Old 02-08-2013, 02:58 AM   #7096
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,305
I had exactly the same problem and it started about the same time too. It took 2-3 weeks to find the problem under warranty. After replacing a variety of parts, it turned out that at the first oil/filter change, the tech installed an oil filter intended for a 2011 model.
This was last August. There were no service manuals for the 2012 models at the time and the tech was unaware they changed filter designs. No problem since.
Originally Posted by Hoots View Post
Flashing oil light
I have a 2012 690R with about 4,000km on the clock – Arapovic, but standard air filter (Twin Air filter kit from RR currently wending its way across the Pacific ... ).
For the last 1,500km or so I’ve had an intermittently flashing oil light – pressure test OK – happens when slowing down to stop, and at idle – continues at idle unless you give it some revs ...
I suspect that the Akrapovic map is not perfect, allowing the bike to idle lower than it should ...
I was cheered by a post on this thread from a compatriot Aussie re’ new Akrapovic map (circa 12/1/13 [English date format]) – but have just had the bike in at the shop and the map fitted (last three digits I think 423) is apparently the current one – the more recent map (last digits I think 424) is specifically for aftermarket exhaust / air filter / high-end cam – I have the standard cam, and the shop thought this map would not be appropriate ...
I noticed that the map loaded (again, last three digits 423) specified an aftermarket air filter – this should arrive from RR next week, and I have small hopes that it will resolve the problem ...
That notwithstanding, have any others had this problem?
If so, any ideas?
The bike is still under warranty ...
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-08-2013, 05:52 AM   #7097
daniel5600
daniel5600's Avatar
Oddometer: 30
Hoots,
I have the Leo Vince with standard air filter.
The dealer loaded an Akra map originally, but the bike ran shitty, idle was really low, it'd stall often and sometimes just searched for a good idle speed.
I took it back to them and they loaded another, no idea what it is, they just said its another recommended one. Much better now, idle is smooth and noticeably higher, no problems since the new map.
Sorry I dont know what the map is.
daniel5600 is offline   Reply With Quote
Old 02-08-2013, 07:40 AM   #7098
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,173
Originally Posted by MrHix View Post
Nice! Is that a rubbermaid screen?
On another note, can you post a couple of pics of your bike from the side & back with the bags on? Are the cases Pelican 1550s? I have been looking at making that setup.
Thanks,
MrHix
That is indeed a rubbermaid! I was shaking, wet and cold @ Target when I bought it and they just gave it to me..
Sorry I can't get any pics of the cases right now as the bikes out of the country (or I am depending on your perspective). They are 1550's with the KTM hardparts rack. Quick thoughts on the set up:
Waterproof and tough
Fairly easy to access the box on the side OPPOSITE the kickstand, but if I did it over I'd have a top loader on the kickstand side.
I can pick the bike off the ground with the pelican handles so pretty impressed there.
Off road they often smash my foot; even worse they encourage bad riding habits to keep from smashing foot again; at the same time they do protect the bike in a fall (and maybe your leg too).
I put reflectors on the bike and it probably makes the back of the bike 3X as visible to approaching traffic.
rickypanecatyl is online now   Reply With Quote
Old 02-08-2013, 08:48 AM   #7099
transplanted
Oddometer: 40
Thanks,
MrHix
Not the 1550's like Ricky's but the 1500
transplanted is offline   Reply With Quote
Old 02-08-2013, 09:06 AM   #7100
MrHix
MrHix's Avatar
Oddometer: 384
Thanks for the input folks.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 02-08-2013, 09:12 AM   #7101
tonykof
Dinosaur Tamer
tonykof's Avatar
Oddometer: 165
Originally Posted by Canadian_Bacon View Post
Hello Everyone,
I recently purchased a 2010 KTM 690 Enduro R and can't reach the ground when I sit on the thing (GREAT fun to ride though). I'm curious about the lowering link that's available for it and what are people's experiences.
http://www.ktmtwins.com/ktm-690-lowering-link
I'm 5'10 with a 31" inseam. I sat on a 2013 model at the bike show (yesterday in fact) and I am on my toes which I'm totally fine with. I know KTM lowered the bike 25mm for the newer models and it seems that my 2010 needs to come down the same (or 1 inch which is basically 25mm).
Anyone have any input or reviews they know of?
Thanks a ton!
I have the lowering link on mine & it works fine...I still need to shorten my kickstand so it will lean over a little more...
BMW R1150GS
KTM 640 Adventure
KTM 525 EXC
KTM 350 XCF
tonykof is online now   Reply With Quote
Old 02-08-2013, 12:34 PM   #7102
Hoots
Hoots's Avatar
Oddometer: 1,650
Originally Posted by daniel5600 View Post
Hoots,
Thanks - sounds familiar - would be great if you were able to find out the map that was loaded - lots of them to chose from ...
Hoots is offline   Reply With Quote
Old 02-08-2013, 01:16 PM   #7103
rickypanecatyl
Oddometer: 1,173
I've no experience with the lowering links but just thought I'd mention I was amazed how much better my '11 does over washboardy type terrain, big hits, stairs etc than the 08 and the whole time I'm riding it I'm thinking it that the difference 1" of travel made in the rear end? I've no idea if lower links would take it back to the 08 harshness or not,...
Old 02-08-2013, 01:30 PM   #7104
Kirkster
Parts Murderer
Oddometer: 296
Suspension
Need to get my boingers all taken care of for my weight and the TAT this summer.
Who are people using today. I was thinking of sending them to KTMworld, any other suggestions out there???
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 02-08-2013, 01:47 PM   #7105
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Talk to Alex at Konflict Motorsports
Sent from ADVmachines.com via Tapatalk
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 02-08-2013, 05:28 PM   #7106
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 340
Alan Stillwell, at Stillwell at Stillwell Performance, boingers to the stars
Bigbugberg is offline   Reply With Quote
Old 02-08-2013, 08:14 PM   #7107
Hoots
Hoots's Avatar
Oddometer: 1,650
Apparently the shop did investigate the oil filter and all OK ...
Old 02-08-2013, 10:14 PM   #7108
Canadian_Bacon
Oddometer: 211
Thx for the heads up. I think I will give the lowering link a go just cause it is so cheap.
Canadian_Bacon is offline   Reply With Quote
Old 02-09-2013, 02:18 AM   #7109
touser
canned fruit
Oddometer: 358
Originally Posted by davidmnz View Post
Did you not have to modify the cover to get it to fit?
15 and 17 works fine. Just flip the adjusters as others have said. FYI 118 links works with 15/50 and 17/50.
Cover didn't need modifying, I couldn't get the it to work by flipping the axel. may be me if others have been able to. I'll give it another go.
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 02-09-2013, 03:51 AM   #7110
fluff34567
fluff34567's Avatar
Oddometer: 1,104
is it possible to add a tacho/rpm gauge to an R model?
fluff34567 is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
