Old 08-28-2011, 07:35 PM   #1
SKPY OP
Oddometer: 1
Cry V65 Help
I have a bad starter on my v65. V45 starters are everywhere, the v65 starter's seem much less available. I have a tight budget and the V45 starter are on average a third of the price. Does anyone know if there is a difference between the v45 and v65 starters? If so do you know that the difference is? Will a v45 starter work on a V65? I know some years spin the opposite way, but I found a site that gives basic specs on the starters. It seems the 1982-87 VF 700-750 (with the #MBO) have all the same mechanical specs. The only difference seems the MB4 vs MBO designation (v65 vs v45) in the part numbers. I just don't know
SKPY is offline   Reply With Quote
Old 08-28-2011, 09:01 PM   #2
Quickv4
Pro Turd Polisher
Quickv4's Avatar
Location: Dickinson, Nort' Dakohtah- Orig. from Wiscowsin
Oddometer: 550
V45 and V65 Sabre/Magna spin the same way. Interceptors spin opposite because of final drive (chain versus shaft). I am pretty sure they interchange, but would have to double check.
Jerry
____________________________
Great forum and Resource for 1st and 2nd gen Honda V4s SabMagIntercept
www.v4hondabbs.com
Quickv4 is offline   Reply With Quote
Old 08-29-2011, 01:50 AM   #3
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
Sorry, but do you know what is wrong with the starter? Is it truly dead, or can it be cleaned up, and reused?
Old 08-29-2011, 03:11 PM   #4
chammyman
Oddometer: 421
I imagine its like the rest of the 80's hondas using a derivative of the Misutba starters. I have repaired a load of them on cbr's, vf's and cbx's by using the good bits with each.
The biggest issues with them I have found are brush wear and the commutator wearing through. So just swap brush packs or the full armature between them.
Often they are choked up with carbon dust from wearing brushes which slows them down and corroded positive pin, just strip it down and clean it up.
1984 Honda CBX 750 FE
1985 Honda VF 750 F
1987 Honda CBR 1000 F
1988 Honda CB 350 SG
chammyman is online now   Reply With Quote
Old 09-06-2011, 10:35 AM   #5
Gramp-Z
Gramp-Z's Avatar
Oddometer: 803
I have had 3 V-45s and one V-65 and had to "turn" the armatures on all of them and general clean up and install new brushes and they were good to go . Note , after turning them (clean up the armature face ) . Make sure to clean between the sections well , carbon will fill in between along with brass . No worries , easy .
Save yourself $5 us my SmugMug coupon b87YWgTeSWxEc
Couple volcanos , stonehenge and some peg scraping
http://www.advrider.com/forums/showthread.php?t=620436
Old Man plays with his Wee
http://www.advrider.com/forums/showthread.php?t=608068
Gramp-Z is offline   Reply With Quote
Old 09-06-2011, 12:02 PM   #6
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Good auto electric shops still rebuild starters, generators and alternators. If you don't have brushes and a lathe handy maybe just drop it off at a shop and see what they can do.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Times are GMT -7.   It's 04:55 AM.
