02-09-2013, 11:25 AM
#46 | |
Don't mean sheeit. .
Oddometer: 2,549
I try to keep in mind the mx idea that you should bottom out your suspension once per lap- on steep downhill bumps offroad, my forks will still get within a couple cms of bottoming out, but most of the time they stay quite a bit higher in the stroke. I can't remember if I mentioned it earlier, but I'm running .56 springs, and I leave my preload all the way in (tight). I should probably make some spacers so that I can have the preload in the middle of the range, but I haven't done that yet.
Zak ktm old bmw others |
02-10-2013, 05:18 AM
#47 |
Oddometer: 1,433
Hi Zak,
Thanks for including this update to your spreadsheet. Looks like your setup favors a firmer ride.
2008 KTM 990 Adv & 2007 KTM 640 Adv |
02-10-2013, 07:02 PM
#48 |
Oddometer: 220
Well the shims on my 2011 990 matches yours.
Zac you're running the stock valves with no modifications correct? The reason I ask is because the Race Tech Gold Valve sure is different. So different in fact that I just ordered the Rebound Valve off of Amazon. Race Tech Rebound Gold Valve Fork Kit FRGV 2302
2013 KTM 690 (Thanks FLHRCI Buyer! ) 2011 990 Adventure Dakar (Thank you Honey!) 2010 Aprilia RSV4 Factory 2010 Ducati 1198S |
02-10-2013, 09:50 PM
#49 | |
Oddometer: 2,549
I talked to Racetech about a gold valve kit for the shock, they said they had one but they wouldn't sell it to me; the only way to get it was to send the shock in and have them R and R it. Hopefully that changes at some point.
02-11-2013, 02:18 AM
#50 | |
Oddometer: 220
02-26-2013, 04:07 PM
#51 |
Oddometer: 220
Hey Zak what did you end up with for float on your midvalve? The restacker software is showing .6 to .8 as the sweet spot.
Oops, just saw the answer on post #48 and it's around .8. Any opinion of it being even lower? Thanks, Tim.
02-26-2013, 05:52 PM
#52 | |
Oddometer: 2,549
My first mods brought the float down to around 1 mm, which I wasn't happy with, my second round brought it to .8. The research I did pointed me towards that also, most other KTMs with this fork come with a float around there. I haven't tried any less float, so I can't comment on that, except to say that in theory, having no float (a clamped midvalve) just doesn't sound right to me: the float on the midvalve really lets you have a bit of relatively plush travel while having plenty of compression damping to keep bigger hits from bottoming the forks. What does the restacker software say about float? And when you say sweet spot, how can you tell what that is? Thanks, Zak
02-27-2013, 02:48 AM
#53 | |
Oddometer: 220
Well it's kind of cool to look at since it computes the damping force of the base valve, mid-valve and the combined system. Since the combined damping force of the base and mid-valve produces three distinct regions with this software I get to see a graph that shows all 3 and the influence of each valve in each region and where the system transitions from one region to the next. So what I'm seeing is that modifying the mid-valve float influences damping in the low speed range and the velocity where the suspension transitions to mid-speed with lower values transitioning earlier. Seems to me that for offroad this would be what you'd want thus (My sweet spot).
04-02-2013, 07:46 AM
#54 |
Oddometer: 107
990 Forks + shock
I just stretched my forks to 'S' specs and revalved with Race Tech valves. I just put 'em back on the bike yesterday. They should be somewhat stiffer, less prone to bottoming and plusher. I'll give a ride report soon. I'm stretching the shock next (obviously) but that's a right PITA and I think over my head due to the need for nitrogen recharge. If anyone has a bead on a good suspension guy on the East coast I'd love to hear about it.
BTW, I had a running email conversation with Jeff Slaven (one of the suspension gurus) and he told me Race Tech stuff is basically crap. He called them the Walmart of bike aftermarket. Thanks Jeff - where were you six weeks ago? Too late now. He said there was little wrong with the stock valves that couldn't be worked around and they were better quality anyway. |
04-02-2013, 09:56 PM
#55 | |
Oddometer: 2,549
04-02-2013, 10:40 PM
#56 |
MotorcycleMayhem
Oddometer: 2,157
From my experience with the RT stuff compared OEM WP stuff, I'd have to say that the WP stuff is pretty decent. There are things that can easily be done to the WP valve bodies to improve them, or at least make me feel better that I have "touched" them..... if it really make a difference I have no real data. I hand lap the valve mating surfaces, hand blend the edges and chuck them in the lathe to re-leave some of the edge restrictions. The "Gold valves" that I have installed into standard orifice forks help make things better, not sure if there is much improvement over OEM WP valve sets.
One of the things that I find rather confusing about what I have seen in my WP suspensions and some RT stuff too, is that the valve bodies have zero transitioning from the sealing surface and the shim.... like a good modern 7 or 9 angle valve cut on a engine cylinder head can make a significant difference in flow performance (and output HP too). Long are the days gone where a "three angle valve job" is the hot setup.... Why not suspension valve bodies too?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
04-02-2013, 11:01 PM
#57 |
Oddometer: 267
I wonder if its because the hydraulic fluid does not compress, but gases like air do.. Liquids usually your fighting cavitation, which is aggravated by surface changes.. Hmm good question..
Dave
Fact: "Beer is a food group" - ME |
