Old 08-06-2012, 06:30 PM   #4921
advrider58
advrider58's Avatar
Oddometer: 47
Where to get an Air Box Temperature Sensor Connector
Once again (third time!) the wires on the connector have broken.
While I've added shrink wrap and cable ties to be sure the stress on the wire leading into the connector is minimum, I continue to break the wire regularly. It appears to be from vibration fatigue. I really could use a new connector to repair this again. Anyone know of a good source (other than a visit to the 100 mile away KTM dealer)?
John
13 Triumph 800xc, 13 Triumph Street Triple R, 08 KTM 690 Enduro, 05 Suzuki DR650 Supermoto, 00 BMW R1150GS
Gone but not forgotten ... 2004 Kawasaki KLR 650, 1998 Honda VTR1000F, 1998 Honda XR400, 1990 Honda CBR1000F, 1979 Suzuki GS750EN, 1971 BSA 650 Lightening, 1972 Honda XL350, 1971 Honda CL100
advrider58 is offline   Reply With Quote
Old 08-06-2012, 06:40 PM   #4922
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,037
I have had good experience with this company for Bosch fuel injection plugs.. not sure if they have that one or not... Here is a link.
http://www.bmotorsports.com/shop/index.php/cPath/109
If you look on the left there is a list of various plugs/connectors.
_________________________
2006 BMW R1200GS
2010 KTM 690 ENDURO R
1969 BSA STARFIRE
wswartzwel is offline   Reply With Quote
Old 08-06-2012, 07:09 PM   #4923
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
I spliced in wire to lengthen the cable so it stopped the stress at the plug. After having it break or the sensor screw up 5 times in the first 15K miles haven't had an issue in 11K miles since I did the splice job.
Old 08-06-2012, 07:20 PM   #4924
advrider58
advrider58's Avatar
Oddometer: 47
Good stuff! The wire on my bike has plenty of slack so is under no "pulling" stress. It hangs straight down from the sensor then over to a cable tie at the frame.
Did you splice in the wire for extra length or as a larger gauge wire to resist a break?
Mine keeps breaking right at the connector, which is making it very difficult to reuse it.
John
Old 08-06-2012, 07:43 PM   #4925
690Emaf10
Oddometer: 68
Originally Posted by wswartzwel View Post
Why does everyone start throwing parts (like replacing fuel pumps) as soon as they have any problem. Whatever happened to doing diagnostics, like checking fuel pressure, ohmning the primary coils, source coils... reading fault codes, checking kick stand switches... etc... to determine what the problem actually is, before buying parts??? Seems like anytime someone's 690 has a hiccup they put a new fuel pump in it.
I definitely understand you point. If my pump was priming consistently it would point to something else. When I turn the key on, I heard the pump click but it didn't prime. If I'm in a situation where I can check voltages to the pump it would be a good troubleshooting measure. If those readings are consistent then it merits pointing to the pump. If not, the hunt begins. Hopefully next time I can be prepared to check everything rather than on my way home from work unprepared.
Now that I've had my first issue it is prudent to be more prepared for an issue. Actually, I should have been prepared from the get go but water under the bridge.
690Emaf10 is offline   Reply With Quote
Old 08-06-2012, 08:23 PM   #4926
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,037
Regarding the fuel pump not priming....
My post wasn't directed solely at you, but at years of posts where the fuel pump is always to blame... I remember when electronic ign. first came out on motorcycles years ago... everyone was replacing CDI boxes whenever there was a problem...
Being prepared... That is why I carry an extra fuel pump with me on long trips.
2006 BMW R1200GS
1969 BSA STARFIRE
wswartzwel screwed with this post 08-06-2012 at 08:30 PM
Old 08-06-2012, 08:42 PM   #4927
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Longer length, mine had no slack in it and you could see it was always under tension.
Old 08-06-2012, 08:45 PM   #4928
SigPig
SigPig's Avatar
Oddometer: 213
I have just over 5000 kms on my 2010 690 SMC. The only performance mod was a Wings silencer and an Akra remap which was at around 1500 kms. Everything was working perfectly until I rolled 5k. It's only been ridden on the street with an occasional gravel/dirt road. While I may think I ride it hard sometimes I am most likely not pushing this bike anywhere near it's potential. I've been deployed every summer since I purchased it so it's been in storage more than on the road.
My 690's fuel pump was failing intermittently and then stopped working all together. When replaced, the new pump fired up and the bike started. During the initialization cycle the bike died after only two minutes of idling. It will no longer start. There is a clicking noise from under the air box somewhere. The fuel pump still hums every time now where as the old one would not turn on at all so that is no longer the issue. It seems to have come up with a new problem now.
I've been skimming through this thread to find similar issues. Am I correct in assuming that the next thing to check would be the Regulator/Rectifier? Or is there something more simple that I could check next?
2014 Beta Evo 250
2011 KTM 200 XCW
SigPig is offline   Reply With Quote
Old 08-06-2012, 09:19 PM   #4929
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,442
No, check the main relay ...right next to the battery. The rectifier wont cause the bike not to start
Seth S
Seth S is offline   Reply With Quote
Old 08-06-2012, 09:21 PM   #4930
Uller
Uller's Avatar
Oddometer: 1,672
Not the R/R. That should probably be the last place for you to look.
You need the Big three. Air, Fuel & Spark
Check that you are first getting fuel at the fuel injector. Your hose might have come off inside the tank or something simple like that.
If you are getting fuel.
Next, see if you are getting a spark by pulling the spark plug and turning it over.
If both of those are good it becomes harder.
Uller is offline   Reply With Quote
Old 08-06-2012, 09:35 PM   #4931
SigPig
SigPig's Avatar
Oddometer: 213
I will start with those. Thanks guys.
2014 Beta Evo 250
2011 KTM 200 XCW
Old 08-06-2012, 10:05 PM   #4932
DirtJack
DirtJack's Avatar
Oddometer: 1,449
I disassembled the plug and used heavier and longer wire, re-crimping and soldering and then sealed the plug and wires with shrink wrap. No problem since.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 08-06-2012, 10:19 PM   #4933
DirtJack
DirtJack's Avatar
Oddometer: 1,449
No codes, kick stand eliminator. When the pump doesn't prime, there is no fuel pressure. When it primes it starts and runs great. It has never failed to prime after waiting a variable length of time. My problem is so intermittent (sometimes nearly a thousand miles between occurrences) that I have not yet changed the fuel pump. The only part I've replaced was the filter which was quite dirty. A frustrating problem. Mine has always run like gangbusters just before and after. It has occurred in 100+ and high 30's temperatures.
2008 KTM 690 Enduro
Old 08-07-2012, 03:56 AM   #4934
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Headbutted a tree yesterday.. tree won . Parts is parts.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 08-07-2012, 07:50 AM   #4935
Seth S
Seth S's Avatar
Oddometer: 4,442
Been there done that. Trail tech was kind enough to sell me a new light frame for a reasonable price
Seth S
Times are GMT -7.   It's 06:10 AM.
