10-05-2011, 01:22 PM
#436 | |
Way Offline
Oddometer: 1,162
![]() Wouldn't removing that "ring" entail pulling the forks apart though? If that's the case I'll just live with it.
I am at one with my duality. |
10-05-2011, 01:24 PM
#437 | |
Way Offline
Oddometer: 1,162
I'll slide them up then. Thanks.
10-05-2011, 06:14 PM
#438 | |
Still trying
Oddometer: 654
10-05-2011, 06:27 PM
#439 |
Beef = Packed Vegetables
I had those. Friction worn them. Holes appeared and those neoprene guards transformed themselves in mud KEEPERS.
I removed it. Paul Jr
KTM690r 2011 Gros Buck screwed with this post 10-07-2011 at 06:51 PM Reason: my written english permanently need corrections ... |
10-06-2011, 12:03 AM
#440 | |
Way Offline
Oddometer: 1,162
10-06-2011, 05:32 AM
#441 |
Dirty Old Man
Oddometer: 772
that was my experience
Ride the DEZ 05 FE 550 Husaberg plated 09 KTM 690 |
10-06-2011, 04:24 PM
#442 | |
Oddometer: 1,422
My battery was on it's way out. Replaced my battery, and bike has started instantly every time. PS: the aftermarket battery company's catalogue had the wrong serial number listed for all three 690 models, leading to the dealer giving me the wrong battery (it was too tall by about 10mm). So if you're getting a new battery, it may be worth taking your old one in and comparing it to the one they give you. I found out the hard way...
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community |
10-07-2011, 11:47 AM
#443 |
Way Offline
Oddometer: 1,162
CA Cycleworks Pump
What's in the box.
Pump Filter Hose Clamp Sticker And a candy bar.... how thoughtful. ![]() Shipped quick too. ![]()
10-07-2011, 01:00 PM
#444 |
TrackBum
Oddometer: 463
Got one in the bike and one as a spare. Could not use the filter but did use the little metal retainer piece that comes with the filter to secure the old KTM filter on the end of the new pump. BTW I got an almond joy...
2009 KTM 690r Enduro in da house 2002 RC51 SOLD 2010 KTM 990 Supermoto R |
10-08-2011, 09:15 AM
#445 |
Oddometer: 7
I got a Coconut thing bar, but it was melted
You can find filters here: KTM 690 SM Duke SMC fuel filter OEM Mahle KL 15 |
10-09-2011, 08:27 AM
#446 | |
Rookie
Oddometer: 265
I ordered a standard oem seat to get ready for the race last weekend. It was a rocky and bumpy 3.5 hours race. Although the result was good, I was really tired and had to sit down in some sections I usually stand up. Guess what! The new seat cracked EXACTLY in the same places as the first one. Either my butt is kind of misshaped or these seats have some serious design flaws. Ayway, gotta do some repairs if possible or order a third seat, but this I'm gonna reinforce it before I use it. Has anybody put some extra fibreglass / carbon etc to their seat pan's ? If so, any pictures? |
10-09-2011, 09:35 AM
#447 |
Oddometer: 215
What controls the idle speed on a 690R ?
My 09 Idles at aprox. 1700 RPM as per spec. It has been checked by a KTM shop and I have verified with the Tune Ecu program that the throttle settings are all correct.If the throttle is turned off at say 4,000 RPM, the engine speed drops to around 2200 RPM ( a guess since I have no tach) in a normal fashion, then it just kind of hangs there and then slowly ramps down to the correct idle. This will happen on both maps. The butterfly valve operates smoothly with no binding. If I understand the system, the cable shuts the throttle off to a point and then the ecu is responsable for the last little bit of closure. With close to 11,000 miles on the bike it runs great,does not stall or flame out. So how does a fellow tell the ecu to drop the idle faster? I don't want a lower idle I just want it to happen faster. |
10-09-2011, 12:54 PM
#448 | |
dual sport guy
Oddometer: 86
I recently just bought a low mileage stock SMC and whenever you blip the throttle, it will hang at around 3500rpm for two or three seconds or so until it drops back down to a normal idle. Obviously, it makes riding the bike somewhat of a challenge because whenever you let off the throttle, the bike keeps going for a few seconds until the rpm's drop down and you get deceleration. It also has some jurkiness between around 4rpm's where it sometimes acts like it's running out of gas, but then all of a sudden picks back up again and pulls strong all the way to the top. I have done all the reset procedures, but they haven't had any effect. My belief is that it is running really lean and or needs the TPS reset. Check out this thread that I came upon this morning that has some helpful info regarding voltages and the TPS : http://www.supermotojunkie.com/showt...eECU&highlight= I'm actually taking the bike tomorrow, Monday, to a dyno to have it all custom remapped and tuned which I'm hoping will resolve most if not all of the jerkiness and most importantly, the hanging idle issue. I'll keep you posted on the results tomorrow. I know most ride the Enduro model here, but here's a pic anyway...
10-09-2011, 07:52 PM
#449 | |
Formerly AKA Boejangles
Oddometer: 4,694
I'm working on building a seat pan for this bike that will Polypropylene which would allow it to flex. |
10-09-2011, 09:06 PM
#450 | |
Meanwhile, enjoy this picture of my armor rim strip after only 3000 miles. Never had this problem with my prior 690. May not be obvious on the picture, but except for 3 or 4 rays, its punctured everywhere. Sometimes 3/8" in diameter. Paul Jr 8
KTM690r 2011 Gros Buck screwed with this post 10-09-2011 at 09:32 PM |
