Old 04-15-2012, 08:14 PM   #16
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,095
Originally Posted by Fast1 View Post
sweet looking mount..
Can you provide a photo of the mounting plate and associated mounting holes for fitting on another enduro bike?
I would like to know if it will fit my TE630 ..
Also the dimensions or distance apart of the mounting holes and over=all dimension of the entire assembly?
I'll try and get a few pics taken soon and posted up, would be good to know if it would fit your TE.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: [URL="http://www.advrider.com/forums/showthread.php?t=797608&highlight=hodakaguy"]CLICK HERE[/URL]
[SIZE=2]Adventure Is Out There - NV RR: [URL="http://www.advrider.com/forums/showthread.php?t=587520&highlight=hodakaguy"]CLICK HERE[/URL][/SIZE]
[SIZE=2]Riding Through History - NV RR: [URL="http://www.advrider.com/forums/showthread.php?t=715493&highlight=hodakaguy"]CLICK HERE[/URL][/SIZE]
[SIZE=2]And Then There Were Four - OR RR: [URL="http://www.advrider.com/forums/showthread.php?t=503392&highlight=hodakaguy"]CLICK HERE[/URL][/SIZE]
[SIZE=2]My VW Syncro [SIZE=2]W[/SIZE]esty Build Thread: [URL="http://www.advrider.com/forums/showthread.php?t=802924"]CLICK HERE[/URL][/SIZE]
Hodakaguy is offline   Reply With Quote
Old 04-18-2012, 06:20 AM   #17
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,155
Now that you've gone this far, how about making a model that flips the plate over, a la James Bond or Transporter...
say, if one were to inadvertently pass through a speed camera, photo trap, etc....
perhaps with a small servo so it could be controlled from the handlebar.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHooligan is offline   Reply With Quote
Old 04-18-2012, 06:23 PM   #18
BackCountryCruizer
Gnarled Adventurer
BackCountryCruizer's Avatar
Oddometer: 450
After a long 2 day wait my Twist-A-Plate arrived in the mail. After re reading the extremely complete illustrated installation instructions I headed out to the shop. It took me longer to get the necessary tools and drill out than to mount everything. Fantastic idea, well made and complete with everything needed to install. Now all I have to do is remember to twist (the plate) when I get to the end of the pavement. Thanks for a well thought out and well made product! Everyone who rides off road should have one.
[COLOR=DarkOrange]Four wheels move the body
Two wheels move the soul!
[url]http://www.youtube.com/user/650tom[/url]
[/COLOR]
BackCountryCruizer is offline   Reply With Quote
Old 04-18-2012, 09:11 PM   #19
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,095
Here's a photo showing the back side of the Twist-A-Plate along with dimensions. If you have any questions please let me know.
Hodakaguy
Old 04-18-2012, 09:14 PM   #20
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,095
Glad you liked the Twist-A-Plate....Thanks for the comments and feedback.
Hodakaguy
Old 04-19-2012, 08:25 PM   #21
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 421
Mine showed up today. It's on the bike now. First impression was pretty good. It went on in a couple of minutes without needing any directions, although I did later read the directions and they were thorough and well though out. My install was probably a little quicker than most, as I had already drilled out the center hole for my existing plate mount. Will give it a work out tomorrow and will reply with the results.
Shawn
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Old 04-20-2012, 02:46 PM   #22
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Texas requires space for a separate inspection sticker. Looks like there might be room for it above the plate when it is rotated to the horizontal position. Do you think that location would interfere with the rotation to the vertical position? The sticker is 3" wide, 2" high.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 [COLOR="DarkOrange"]KTM[/COLOR] [URL="http://www.cs.trinity.edu/~jhowland/SigPic.jpg"]1190 Adventure R[/URL]
2008 [COLOR="DarkOrange"]KTM[/COLOR] [URL="http://www.cs.trinity.edu/~jhowland/howland-down.jpg"]300 XC[/URL] (plated)
2008 [COLOR="DarkOrange"]KTM[/COLOR] [URL="http://www.cs.trinity.edu/~jhowland/Ouray-690.jpg"]690 Enduro[/URL]
DirtJack is offline   Reply With Quote
Old 04-20-2012, 05:11 PM   #23
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,095
You should have no problem with mounting the sticker between the plates...although it will probably get worn quickly by the plates sliding on each other when you open/close it.
Hodakaguy
Old 04-21-2012, 07:02 AM   #24
hillwalker
hillwalker's Avatar
Oddometer: 34
Hodakaguy
I'm thinking about one of these for my Berg in Texas. Wonder if it might be possible to put the inspection sticker in this spot and then cover it with some sort of clear tape to minimize wear.
hillwalker is offline   Reply With Quote
Old 04-23-2012, 08:42 PM   #25
Romppy
Oddometer: 6
I mounted the Twist-A-Plate up last week and went out and put 100 miles on the bike in a 12 hour race. I was able to crash test it a couple of times in the offroad road position. It held up great
Romppy is offline   Reply With Quote
Old 04-26-2012, 08:59 PM   #26
Lotus54
Ngana
Lotus54's Avatar
Oddometer: 182
I just installed my Twist-a-plate.
It came super quickly after I ordered.
I already had a test unit that I built myself. There were some things I needed to finish up and fine tune. I made it out of aluminum, but was going to do a final in stainless.
But since I knew it was going to take me quite awhile to get time to do mine, I though I'd just buy this one.
My first thought in the pictures was it may not be very sturdy.
After getting it, the unit was way better than I thought. It appears quite sturdy and I think will hold up really well.
The whole thing is really simple but effective- just what I like.
Not heavy, but good material. Also room to put a reflector sticker that will show up when horizontal.
Since it sticks down a bit past the fender, I think it will be darn close to meeting the fender law for the converted bikes in Washington.
I haven't taken it out the woods yet, but I very highly recommend it. And this is from someone that was a bit skeptical at first.
If you ride on and off road, but one of these, you will like it!
(pics to follow).
I can't say enough good things about it!
Mark
OSSA Explorer 2014 AND 1974, Ducati Multistrada 'S' custom-Lotus M100- '68 Benelli dynamo trail- 76 OSSA GPII Phantom (project) 86 XT350
Lotus54 is offline   Reply With Quote
Old 05-13-2012, 10:25 AM   #27
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,310
PM sent for ordering info.
Assfault
* [FONT=Comic Sans MS][SIZE=1]Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*[/SIZE][/FONT]
Assfault is offline   Reply With Quote
Old 05-28-2012, 06:55 PM   #28
Lotus54
Ngana
Lotus54's Avatar
Oddometer: 182
Just an update on the Twist A Plate.
Out on the West end (Donkey Hill) saw me make a mistake on this somewhat challenging hill.
Because of that, I ended up with the bike on its side and a tree between the tyre and Twist A Plate.
It took me a bit to get the bike extracted (the hill is rather steep)---and the Twist A Plate came throught just great!
Still highly recommended
Mrk
Old 06-20-2012, 03:52 PM   #29
Tripndrag
Tripndrag
Tripndrag's Avatar
Oddometer: 76
Ordering
How do I order one of these?
Tripndrag is offline   Reply With Quote
Old 06-21-2012, 06:22 AM   #30
Lotus54
Ngana
Lotus54's Avatar
Oddometer: 182
PM Hodakaguy
Times are GMT -7.   It's 04:52 AM.
