Old 03-15-2005, 09:28 AM   #1
Stobie OP
Mr. Motivated
Stobie's Avatar
Oddometer: 1,863
Question LC4 Suspension: To revalve, or not to revalve?
I'm torn.
There's no doubt that the springs on my 640 Adv are too soft for my 215 or so pounds. I'm sure that changing to stiffer springs and fresh oil would be significant improvement, and there is so much damping adjustment available that revalving simply because the springs are stiffer shouldn't be necessary, especially if I go with heavier than stock oil.
I've never had the suspension on a dirt or dual-sport bike revalved, so I haven't experienced the difference. Some people say it can make the bike more plush and more bottoming-resistant, but I wonder if it's worth the expense and down time for a dualsport bike that's not going to be raced.
Right now, the bike handles bigger hits better than smaller bumps, at least until it bottoms. Most of my riding is dirt roads that can be fast and/or bumpy, or rough, rocky trails. I haven't gotten big air with it, but I imagine it wouldn't be hard to bottom out, since I can practically bottom the front end with the front brake on pavement.
OK, now I'm rambling. Any of you guys have experience with revalved suspension on one of these bikes, versus just changing the springs? Is the extra $300-$400 for the revalving worth it?
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 03-15-2005, 09:37 AM   #2
markjenn
Oddometer: 10,442
I had the forks revalved on my 300EXC which, with stiffer springs, are the same forks as on my LC4. The suspension was improved, but only marginally. I think when you get the spring rates correct, sag set correctly, clickers dialed in, and clean/correct-vis/proper-height fork oil, you're 95% of the way there, especially on a non-MX bike like the LC4.
- Mark
Old 03-15-2005, 10:02 AM   #3
Rocamojo
Toasted on both sides
Rocamojo's Avatar
Oddometer: 59
FWIW, I have resprung my Adventure and it still bottoms chronically in the rear off-road. I had the forks working pretty good and they probably could be further improved with additional testing and adjusting. However, the shock is maxed out on compression and bottoms on everything. The bike has under 2500 miles on it. So since it probably needs a suspension service I am going to have to do the revalve. I'm a bit lighter at 195.
That said, springs may be all you need. It really depends how you are going to ride it. I would suggest respringing and if thats not enough, have it revalved.
Just my 2 cents worth.
Rocamojo is offline   Reply With Quote
Old 03-15-2005, 11:14 AM   #4
Hipster
Hipster's Avatar
Oddometer: 1,810
I replaced just the fork and shock springs, and it made a big improvement for off road riding. However, the rear shock is still a little soft for off road use so, next time it needs to be rebuilt I'm also going to have it revalved.
Hipster is offline   Reply With Quote
Old 03-15-2005, 04:48 PM   #5
Stobie OP
Mr. Motivated
Stobie's Avatar
Oddometer: 1,863
It sounds like the prudent course of action would be to go stepwise; respring first, then revalve as necessary. Maybe that should have been obvious.
Thanks for the insight, fellers.
Stobie
-Albert Einstein
Old 03-15-2005, 05:52 PM   #6
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Revalving the fork and rear shock were the single best improvements made on my 640 Adventure.
Everthing about the bike felt better - cornering, bottoming, whoops, even riding straight down the highways.
IMHO respringing and revalving forks should be the first thing done to any bike - even before pipes and stuff. It makes that much of an improvement.
you would probably be a much smoother and faster rider with good suspension rather than any engine work you could do.
Flanny is offline   Reply With Quote
Old 03-15-2005, 05:57 PM   #7
2whlrcr
gooligan
Oddometer: 6,398
So what fork spring rate did you guys go to? Just curious, since I just got new .46's, but have not put them in yet. I weigh 200 in riding gear.
2whlrcr is offline   Reply With Quote
Old 03-15-2005, 07:15 PM   #8
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
i dunno if there is a suspension whiz around here like the engine gurus - the suspension stuff is part voodoo - might wanna consult a good suspension speciality shop.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-15-2005, 07:45 PM   #9
Flanny
Flanny-it-up!
Flanny's Avatar
Oddometer: 2,738
I'm pretty sure mine were .48s, pregressively wound by Eiback. I weight 170 and add about another 10-15lbs with gear.
Old 03-15-2005, 09:15 PM   #10
Rocamojo
Rocamojo's Avatar
Oddometer: 59
I put in .47s in the forks and a 7.6 in the rear. If I had to do it over, I would go .50 in the forks and at least 8 in the rear. But I'm going to let a suspension shop tell me what I need when I get things revalved. I should have done so in the first place. Flanny had the right idea IMO.
