Old 02-14-2013, 01:35 PM   #7216
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,775
Originally Posted by crankshaft View Post
20k miles on the road....
Yeah, ok Mr. Hardcore.
BK.RD.RNR is offline   Reply With Quote
Old 02-14-2013, 01:44 PM   #7217
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Originally Posted by Seth S View Post
There is one way to find out. It sounds like this theory needs to be tested. Please keep riding the bike and let us know if things gets expensive...then we will avoid doing it
From Magura themselves: "No. It should be fine."
Regardless of the tiny amount that can get into the engine, there aren't any abrasive or corrosive properties to mineral oil. We're not talking brake fluid, or other glycol based fluids like hydraulic fluid. Just because it has "mineral" in the name does not mean it has any abrasive properties. It is used in machining and knife sharpening because it is a great lubricant, floating the material being removed away from the working surface.
Originally Posted by BK.RD.RNR View Post
Please do report back with your findings.
Granted I did not change engine oil every time I flushed the clutch system, but the closest bearing to where I suspect it would leak out is the one that failed, and no one else has heard reports of the main bearing failing.
There's also a guy on Supermoto Junkies who had to replace his countershaft because it SNAPPED IN HALF with only 3K on the clock. Stranger things have happened...
We'll see if my main bearings go, but I've got about 5,000 miles on my bike since the fluid started going grey.
Either way, I've ordered an Oberon slave. Seems the LC8 and RC8 folks have had great experiences with their slaves...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 02-14-2013, 01:50 PM   #7218
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,775
I was not commenting so much on a belief that there was an abrasive involved, as a concern for lack of viscocity compared with the fully synthetic Motorex.
Old 02-14-2013, 01:57 PM   #7219
Aaron from Texas
Oddometer: 489
Didn't mean to come off that way.
I suppose it's possible there would be a lack of viscosity compared to the Motorex, but there are SO many of the LC4's, LC8's, and RC8's with failing Magura's, you'd think it would be more wide spread.
If mine is leaking, which I'm near positive it is, it's leaking very, VERY slowly. The bike just doesn't have the clutch action it should, especially how smooth it operates after a bleed. But it's still working. Most people probably wouldn't be able to tell.
How many miles did you put on the bike while the slave was taking a shit?
1987 Honda XL600R
Old 02-14-2013, 02:08 PM   #7220
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,775
I could not say for sure, but once I got to the point where it seemed to need the flush/ bleed done a few times in a few months, the bearing failure snuck up on me in one ride, and the bike and I ended up coming home in a truck.
Old 02-14-2013, 02:09 PM   #7221
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,091
Before I replaced my o-ring I was leaking inside for many months. Never really identified what was going on until the o-ring finally failed outright. I had maybe a thousand miles that way 90% off-road. Since we change oil so often in the RFS it never was an issue.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 02-14-2013, 04:00 PM   #7222
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,643
Hey now... this isn't Django Unchained!
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 02-14-2013, 04:07 PM   #7223
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,732
Well, my slave cylinder failed completely, no slow dying so I didn't get to try that theory out.
Old 02-14-2013, 04:41 PM   #7224
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by dad2bike View Post
Any more pics or are we just gonna internet duel over the merits of each brand. This wasn't an oil question.
Thanks for the pics so far. I like those. Kinda flush yet stick out some. My taillight is LED with intergral turn signals. Every littls bit helps.
billet housing.....
Just say'IN
crankshaft is offline   Reply With Quote
Old 02-14-2013, 04:58 PM   #7225
Baja Dad
Baja Dad's Avatar
Oddometer: 2,027
billet housing.....
VERY NICE !!!
I will have to give paul a call !!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-14-2013, 05:16 PM   #7226
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Baja Dad View Post
VERY NICE !!!
Mike and I have both run them on our 950's and as you know, they survived Baja and many, many miles of trail riding and general abuse. If that doesn't tell you how tough they are, then I don't know what else to tell ya
The Sicass signals would keep popping out of the base and then eventually get ripped off, leaving the wires dangling. I've had a set on my 690 for three years and never even had to give them a second glance.
Just say'IN
Old 02-14-2013, 05:55 PM   #7227
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Same here .. Pop out quite easily.
However, I glued them with a mix of cyano-acrylate and primer ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 02-15-2013, 06:37 AM   #7228
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,961
I was thinking small stem style LED version for Ginger. Front & rear.
I like the ones on the 500 exc.
Bruno T . is offline   Reply With Quote
Old 02-15-2013, 06:48 AM   #7229
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,091
I ended up just getting a mini set of stem turns at Cycle Gear Bike Night yesterday.
I talked my bride of thirty years to go for a ride with me on Valentine's Day and they even fed us.
I'll return to the LED stuff later. I need Ginger to be ready to ride tomorrow.
On another note- It seems my Big Orange is getting jealous of all the attention I've been giving Ginger. I saw my first oil puddle under the 950 last night. It has been relegated to the shed while I use the garage/shop to work on the 690.
No oil drips after the ride. I'm thinking I have something that is being effected by the cold outside temps. Should be easy to find & fix.
Tom
My2Wheels
690 WIKI
Old 02-15-2013, 06:56 AM   #7230
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,961
What do they look like ? I've been holding off on installing my euro tail light cause i haven't been able to solve the turn signal issue without fitting something hideous.
Times are GMT -7.   It's 03:57 AM.
