Old 05-27-2005, 05:28 AM   #46
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,872
Potatoho,
I posted 3 replies I recieved from Sommer KTM in Germany here:
http://www.advrider.com/forums/showt...ghlight=sommer
Note they did not see the benefits of a racing cam without high flow headers (Akrapovics or probably the KTM Ti supermoto headers). Maybe the SXC dual pipe setup would do it Just another piece of the pie that creeper stated.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-27-2005, 07:30 AM   #47
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,621
I've read that too. But my sprocket is on backorder, and I gotta mess with something.
potatoho is offline   Reply With Quote
Old 05-27-2005, 08:36 AM   #48
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,621
Originally Posted by creeper
Yamabond 4 is probably going to be what you want, or Three-bond brand equivalent.
Loctite 515 better? I see the RFS bulletin recommending it over the threebond sealant.
Old 05-27-2005, 09:34 AM   #49
meat popsicle
Ignostic
Oddometer: 13,872
is that stuff Thixotropic like the Permabond stuff?
http://www.homershams.co.nz/a_P_A136.htm
http://www.homershams.co.nz/a_P_HH190.htm
http://www.homershams.co.nz/a_L_515.htm
Just curious about this stuff - no gasket for better "load transmission"?
Old 05-27-2005, 09:44 AM   #50
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,621
Here's the bulletin I read: http://www.egetadeal.com/mx/tips/jeb...5_bulletin.jpg
Old 05-27-2005, 09:55 AM   #51
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,287
Holy moley Meat....
I've heard of thixotropism applied to catsup, but not Loctite....what's the application? The groundlings need to know....
Chris
'03 KTM Adventure 640
'43 BSA M20WD
ChrisC is offline   Reply With Quote
Old 05-27-2005, 10:22 AM   #52
meat popsicle
Ignostic
Oddometer: 13,872
Originally Posted by ChrisC
Holy moley Meat....
I cried too.
Thixotropic: The viscosity decreases as the shear rate increases.
there shouldn't be any shear stress in this application so that works right? it's just the thumper paint shaker that makes me wonder why this stuff doesn't liquefy and seep out?
"Permabond A136
Ready Gasket / Flange sealant
An anaerobic material designed for making ‘formed in situ’ gaskets between metal surfaces. It is capable of replacing a wide range of ‘conventional’ gaskets thereby offering potential for reduced stock holdings. By allowing surface to surface contact load transmission can be improved. As the product does not shrink, creep or relax after curing no bolt retightening is required. Its excellent chemical resistance allows its use with a wide variety of gases and liquids."
Shear Strength (MPa) 12
Maybe its not thixo after it cures...
"Permabond HH190
Anaerobic Gasket Maker
An anaerobic curing flange sealant that can replace, or be used as a dressing for, conventional pre-cut gaskets. Since the HH190 is a flowable paste, it conforms to the shape of the flange. The consistency allows metal to metal contact of the flanges while filling the areas where no contact exists because if irregularities. HH190 results in uniform stress distribution and eliminates the need for re-torquing because of stress relaxation of the flange bolts. It provides instant seal depending on the gap and flange width and ultimate seal up to 5000 psi. Because of the flexible nature of the cured polymer, HH190 has good vibration and shock resistance. HH190 provides convenience of assembly and is easy to dis-assemble as well."
VS.
Loctite 515
Shear Strength (N/mm2) 6
anyone got the conversion for millipascals to newtons per mm2?
This gets beyond me... the Permabond might be stronger but i dunno how to choose one over the other. seems like the HH190 is for filling the gaps where the standard gasket can mate with the surfaces adequately, but it also can replace gaskets. Why use a gasket anymore?
the anaerobic bit worries me; what happens if it gets oxygen?
up to 5000psi once fully cured sounds good!
did notice that all of these are only good to 150 celsius (300 farenheit)... is that good enough?
Old 05-27-2005, 10:30 AM   #53
meat popsicle
Ignostic
Oddometer: 13,872
Mebbe dis mo'betta:
http://www.homershams.co.nz/a_P_MH199.htm
http://www.homershams.co.nz/a_P_MH196.htm
"Permabond MH196
High Temperature Anaerobic Gasketmaker
Permabond MH196 is an anaerobic material designed for making formed 'in situ' gaskets between metal surfaces. Remains Flexible for impact and vibration resistance. "
Colour Red
Viscosity (mPa.s) 150,000 (Thixotropic)
Density 1.1
Handling Time 10-20 mins
Working Strength 1 hour
Full Strength 24 hours
Shear Strength (MPa) 18-13
Torque Strength (Nm)
Breakaway: 7-10
Prevail: 12-18
Gap Fill (mm) 0.5
Temp Range -55/200 °C
stop?
Old 05-27-2005, 10:32 AM   #54
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,287
So what you're saying is that if you have a thixotropic anaerobic paste, formed in situ with the stress relaxation of the flange bolts, then you will not shrink or creep until the convenience of the assembly has a reduced capacity for stock holding.
Yea, that's the ticket....now I got it
Chris
'43 BSA M20WD
Old 05-27-2005, 10:36 AM   #55
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Sounds like a Honda manual from the 60s.
creeper is offline   Reply With Quote
Old 05-27-2005, 12:52 PM   #56
meat popsicle
Ignostic
Oddometer: 13,872
yeah, i work with punchcards... or did ya forget?
chris, you lost me at the second sentence
yeah...
in situ, yeah but flange bolts add stress so i dont find this relaxing...
no shrinkage or creeping - funny how those go together
Old 05-27-2005, 02:46 PM   #57
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,621
Hopefully. I'm still a bit worried that this part may be unavailable, and I don't want to get any of the more aggressive cams.
951170 is unavailable. So I'm left with Tornado G1, which is very similar, other than costing TWICE as much. Or I can go with the MSP3 rallye cam and springs and wind up around the same cost as 951170, except with perhaps too much cam.
There are other cam options too, including getting mine welded up by webcam.
Old 05-27-2005, 03:12 PM   #58
meat popsicle
Ignostic
Oddometer: 13,872
Does it come with a cool sticker?
Old 05-27-2005, 03:14 PM   #59
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
I hear certain stickers are good for a few ponypowers.
Old 05-27-2005, 03:31 PM   #60
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,621
I can't do it! That's too much money for the same thing. And the rallye cam is sure to break me in half. So I'll keep looking for a 951170, or check if megacyclecam will make one, or buy a stocker and get it welded up by webcam.
Times are GMT -7.   It's 11:57 PM.
