11-07-2011, 02:05 AM
#766 | |
690er
Oddometer: 132
maurizio '08 LC4 690 E "Orange Duck-R" '08 FLHCTUSE3 "White Anchor" '76 CB 750 F ss "76er" Sold: '03 LC8 ADV s "Big Orange" - '05 EXC 450 F "Orangina" |
11-07-2011, 02:14 AM
#767 |
Hmmmm, dirt!
Oddometer: 892
Yeah, unfortunately that happens.
950 Rally custom - 690 Enduro Ride ON! |
11-07-2011, 02:31 AM
#768 |
Supern00ba
Oddometer: 519
I'm happy that there is an alternative that doesn't require me to reprogramme my ECU. In a lot of countries reprogramming would leave you with no recourse under warrentee. Its tricky to uninstall software if the ECU stops working. The accellerator module is completely removable. I'm fitting a vortex once out of warrentee.
KTM 690 R - "Its just a little crush..." |
11-07-2011, 03:42 AM
#769 |
Hmmmm, dirt!
Oddometer: 892
you lose your warrenty by installing a diffrent pipe and NOT mapping for it...
11-07-2011, 05:49 AM
#770 |
Oddometer: 1,385
11-07-2011, 06:19 AM
#771 | |
Discombobulated
Oddometer: 957
http://www.cjdesignsllc.com/footpeg.html and absolutely love 'em.
11-07-2011, 07:03 AM
#772 | |
Safari Scramble!!!!!
Oddometer: 3,199
there is a law that dictates coverage with warranties. I don't remember why it was created exactly but it had to do with warranty companies dropping coverage for silly things.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
11-07-2011, 07:10 AM
#773 |
Oddometer: 925
In the U.S its the Magnuson-Moss Warranty Act
cheers... jack 04 BMW R1100S 02 KTM 250 Exc Racing SmugMug referral code: jXF8ohDWlTm56
11-07-2011, 08:52 AM
#774 |
Oddometer: 3,199
cool thanks. I seem to remember it has to do with customers doing their own oil changes and the manufacturers trying to void the warranty.
11-07-2011, 09:04 AM
#775 | |
Oddometer: 4,920
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
11-07-2011, 09:16 AM
#776 | |
Way Offline
Oddometer: 1,162
The reality is that it's a pain getting the bike dropped off, dealers in the US are horribly unscrupulous and the work performed is usually pretty shabby. I've never had a bike return from a dealership without something amiss that I needed to rectify.
I am at one with my duality. |
11-07-2011, 09:56 AM
#777 | |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 171
On the ignition, had a similar issue with my WR450. Drove me nuts, but eventually traced it to the ignition switch. Thankfully had a spare handy and swapped it out. Problem solved in my case. Hope Cranks is just as easy
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com blakrj screwed with this post 11-07-2011 at 09:57 AM Reason: Damn ipad |
11-07-2011, 10:45 AM
#778 |
TrackBum
Oddometer: 463
SAS removal
Was doing some work on my newly acquired 990 Supermoto R and had some SAS removal parts left so figured I'd use those parts and finally remove the SAS on my 690r. Not so fast! Blockoff plates for the 990 do not fit the 690 as the 690 has a different shaped plate. I fashioned a crude plate out of aluminum sheet metal and put it between the engine and the OEM SAS cover. Seems to work fine. Also I had these nice pre-made resistors for the 990 that also do not fit the plug for the 690! I tried running the bike without the resistor and got no FI light-probably because I turned off the SAS using tune ecu a long time ago. I was searching the internet for a SAS removal kit for the 690 but could not find one.
2009 KTM 690r Enduro in da house 2002 RC51 SOLD 2010 KTM 990 Supermoto R |
11-07-2011, 01:10 PM
#779 |
Geophiz
Oddometer: 63
Best assortment of Torx nuts and bolts for KTM 690R
I am looking for an assortment of KTM-style Torx headed cap screws (bolts) and nuts, spacers, washers etc. to compliment them. I have asked at some local bolt houses but have yet to see a kit containing a decent assortment with Torx heads.
At a local KTM dealer I recently saw an assortment for the SX and XC which appear to have some common sizes. Are there are any better nut and bolt kits out there (with Torx) for the 690R than this kit? Thanks. gbx2001 screwed with this post 11-07-2011 at 01:20 PM |
11-07-2011, 01:23 PM
#780 |
Oddometer: 587
SAS removal
Hi all Whats the advantages/disadvantages of removing the SAS ? and if there are advantages +1 on a kit and some help with what I need to do any links ? Cheers Louis |
