind of "experimental today - production tomorrow" stuff. Fewer "suits", bean counters and red tape in the way of progress.
So... how's tricks?
Old 03-10-2005, 08:56 PM   #4
Jinx
Call me Renzo
Jinx's Avatar
Oddometer: 10,838
A "bowl job" is not very time consuming. Not that it gets done much in a production environment, but Moto Guzzi was doing it 30+ years ago on the V7 Sport heads. Not the trick Telaio Rosso stuff, all of them.
It helps, but the real money is in the seats (want to find flow obstruction? Look for the highest velocity areas. Want better flow? Make the high velocity areas work better). What the bowl job does is make the heads consistent from one to the next. And if you are trying to extract performance, you need all the heads to flow the same +/- fuck-all. With precision seat/valves, and a quick and dirty bowl job, KTM has made a very consistent platform for tuners.
Best bang for the buck in head work? Really good valves and seats, a moderate bowl job, and drop the squish clearances to .035" +.005/-.000. But it is nice to see KTM cares. Now if they would quit putting 2-stroke bottom ends on their 4-stroke singles..........Cheers.
- Jinx
"You remind me of the monkey with the jerk-off button, starving to death at the switch." - Chopperman
"I didn't know how many assholes it was going to take to piss me off, but I knew how many they were going to use" - collaboratori
Jinx is offline   Reply With Quote
Old 03-10-2005, 09:20 PM   #5
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,261
I say boy, dashing good photographs! I actually was going to suggest you give us an introduction to what it is you want people to pay money for... especially since I have little exposure to high end engine work. I see that you are way ahead of me.
PS - Mack is gonna be real peeved, you flashin that beauty across his screen! That is unless it will fit on his older non-HF engine? reel them in baby!
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-10-2005, 10:14 PM   #6
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,745
what's the difference from that bad boy to the one on my '02? wonder if there's any benefit to installin a "high flow" head on an older engine.... hmmmm.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 03-10-2005, 11:00 PM   #7
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,076
Yeah, it helps ya get to Alaska quicker and lets more hot air out.
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 03-10-2005, 11:00 PM   #8
Tim
Tim's Avatar
Oddometer: 2,364
Apparently there is a benefit to be gained from having a HiFlow head on an older engine. Sommer do what they call the "red head" flow job on older heads which, they claim, takes the head to better than a stock HiFlow. Also their advice on airbox mods varies for the HiFlow - Older bike = airbox door but leave the snorkle in, whereas HiFlow = airbox door and remove snorkle.
Don't know if a stock HiFlow will bolt on to an older engine but I guess it should - shouldn't it?
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 03-11-2005, 01:20 AM   #9
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
hi KTiM,
I would go for the Sommer solution.
It is a handmade High Flow with finishing touches.
Or send your head to Mr. Creep
I think I will send the head of my spare engine to the good ol' US of A
cheers
Stefan
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe screwed with this post 03-11-2005 at 01:52 AM
Happe is offline   Reply With Quote
Old 03-11-2005, 04:04 AM   #10
Tim
Tim's Avatar
Oddometer: 2,364
Stefan,
With the current exchange rate you may even save some money by sending it to Uncle Creep! (Plus you'll get that specialAdvRider service )
Old 03-11-2005, 04:26 AM   #11
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
Stefan,
You nailed it
Old 03-11-2005, 06:04 AM   #12
wickedsprint
Oddometer: 2,386
...Either that or it had a serious casting flaw that required it be fixed by hand and inventories were short...I like your answer better though.
wickedsprint is offline   Reply With Quote
Old 03-11-2005, 06:13 AM   #13
Loadedagain
making chips
Oddometer: 26,745
and you know the special service is gonna leave stains on your clothes...
Old 03-11-2005, 06:35 AM   #14
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
I just wanna send the cyl. head, I don't wanna touch Creep *shudder*
Have you seen his avatar??
cheers
Stefan
Old 03-11-2005, 06:47 AM   #15
daotoys1
Oddometer: 1,116
I have a collection of exotic bikes...mostly Italian stuff...
TM are hand crafted off road bike and cart engine builders...all my TM 2 stroke and 4 stroke bikes come with balanced, blueprinted and polish/match ported engines...
Vertemati of which I have 5 copies, also Italian hand crafted race bikes...are also match ported and polished from the factory....
Bimota also matchports, polishes and routinely do head work on the bikes they use to build...they of course would source engines from suppliers, but they would rework the engines to thier specs before using them in thier hand assembled bikes....
Its nice to see that KTM, also a race oriented bike maker, is not cutting all corners to safe money on the mass production level of their manufacturing...
Of course, this extra time and attention to details will raise the cost of the parts, and the bikes them selves...but you end up with a better bike in the process too.....
This is oneof the reasons I personally am attracted to the Hand made Exotic vehicles...both of 2 and 4 wheeled design....you get better quality of parts, work manship and assembly....plus alot of attension to details, and billet, and sand cast alloy components.....so you get a work of art as well as a vehicle...
daotoys1 is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