Old 03-16-2005, 04:50 AM   #11
Hipster
Hipster's Avatar
Oddometer: 1,810
I weight 200lbs and went with WP 48 fork springs and a WP 8.0 shock spring per Factory Connection's advice (640 enduro model, w/18L tank). They were very helpfull and they stock WP springs.
Tom
Old 03-17-2005, 10:42 AM   #12
Stobie OP
Mr. Motivated
Stobie's Avatar
Oddometer: 1,863
OK, so it sounds like you heavier guys who just resprung wish you had revalved, too, at least the rear shock. Makes sense, since the factory setting on the compression damping for the rear is one click out from full stiff.
Now, I just need to decide who's gonna do the work.
I've talked to John Curea at MX-Tech East Coast Suspension, and feel really good about his operation. He gets lots of from the KTMtalk and ThumperTalk guys, too.
But, while talking to Gary Emig about other stuff, I learned that Emig Racing does revalving work also. Apparently his son Brian does the suspension work, but they don't list anything about it on the website. I feel pretty good about anything Gary does, and since he rides an LC4-E himself, they've probably got the settings for those suspension components pretty well dialed in.
The fact that they are a little cheaper ($150 per end v. $175) doesn't hurt. Also, he did all the setups on Jeff's bikes before Jeff got a factory ride, and Jeff was pretty successful (but he's prolly fast on a QA50).
I'm good with John Curea, but does anybody know anything about Emig's suspension services?
Flanny, any opinions?
Stobie
-Albert Einstein
Old 08-17-2005, 08:21 AM   #13
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
Bumping this back up to the top - suspension is important
I spent a bit of time riding a few loops of varying terrain around PHX on my new-to-me '03 640 Adv. My '01 adventure was softly sprung and underdamped, but it felt a bit better than the '03 - and I have no idea why. It's clear that the suspension is nowhere near where it should be for handling the Adv's weight, fuel load and a heavy rider (I'm 240lbs geared up).
If I rode prettly slowly, I had a plush ride, but I don't have the self restraint to ride that pace for any length of time.
I rode some technical stuff, rock, sand, etc, and the general consensus was I had to do something about this asap. It was chronically bottoming the fork - it's a bit unsettling to hear the front knob rubbing the fender while in 6" of sand at speed. The fork would actually bottom while braking hard on pavement. The rear was also pretty odd feeling, but it was hard to pin that down since the fork was so poor. In general, I really couldn't wick it up because the suspension action was so poorly damped and sprung for the weight it had to deal with.
I called MXTech and talked to them about it. They've done quite a few LC4's, and since it was fairly closeby, we decided to take the bike there and size it up. So down to MXTech I went. After making a lot of measurements and chatting about riding style and such, it was recommended to me to stick with the (original?) rear spring since the static sag numbers were actually quite good, but the shock valving needed to be changed rather dramatically. I didn't check the # on the spring since we decided it was OK. I am assuming it is the 7.0 OE spring.
Up front, we decided to go with .50 springs and revalve the fork. I declined on the preload adjusting caps on the fork, because quite frankly, for the purposes of what my 640 needs to do, I'll never do it reliably.
Anyway, even if you're a prettly light fella, and you feel the fork spring rate is OK, the fork needs some valving help to really get the max benefit of the WP. The shock, at least on my bike, appears to be fairly well sprung, but poorly damped.
My point is, if you're actually sufficiently dissatisfied with the suspension's action to consider re-springing it, you really ought to consider revalving the shock and fork to really take advantage of what the WP suspension really has to offer. Revalved, resprung and the sag correctly set makes a world of difference, but it ain't cheap. It is, as Flanny says, the best thing you can do with the bike.
Thanks to Flanny's post for making me decide to do it rather than dealing with it as it was.
gaspipe [the original]
Hair of the dog....
gaspipe screwed with this post 08-17-2005 at 08:31 AM
gaspipe is offline   Reply With Quote
Old 08-17-2005, 09:22 AM   #14
cross-country
cross-country's Avatar
Oddometer: 1,658
Great advice, suspension is key to going fast and or safe. If your shock is going to be apart ask for the larger bump stop to be put in, it realy takes the edge off of the hard hit e.g. g-outs, jumps, ect.
cross-country is offline   Reply With Quote
Old 08-17-2005, 01:26 PM   #15
Buckster
Buckster's Avatar
Oddometer: 1,003
I'm 205 and have re sprung, everything is good now.
Buckster is offline   Reply With Quote
Times are GMT -7.   It's 01:50 AM.
