Old 03-29-2013, 06:15 PM   #7966
wiswoodsguy
Kmart shopper
wiswoodsguy's Avatar
Oddometer: 2,059
anybody wanna share how much the stealer charged for the Akro remap ??
Just want to know what to expect
wiswoodsguy is offline   Reply With Quote
Old 03-29-2013, 06:37 PM   #7967
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,961
Mine told me they'd do it for $80, but my bike runs like a scalded ape on fire and gets killer gas milage as it sits, so I passed.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 03-29-2013, 09:09 PM   #7968
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,595
Mine got remapped twice, dealer didn't charge me a penny.
Old 03-29-2013, 10:01 PM   #7969
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,605
$110
anybody wanna share how much the stealer charged for the akro remap ??
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 03-29-2013, 10:40 PM   #7970
wiswoodsguy
Kmart shopper
Oddometer: 2,059
Im assuming that my dealer is gonna charge me at least an hr
Got the Leo switch + exhaust + geared wrong 15/48
Stalls occasionaly even with all the other updates done
Hope remap helps
Old 03-29-2013, 11:16 PM   #7971
Hoots
Hoots's Avatar
Oddometer: 1,462
Is anyone using shorter aftermarket clutch and brake levers?
If so, any recommendations?
Hoots is offline   Reply With Quote
Old 03-30-2013, 07:21 AM   #7972
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
I dropped my bike first day I owned it. Kickstand sunk into grass. The clutch leaver bent at the "break off" notch at about 35 degrees. I then cut the break leaver about 1cm past that notch and it makes a great short lever.
you could do the same pretty easily... minus dropping the bike.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 03-30-2013, 08:24 AM   #7973
Velociraptor
TrackBum
Oddometer: 1,118
I had some aftermarket levers I got from KTM Twins. They were not shorty levers. I liked the feature to easily adjust lever play. I ended up talking them off because they did not fit well inside my Cycra pro-bend bark busters and the levers did not have the bump that enabled starting the bike in gear. I have them on my supermoto now, where being able to start in gear is not as important. Anyway with the pro-bend setup on my 690, breaking a stock lever is much less likely. I have not seen any shorty levers for the 690, but if you found some for the 990 SMR or SMT they might fit the 690, but prob would not be able to start in gear. KTM Twins said they were working on a new design. They were from FP Racing.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 03-30-2013, 09:05 AM   #7974
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
FI flashing the 8's
Wondering if anyone has some input. Took a perfectly running '12, properly mapped for my Uni and Wings and yesterday put on new EVO 2 tanks from RR. Took the time to do a mild spring clean with the airbox off and add dielectric grease to all the electrical connectors.
Tanks on, put things back in place and upon start up, get the flashing 8's FI code, somewhere I translated it to "Grip Position Sensor" - I assume is the same as TPS. It starts, rough idle. Put in gear or if I add throttle will kill the engine.
Now here are a couple things I messed with during the RR tank install:
- Had to ditch the black plastic piece near the steering head on right side but throttle cables pass through there soo without thinking, started to remove the throttle cables by loosening the threads on top, forward of the tb but stopped, realized how silly that was just to get the cables from the shroud and just cut the damn thing to fee the cables.
- the inside lip of the tb looked a bit dirty and I carefully cleaned around inside lip and butterfly face with a rag and tb cleaner.
- A partial canisterectomy was performed when I first purchased the bike but kept the valve on the right side stil plugged in - all vacum caps were installed. I took this off as required to put on the rr tanks and closed the loop with the 22k Ohm resistor. I reversed this back, putting valve back ON the bike and plugged the cable back in this valve but still get error code.
Nothing looks pinched but I ran out of time last night and will have a closer peek Sunday.
Maybe someone has input or thoughts.
modeselector is offline   Reply With Quote
Old 03-30-2013, 09:21 AM   #7975
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 453
coolant
So what coolant are you pimps using?
I need to top off my reservoir a bit. i've dropped my bike too many times...
The manual calls for Motorex G48 Coolant. It's "free of nitrates, amines and phosphates."
Now I may have Motorex stickers on my bike, but I sure don't want to buy this expensive-ass coolant ($15/L).
What's the NAPA, Pep-Boys, etc. equivalent?
Maybe Honda coolant?
EDIT: oh wait, this may be what I need: Prestone Extended Life Coolant : "Free of silicate, phosphate, borate and nitrate"
I remember using this on my sportbike many years ago....
thorinoakenshield screwed with this post 03-30-2013 at 09:31 AM
thorinoakenshield is offline   Reply With Quote
Old 03-30-2013, 10:09 AM   #7976
ABuck99
0.0
ABuck99's Avatar
Oddometer: 598
I was introduced to a new product from Moose Racing yesterday- and I am confident that it will prove to be as good as all the other products they put their name on. I would have no reservation giving it a try when I exchange the coolant in the 450 & 950.
It doesn't appear to be on the Moose website yet, but I checked the distributor website and it shows available April 5 (if you can wait). Any of the thousands of dealers doing business with Parts Unlimited can get it.
Price: .5 Gallon is $19.95 & Premixed 50/50 ready to pour in. Motorex G48 is about $18 a liter
From the spec sheet:
  • High performance water based coolant
  • Optimum heat transfer and cooling ability in the most extreme temps and operating conditions
  • Excellent wetting, lubricity, and fluid contact with the cooling system
  • Biodegradable formula, environmentally safe and "green"
  • Non-hazerdous, non toxic formula
  • Premixed and ready to use, no guesswork
  • Lowers water temperatures as much as 25deg F
  • Lowers Oil temperatures as much as 50deg F
  • MADE IN THE USA
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-30-2013, 11:20 AM   #7977
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,088
I think and stand to be corrected..... because you messed with the cables you messed with the two throttle position sensors (thad, apad) I believe maybe your apad is now not setup with thad... giving apad improper voltages...
shipwrek12001 is online now   Reply With Quote
Old 03-30-2013, 12:32 PM   #7978
modeselector
Common as muck
Oddometer: 624
Thanks shipwreck.
You know, thought the same thing as I tried to return them to where they were...I will have another look but outside the obvious loose cable, how else could I verify they are where they need to be?
Old 03-30-2013, 12:54 PM   #7979
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Evil Invader View Post
What oil do you guys use?
Sorry...
Hey Gio: Try the Michelin t-63. Nice allround tire.
Hey Evil, send me an Email, I have some info for you.....
aarongibson(at)gmavt.net
Just say'IN
crankshaft is offline   Reply With Quote
Old 03-30-2013, 01:02 PM   #7980
Lexey63
AlcoDventurer
Lexey63's Avatar
Oddometer: 46
exhaust bearing has free playing inside the rocker, is it broken, or it normal? odo 5500 ml
http://zovff.ya.ru
Lexey63 is offline   Reply With Quote
Times are GMT -7.   It's 11:34 PM.
