Old 09-16-2011, 02:27 AM   #151
Roadcat
The Lordly Keeper Of
Roadcat's Avatar
Oddometer: 8
Originally Posted by giodog2000 View Post
I have 4745km (2948 miles) and my rear pads were to the metal. I forgot to check them so I figure I would have changed them much earlier than that as they scratched the disc a little. On my last ride it was the sound that gave it away lol. Front are almost done also , only a few rides left in them.
I do mostly offroad but no competitions.
Sounds to me like your brake peddle might be suffering from "KTM binding".
Roadcat is offline   Reply With Quote
Old 09-16-2011, 03:39 AM   #152
CHRIS_D
CHRIS_D's Avatar
Oddometer: 632
Lately it seems my bike wants to take a nap on its left side a lot (damn lazy KTMs ). Every time it takes this nap I bend my gear shift . Any suggestions on a more robust shifter or is there a way to protect it better ???
2011 Victory Cross Country
2006 Suzuki DR 650
CHRIS_D is offline   Reply With Quote
Old 09-16-2011, 08:04 AM   #153
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
I thought the US bikes didn't have the limiter? I've hit the rev limiter twice since I've owned the bike and that was the first day I rode it I ride the mid range, I'm not a big fan of wild out of control wheel spin I guess
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-16-2011, 08:13 AM   #154
jorich
jorich's Avatar
Oddometer: 24
It would be interesting to spend a day riding with everyone, just see how differently we use this bike! I though the beautiful thing about the close ratio transmission was that every shift your in the power and don't have to worry about winding the thing out to the rev limiter 'til you go looking for seventh gear, lol
A ship is safe in the harbor, but that's not why ships are built...
'10 KTM 690R:)
jorich is offline   Reply With Quote
Old 09-16-2011, 08:21 AM   #155
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
I felt a difference in the low to mid-range in 2&3 after the "fix". I didn't feel a difference anywhere else. Could be my imagination though. You guys with the Vortex or TuneECU probably wouldn't benefit??
I am at one with my duality.
Barman is offline   Reply With Quote
Old 09-16-2011, 08:22 AM   #156
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
I'm always looking for that 7th gear.
Old 09-16-2011, 08:27 AM   #157
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 324
Originally Posted by Tarheel Wheeler View Post
Here ya go http://sigutech.com/index.php?option...d=28&Itemid=47
Group buy done awhile back. Sounds like everybody is happy with them.
Yup. That cured my problem. I ordered using google translate and corresponded with him via email to figure out the total cost. Great product and a painless process considering the language difference.
Someone did, though, post the part number for a replacement o-ring that would work. I'm afraid that's lost in the big thread implosion.
Jeff
FriedDuck is offline   Reply With Quote
Old 09-16-2011, 08:32 AM   #158
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,806
Also, anyone that has the akra map.
Old 09-16-2011, 08:32 AM   #159
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,806
+1
Old 09-16-2011, 08:36 AM   #160
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,806
Exactly, which is why the 690 is such an awesome motard. But for dual sporting, most people want a nice granny gear for doing steep rocky climbs and a nice overdrive for hiway speeds. Only get that with a wide ratio tranny.
Old 09-16-2011, 11:01 AM   #161
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 313
I use a hammerhead designs shifter http://www.hdmoto.com/ProductDetails...uctCode=KTM1SL (part number ktm1, but there are still a bunch of variations of color/length/etc) and it has held up thus far.
I also use a "brake snake" similar to this:http://www.flickr.com/photos/24373111@N08/2770001380/ that runs down through the shifter's pivot (the hammerhead pivot pin has a hole running vertically through it) and then forward to the skidplate to help keep it from getting bent.
The Letter J is offline   Reply With Quote
Old 09-16-2011, 11:09 AM   #162
The Letter J
Oddometer: 313
The US bikes definately have the limiter, but to be honest, I hit it more on twisty paved backroads than I do in the dirt... the only time I get wheel spin on asphalt is coming out of a corner hot. Wheel spin is usually a problem in the dirt long before the rev limiter. I did hit the rev limiter in 4th on sunday, somewhere in the neighborhood of 85mph and really it takes so long to wind up from higher speeds (wind resistance and what not) that I typically would have shifted MUCH earlier, but I wanted to see if it cut out in the same manner as 2/3... it does, just at a higher rpm.
Old 09-16-2011, 11:23 AM   #163
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,806
I think there's some confusion about the limiter. There's the rev limiter which protects the engine from over revving, when you hit a certain RPM, the engine cuts out, and then there is the 2nd,3rd gear limiter that doesn't allow more then something like 80% throttle when you wick the throttle WFO. It's a more of a nanny thing to prevent looping the bike.
Old 09-16-2011, 11:41 AM   #164
FriedDuck
FriedDuck's Avatar
Oddometer: 324
If you want to test whether there's a limiter you can just unplug the plug that gets modified. Ride it and see for yourself whether it's worth going through with the mod.
Old 09-16-2011, 12:44 PM   #165
Bike Nomad
Bike Nomad's Avatar
Oddometer: 65
I also use a "brake snake" similar to this:http://www.flickr.com/photos/24373111@N08/2770001380/ that runs down through the shifter's pivot (the hammerhead pivot pin has a hole running vertically through it) and then forward to the skidplate to help keep it from getting bent.[/QUOTE]
Was your brake snake a DIY project, or did you purchase it somewhere?
DON'T GET IT TWISTED --ITS DUAL SPORT! NOT DUEL SPORT!
Bike Nomad is offline   Reply With Quote
Times are GMT -7.   It's 04:34 AM.
