Old 03-20-2013, 03:10 PM   #7846
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,091
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 03-20-2013, 06:36 PM   #7847
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 812
Bob Hancock
'14 R1200GSW; '14 F800GSA
'10 690 EnduroR; '88 R100RS
JustBob is offline   Reply With Quote
Old 03-20-2013, 06:51 PM   #7848
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 812
Originally Posted by Velociraptor View Post
I don't think going from 3 to 2 will make the bike too lean. Do you know what maps are in the Vortex? With the Vortex no 15 min idle. I went back and forth with Vortex a couple of times to get the right maps in the right order for my bike with the map switch they offer. All good now. I am surprised the stock ECU is still there. There are two of them. If this ECU is still plugged in then it must be the smaller one. I would remove it. These days they put 5 maps for open airbox and 5 maps for closed airbox. I asked them to do an economy map too. Have not tested it yet.
I may have this wrong in saying that I still have the stock ECU. What I have is the Map-Select switch under the seat. I haven't done anything with it, so maybe the ECU (wherever it is) isn't there? The X10 ECU settings in the instructions say it's for the Enduro-Open airbox, release 4, 28-4-11.Vecu1. It then gives a list of maps. Mine is set at X10 position 1 which says "Power Map1 (Softer initial throttle). Other options are for Traction, torque, power with variIous descriptors. Right now I'd just like to get some better mileage without hurting the motor. Should I dial back the fuel trim settings on all three throttle ranges to 2-2-2? This gives Base minus 7.5%.
Bob Hancock
Old 03-20-2013, 07:00 PM   #7849
Velociraptor
TrackBum
Oddometer: 1,122
Maybe best thing to do is send an e-mail to Richard Muurling at Vortex in Australia with your question and all the details you mentioned here. He may take awhile to reply but he always gives informative answers.
richard@vortexcdi.com
If all the maps are for an open air box then the bike would run rich with the foam air filters.
The last option would be to send the Vortex ECU to Mike Tolle in California to get proper maps for your bike setup. He charged me $100 to do that so not cheap.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 03-20-2013, 07:03 PM   #7850
JustBob
Uh...who me?
JustBob's Avatar
Oddometer: 812
Thumb
Thanks for that. I'll contact Richard first.
Bob Hancock
Old 03-20-2013, 08:27 PM   #7851
bayarearider
Oddometer: 139
Issue with rear break pedal M10 special screw
After noticing a drop in rear brake pressure, when I removed this M10 special screw (KTM#76513057100) it was broken in half and the other half got basically stuck in the round piece ( looks like a nut) that's on the foot rest bracket. I then had it looked by a mechanic and he wasnt able to pull the rest of the broken screw out of it. I looked at the parts list and called KTM and went back and forth and concluded that the round nut like looking piece cannot be ordered separately and the only alternative is to order the entire right side foot rest bracket (KTM#7650303904401S). I have the cleanspeed break pedal if it matters.
Does anyone here offer any feedback on how to solve this. For now I have ordered the entire right side foot rest bracket. Below is the parts diagram from the manual. The part 6 is the special screw, part 4 are the 2 slide bearings and the screw goes into the round looking thing in the footrest bracket (if you follow the dotted line all the way to the footrest bracket).
Below is another view of the footrest bracket labelled as 17.
bayarearider screwed with this post 03-20-2013 at 08:39 PM Reason: added photo
bayarearider is offline   Reply With Quote
Old 03-20-2013, 10:25 PM   #7852
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,021
You do know that the bolt is left hand thread correct?
The Letter J is offline   Reply With Quote
Old 03-21-2013, 05:24 AM   #7853
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 430
Originally Posted by fluff34567 View Post
any positive/negative comments about the cleanspeed brake pedal ?
http://www.cleanspeedeng.com/Brake%20Pedal.htm
cheaper than the RR version and different milling design.
Have it and it's awesome. I've crashed on that side since installing it and it held up beautifully. I'll take this opportunity to remind you of the reverse threaded bolt that holds the lever on.
Jeff
FriedDuck is offline   Reply With Quote
Old 03-21-2013, 05:48 AM   #7854
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 594
I had to find that out the hard way... Broke tools and bolts, and had to redrill and retap the footrest bracket to be able to re-use it.
Another disadvantage of the setup (2008-2009) is that when the rear brake pedal joints get's dirty, it will tighten the bolt, making it very difficult to remove later.
The newer rear brake pedal (I think 2010 and on) uses a different system, still left hand thread but with bushings to prevent this problem.
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos is offline   Reply With Quote
Old 03-21-2013, 08:50 AM   #7855
bayarearider
Oddometer: 139
No I didnt until now, but the problem at the moment is to get the broken screw out of the groove on the foot rest bracket. I will try to post some pics soon.
Old 03-21-2013, 09:07 AM   #7856
It'sNotTheBike
Oddometer: 704
1) If you have not yet done so, use heat to break the bond of the
OEM thread locking compound. 300 degrees F. for 5 minutes should
do nicely. You can use a heat gun or a propane torch or a household
oven, all that matters is to get the thread locking compound molecular
bonds to break free.
2) If you can find some Kroil, use it on the threads of the fastener you want
to remove, after you have applied the heat. There is no penetrating oil
which works as well as Kroil. Ask any old-time aircraft mechanic about
Kroil, it is amazing stuff.
Kroil can be seen here :
http://www.kanolabs.com/
It'sNotTheBike is offline   Reply With Quote
Old 03-21-2013, 09:09 AM   #7857
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,734
Originally Posted by motoged View Post
Originally Posted by JustBob
Well then you've got a light bike...sorta. My GS's are both 475. The Ducati a bit less. All more than a KTM 500 or the 690. So your 425 lb Gixxer is a pig or a fairy, depending. It's all relative....my only point.
Yep....my GS is a Fairy Pig:
But when I get on my 690....it is a Rocket Pig:
And when I get on my 450, it is a nuclear pig:
Just love riding those pigs
All you need is a Harley and you'd have an Old School Pig!
Old 03-21-2013, 09:41 AM   #7858
bayarearider
Oddometer: 139
Thanks for the feedback. Just ordered Kroil. Hopefully this should do it.
Old 03-21-2013, 10:51 AM   #7859
dunefreak
dunefreak's Avatar
Oddometer: 93
I installed a clean speed lever. It's a nice piece of work and is very stout. Nothing bad to say about it and it's cheaper than the RR. I think they're out of AZ. Shipping to me was only like $6.
http://my2wheels.com/forum/showpost....&postcount=148
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 03-21-2013, 10:58 AM   #7860
fluff34567
fluff34567's Avatar
Oddometer: 1,095
Jeff
yep cheers.. i read the destructions
ordered the lever 3 days ago, it arrived at my friends in NY this morning and I should have it in my grubby hands in zurich tomorrow morning....
fluff34567 is offline   Reply With Quote
Times are GMT -7.   It's 09:24 AM.
