Old 03-26-2013, 01:59 PM   #7936
Noyah
poser
Noyah's Avatar
Oddometer: 400
Originally Posted by Xico View Post
Yesterday I went to Hauthaler, the KTM Dealer in Salzburg (Austria), and found a nice tripmaster switch with 2 push buttons for the 690 Duke.
I asked them to install it on my 2011 690 Enduro R, but when they tried, the connector doesn't match. They are the same color, and i think also the same size and also 4 pin. But the connector on the bike and on the switch are both male.
Does anyone know if it's only a matter of finding a female connector for one of the sides, and if it would work that way?
And one more doubt... anyone knows the name of that kind of connectors?
Maby the exc tripmasterswitch is the one you looking for?
54814073000
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 03-26-2013, 05:48 PM   #7937
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
Do you know what the KTM part number for the switch is? If so, can you post it? If you have detailed pictures of the connector I might be able to help with a source for the alternative connector gender
Sent from ADVmachines.com via Tapatalk
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-27-2013, 01:09 AM   #7938
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 256
Yes, 54814073000 is the right one.
But it is useless for rally riding, you cannot adjust it while riding.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 03-27-2013, 03:14 AM   #7939
fluff34567
fluff34567's Avatar
Oddometer: 1,077
Are there any problems with wolfman bags fitting onto touratwat racks? Or do you need to weld loops onto the racks?
sent using my fingers and voodoo magic.
fluff34567 screwed with this post 03-27-2013 at 03:32 AM
fluff34567 is offline   Reply With Quote
Old 03-27-2013, 04:06 AM   #7940
touser
canned fruit
Oddometer: 358
puzzled
Ok, I'll ask at the risk of ridicule. What is a tripmaster switch and what does it do mon?
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 03-27-2013, 05:43 AM   #7941
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
It is a remote mode switch for the speedo unit. It allows for incrementing + and - on trip 2. Used mostly on Enduro or other events that run a rollchart. When I installed mine I noticed it also activated a stopwatch function as well. That is on my 2009 with the small digital instrument panel. Not sure if anything exra works on the big panel with tach.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 03-27-2013, 05:45 AM   #7942
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
The tripmaster switch came to life back when they were selling the 950 and the 640 adventure. The speedometer they came equipped with had an option for a thumb switch that had 3 buttons on it. 1 button for mode, and 2 buttons for incrementing and decrementing one of the trip odometers.
Seth S
Seth S is offline   Reply With Quote
Old 03-27-2013, 07:19 AM   #7943
DirtJack
DirtJack's Avatar
Oddometer: 1,571
Originally Posted by Bumpaman View Post
Hi all. A friend of mine has a 2008 690E and on a ride in Utah last year the bike developed an intermittent problem where after the engine had been shut off it would not start again. We figured it was probably one of the safety switches, either kickstand or clutch. We started at the clutch safety switch and after pulling it apart and cleaning it the bike started right up. Problem solved..maybe not. The bike did this again during the ride and we employed the same fix with good enough results to finish the ride. When my friend got home he had another similiar incident so his mechanic cut the safety switch and jumpered it to remove it from the system and as we know from other posts, this misguided shortcut caused other problems. On the advice of the inmates here, the old switch was spliced back in and the bike is running fine. My friend is certain that Murphy's Law is going to strike again and leave him stranded out in the pickertoolies. With my keen sense of the obvious, I suggested a replacement of the old clutch safety switch with a new one, but I would like to solicit advice from the experience of everyone here if this would be the right fix? The previous owner has told him that the kickstand safety had been removed and replaced with the KTM kit. Is there something else that he should be looking at here also? Thanks for the help.
When the bike doesn't start, do you hear the fuel pump prime sound when turning the key switch to on before pressing the start button? If not, the bike will not start and you likely have fuel pump issues. Mine would always eventually start after waiting an unspecified time period. I eventually fixed the problem (as others have) by replacing the fuel pump. Read: http://www.advrider.com/forums/showthread.php?t=641042
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-27-2013, 07:40 AM   #7944
Seth S
Seth S's Avatar
Oddometer: 4,545
All the clutch safety switch does is to prevent you from starting the bike in gear if the clutch is out. It shouldn't cause the bike to stop running and as long as the clutch lever is pulled in it will start in gear.
The side stand switch will keep the bike from starting and it is worth installing the eliminator.
Otherwise your friend might be having issues with the leads on the coil or is having fuel pump issues.
Seth S
Old 03-27-2013, 02:25 PM   #7945
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 798
steering locks
So it looks like on my 2013 that the stops could be closed in a bit to offer more movement lock to lock? Any negative to doing this?
sdd04 is offline   Reply With Quote
Old 03-27-2013, 02:32 PM   #7946
ramjet
ramjet's Avatar
Oddometer: 2,211
Nope. Close it up. Mind the radiator or any other interference.
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 03-27-2013, 03:05 PM   #7947
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
I took the jam nuts out and bottomed the stop bolts to go in as far as I could. Only thing that touches is my turn signal on the Safari tank.
Tom
My2Wheels
690 WIKI
Old 03-27-2013, 03:15 PM   #7948
lightfighter
where does this go?
Oddometer: 2,277
Just buy the "other racks" Velcro/D rings and your in business...
lightfighter is offline   Reply With Quote
Old 03-27-2013, 04:09 PM   #7949
sdd04
Oddometer: 798
Thanks to both you and Ramjet for the responses-will get that done tomorrow.
Old 03-27-2013, 11:16 PM   #7950
fluff34567
fluff34567's Avatar
Oddometer: 1,077
thanks
Times are GMT -7.   It's 11:55 PM.
