Old 09-05-2011, 09:54 AM   #1
Bloodweiser OP
honestly
Bloodweiser's Avatar
Oddometer: 2,617
stuck brakes
So, yeah. I'm pretty green when it comes to most modern things.
Keep that in mind.
The calipers on my new-to-me RD where frozen.
After a nice long afternoon I got both pistons moving,
and was able to pump them out as far as I could before they bumped each other.
But at this point, even after splitting the caliper in half,
I still can't pull the pistons out completely.
I've read a lot about using air pressure, or pumping grease in there
but the caliper needs to be bolted together for either of these methods to work.
Is there a puller or something to use at this point?
I mean, what's a boy to do?
Related: My rear MC doesn't pump fluid.
I feel air pressure pulses if I cover the end of the banjo with my fingers,
but couldn't get any fluid out the business end.
Is there anything else I should check before I pick up a rebuild kit?
Bloodweiser is offline   Reply With Quote
Old 09-05-2011, 10:01 AM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,902
Split the halves, and use and air tip with your compressor to push out the pistons. Sometimes you can block the Passages using c-clamps and a bit of gasket material oar copper sheet.
I Think with the pistons moving under fluid pressure, they should come out with air. The grease trip is for real lay stuck pistons.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Times are GMT -7.   It's 03:56 PM.
