Old 02-04-2013, 04:10 AM   #7081
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,107
Originally Posted by Chris 690R View Post
5 min idle so temp comes up. LH side about 2/3 way up steams pours out like a kettle!
I noticed the overflow bottle was just about empty which I thought was strange!
Chris
Sounds like the old thremo fan rubbing through again , has your bike been dropped ? On the left side ?
Mudguts is offline   Reply With Quote
Old 02-04-2013, 04:46 AM   #7082
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,743
This one ?
http://www.advrider.com/forums/showthread.php?t=753721
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 02-04-2013, 07:02 AM   #7083
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,474
There is also a bleeder valve on the top left as I recall...make sure that is tight.
Seth S
Seth S is offline   Reply With Quote
Old 02-04-2013, 10:42 AM   #7084
Bubba Bauer
Bubba Bauer's Avatar
Oddometer: 156
Question biggest loser
Sorry for the lame question, and probably it has been already answered somewhere, but I just can`t find the time to shuffle through 600 pages.
So... how much weight can you shed off the bike within reason is 5-10kg-s achievable ?
I know it`s not a porker from the get go,it`s more to curiosity than anything else...
Thank you
Bubba Bauer is offline   Reply With Quote
Old 02-04-2013, 10:51 AM   #7085
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
I think you can achieve that by simply replacing the CAT/muffler/Butt Burner with an FMF or other aftermarket muffler.
Doesn't take long to add that weight back on with skidplates, extra fuel tanks and a variety of goodies.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 02-04-2013, 11:24 AM   #7086
Seth S
Seth S's Avatar
Oddometer: 4,474
Thank you
The muffler swap will drop the most weight. After that its difficult to make it much lighter. Consider evaluating your physical condition and determine if you can lose weight off yourself. This is an area most riders forget about and it offers much bigger improvements.
Seth S
Old 02-04-2013, 12:30 PM   #7087
dunefreak
dunefreak's Avatar
Oddometer: 93
Thank you
Yes. Ride it. When the tank is near empty you will have lost about that much weight in fuel. By then you'll have a huge grin on your face that will be much more difficult to get rid of. Shedding bike weight will be the least of your concerns at that point.
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 02-04-2013, 01:06 PM   #7088
Ryman
Oddometer: 768
Are you calling me fat??
Ryman is offline   Reply With Quote
Old 02-04-2013, 01:11 PM   #7089
Mudguts
Mudguts's Avatar
Oddometer: 2,107
Thank you
Yes its easy but exspensive . Full Ti exhaust .Lipo battery .carbon fibre
Heat sheild and heal gaurds. Remove horn indicators any thing you dont need
Vortex cdi as the replaces one of the two ecu's
Old 02-04-2013, 01:20 PM   #7090
Seth S
Seth S's Avatar
Oddometer: 4,474
No not calling you fat...suggesting that you evaluate your condition and determine if you are at a healthy weight or if you stand to lose 20 lbs. I myself am not fat but could stand to get my weight down 10 or 15 lbs.
Seth S
Old 02-04-2013, 05:29 PM   #7091
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 448
over on supermotojunkie, folks shed further weight by replacing the sprockets to the lighter (but softer) aluminum ones.
they also remove the airbox and put a filter on the throttle body.
generally, after the big weight savings already mentioned, people try to save a few ounces here and there, which adds up.
just fyi, i won't do either of those mods. i like the underseat storage though
thorinoakenshield is offline   Reply With Quote
Old 02-04-2013, 09:01 PM   #7092
Woundflatout
Woundflatout's Avatar
Oddometer: 485
A lithium iron battery will shed about 5-6 lbs...then you could go for a Ti shock spring...you'll also lose about 5 lbs of unsprung weight. A very pricey weight loss though. Not sure about your physique but you might just want to lose 10lbs off your body. It may be a lot cheaper! ;)
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 02-05-2013, 04:46 AM   #7093
Honkey Cat
Tailights Fade!
Oddometer: 1,104
Rear brake ??
Put on some new wheels today. I noticed that the rear rotor seemed to have a gap in the brake pad contact area seems little strange. Are you guys greasing the pivot slide bolt also.
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 02-05-2013, 10:19 AM   #7094
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,671
I wouldn't worry about. The pads and disk just wear uneven. Give it a few hundred miles and it will sort itself out. If you are still worried you can change out your brake pads. If the bolt is dry, its not a bad idea to keep it a bit lubed.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 02-05-2013, 10:37 AM   #7095
Honkey Cat
Tailights Fade!
Oddometer: 1,104
brakes
Thanks Ronin
Times are GMT -7.   It's 12:03 PM.
