Old 01-30-2012, 07:09 AM   #1531
asheville thumper
asheville thumper's Avatar
Oddometer: 122
Originally Posted by Sutherngintelmen View Post
+1 on this fun.
15/45 made 1st useless and HIGHway revs.
I bought a 40 too but have not yet swapped. Am curious to see if I can get proper chain tension.
Seems like the general consensus is that 15/ 40 or 42 is the way to go and will work with the stock chain just fine. I think I will go with the 40 to keep the revs down just a bit.
2012 Triumph Tiger 1050 SE
2011 KLR650
2010 KTM 690 Enduro R
2010 Triumph Bonneville SE
asheville thumper is offline   Reply With Quote
Old 01-30-2012, 09:04 AM   #1532
Scout_WY
Pirate
Scout_WY's Avatar
Oddometer: 118
Changing Fuel Pump
Getting ready for spring.
In the process of changing out the stock Fuel pump for the NAPA pumps. Are the fuel lines reusable? If so what is the trick to get it separated from the fuel pump? Heat it with heat gun?
Seems to look like they are somewhat fragile. Has anyone replaced them with good clear/transparent hoses? Seems like that might eliminate those connectors on the tank. But may also become brittle. Thoughts?
Scout
'08 690 Enduro
NRA life
Scout_WY is offline   Reply With Quote
Old 01-30-2012, 09:49 AM   #1533
motoged
motoged's Avatar
Oddometer: 908
In the process of changing out the stock Fuel pump for the NAPA pumps.......... Has anyone replaced them with good clear/transparent hoses? .....
Scout
You can replace the fuel lines with regular FI rubber hose/line which is thicker and far less likely to kink....and are rated for the pressure...
My question is : "What Napa pump"???? Did I miss a memo????
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-30-2012, 10:06 AM   #1534
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
i missed that one too Ged
i think he is thinking of the filter from napa
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 01-30-2012, 11:24 AM   #1535
Scout_WY
Pirate
Scout_WY's Avatar
Oddometer: 118
3095
Shit!
You guys are right I thought it was the P/N 3095 from?????
I wrote it down as NAPA but is from someplace in CA. Help a man out, what the vendor?
Hell, probably the filter is a 3095 from NAPA..
I'll look back through the thread to see if I can find it too.
Found it. It's from Cycle works. Glad you guys alerted me. Would have look like an idiot at NAPA.
'08 690 Enduro
NRA life
Old 01-30-2012, 12:54 PM   #1536
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Ryman View Post
Thanks for that link....missed it while I was smoking crack and beating the kids
Doesn't the stock KTM pump have a secondary outlet / inlet for returning fuel....or something like that???
Seems to be a simple plug-and-play. Anybody use / instal one yet?
Ged Schwartz
Kamloops , BC
Old 01-30-2012, 01:01 PM   #1537
andykeck
Oddometer: 108
I had one and it worked fine, but I eventually removed it and sent it to Crankshaft. The stock setup uses this unobtainable thin wall nylon line with a weird metric inside diameter. I had trouble making the commonly available 5/16" Goodrich submersible line stay attached regardless of clamp type. I know others have made the swap without issue, so it could just be me being an idiot.
Knowing what I do now, I wouldn't have bothered with the in-tank filter, which would simplify things a lot. I have the 3095 filter where the quick-disconnect was. No need for the stock filter now.
andykeck is offline   Reply With Quote
Old 01-30-2012, 01:56 PM   #1538
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,741
My thought process for the future design is to eliminate the in-tank pump entirely and go to an external unit of one sort or another. There are a couple of ways to do this but the appeal is the ability to throw a valve, unplug the pump, and swap it out on the trail or in the middle of a rally without too much complexity or loss of fuel.
Seth S
Seth S is offline   Reply With Quote
Old 01-30-2012, 03:46 PM   #1539
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
bingo
need one that stays cool and not too big just 2 small details
Ride the DEZ
76 CB750
Old 01-30-2012, 03:51 PM   #1540
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
The rr front tank setup uses a aluminum spacer at the bottom of the tank to add a fuel line for the front tanks. An inline pump might work quite well.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-30-2012, 04:01 PM   #1541
jonnykilo
Traveller
Oddometer: 205
Originally Posted by RoninMoto View Post
Anyone have a set passenger pegs they dont need? Im starting a rtw trip april 1. I figure a single guy needs the option of picking up a female once in a while.
I also have a bunch of stock parts if anyone is interested. Radiator screen, rad gaurd, skid plate, front and rear sprockets, seat foam and cover, muffler, and a rr twin air kit with 2 filters. Pm offers. I think everyone here probably does the same mods so these parts are probably not needed.
You gonna do a thread here for the RTW, or just the blog in your sig line?
jonnykilo is offline   Reply With Quote
Old 01-30-2012, 10:00 PM   #1542
motoged
motoged's Avatar
Oddometer: 908
Saw this on Page One of this new thread.
Was wondering.....what goop did that guy treat his bumpers with??? I want some for my Safari tank...
Ged Schwartz
Kamloops , BC
Old 01-30-2012, 10:54 PM   #1543
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Yes. I plan on doing a thread. I figure I'll start it when I start.
Old 01-30-2012, 11:38 PM   #1544
Uller
Uller's Avatar
Oddometer: 1,690
Did someone say fuel pump
For fuel pump/filter replacement or just a look at the parts inside the tank.
http://advrider.com/forums/showthrea...ight=fuel+pump
Uller screwed with this post 01-30-2012 at 11:56 PM
Uller is offline   Reply With Quote
Old 01-31-2012, 01:16 AM   #1545
stef
stef's Avatar
Oddometer: 51
Originally Posted by CordR View Post
I've had my 08 E model for a few months now but time for the fun stuff has been limited. 90% of my riding has been city tarmac.
While I was doing the 15 min idle, I went to check on the tank bolts.....which apparently, I should have done a lot sooner.
The left one dropped into my hand when I touched it. The right one doesn't seem like it's in either, but I won't be pulling it out until the new bolts arrive.
There were a bunch of things on my Rally-Raid wish list, so I imagine I'll be placing an order soon. Being in Vancouver, I know I could get just the bolts from KTM Twins sooner, but there's a few other bits that I don't think they have.
I know there were some sold through this site before, but I don't think Mudguts is producing them anymore. I've inquired, but have not heard anything back. If someone has a North America solution, please let me know. Otherwise, I'll go across the pond.
Also, just to confirm with those that have fitted the FMF pipe...
If I'm wrong, let the feedback begin!
Thanks,
Cord
For those who have replaced the upper bolts on the tank, did you have to remove the airbox to enable easier replacement of the new stronger bolts?
stef is offline   Reply With Quote
Times are GMT -7.   It's 04:52 PM.
