Old 04-10-2013, 07:57 PM   #8191
Biped
NooB Again
Biped's Avatar
Oddometer: 325
Originally Posted by StepOnIt View Post
thanks for your lack of help...should have asked your better half . As long as you are telling me I am screwed vs trying to screw me all is good.
Maybe this will help you feel less screwed.
http://advrider.com/forums/showpost....54&postcount=1
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is online now   Reply With Quote
Old 04-10-2013, 08:12 PM   #8192
DrtSqtr
DrtSqtr's Avatar
Oddometer: 145
zip ty magnetic drain plug
Anyone have a problem installing a Zip Ty Racing magnetic drain plug? Mine seems to want to start but buy the 2nd thread it starts to bind and does not want to go in any further. I removed and installed the original one to make sure i didnt mess up the threads and it screws in just fine.Tried a few times with same result in 2 threads then binds. Any thoughts suggestions? Thanks
DrtSqtr is offline   Reply With Quote
Old 04-10-2013, 08:46 PM   #8193
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,010
thanks
That was the thread I was looking for and couldn't find again.
thanks so much, makes life less screwed, for the bike that is..
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 04-11-2013, 07:01 AM   #8194
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,469
Originally Posted by Gros Buck View Post
Let's assume you installed that 2.15 and tighten the screw ... You have any clue they were doing their job properly ? I mean, they may have not lock the tire at all after all. I ride at 20 PSI and never felt the need to install rim lock ... It was a very different story on my previous Jap bike. I thought of installing two rim locks at one point ...
Paul Jr
Well considering i had to mount the tire myself and I had to fight the bead under the rim lock and I had done it with a Mousse in the tire...I am pretty sure that the rim lock was working. I also had to take the thing apart to remove the rim locks after everyone said not to run them with the Mousse . But it has been a while and its quite possible I in fact have the larger black rim lock in there. I definitely have the blue one on the front.
Seth S
Seth S is online now   Reply With Quote
Old 04-11-2013, 07:03 AM   #8195
Seth S
Seth S's Avatar
Oddometer: 4,469
Paul Jr
Note #2. At 20 psi you shouldn't have any need for a rim lock...the pressure in the tires puts enough force on the bead to secure it in place. I run the rim locks when I have tubes in the tires and am running around 10 to 13 psi front and rear.
Seth S
Old 04-11-2013, 12:36 PM   #8196
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,618
Originally Posted by snohobo View Post
When I originally got this code back in Colombia (10,000 miles ago) - I was running the stock filter. I brought it to the dealer - and they cleared the code and changed my spark plug. He also sold me a higher flow foam filter - which I didn't install until at least 2,000 miles later.
I'm still running the new foam filter - but at one point in my trip one of the inserts ripped out of the top of the airbox. i've been expoying it back on ever since. I suspect it's letting in a little bit more air into the box because the lid doesnt sit as flush as it used to - but it's been like that for thousands of miles.
Have you tried using a couple of zip ties to secure the lid/ snorkel? I did it that way on mine, and it is more confidence inspiring than wondering if the grommets will pull out again while on a ride. Also did it as a backup on my new 2012 so that I dont have to worry about the possibility of it coming undone.
I could try putting on my buddies airbox to see if it changes anything. Or go back to the paper filter.
If you want/ need a new airbox, I have one brand new in the bag that I would be willing to part with.. pm me if interested.
Originally Posted by metaljockey View Post
None of us are exceptionally skilled riders (excepting when I'm drunk, then I'm fcking quick).
BK.RD.RNR is offline   Reply With Quote
Old 04-11-2013, 02:40 PM   #8197
Hoots
Hoots's Avatar
Oddometer: 1,422
This was my concern also ...
I'm intending to drop the rear to about 15, but leave the front reasonably high to protect the rim from rock jarring ...
I'm not going to fit one to the front at this stage ...
I found some 2.5" light-weight billet alloy rim locks, which should be OK ...
Just a short term adjustment - keen to retry the couple of hills that undid me a month or so ago - want to see how much difference lowered tyre pressures actually makes to traction on long steep stretches of loose rock ...
Hoots is offline   Reply With Quote
Old 04-11-2013, 04:46 PM   #8198
motoged
motoged's Avatar
Oddometer: 908
J..
These?
http://www.rockymountainatvmc.com/p/...?term=rim+lock
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 04-11-2013, 05:47 PM   #8199
Hoots
Hoots's Avatar
Oddometer: 1,422
Originally Posted by motoged View Post
No
I've used those on a DR650, and didn't like them - too heavy and not well made.
I've ordered some from Torpedo 7:
http://www.torpedo7.com.au/products/...y-cnc-rim-lock
Old 04-11-2013, 06:03 PM   #8200
Baja Dad
Baja Dad's Avatar
Oddometer: 1,973
I rum rim locks with bibs all the time allways have.
You need too or you will spin the tire.
Yes I know what I am talking about !
I worked for Michelin as a Tire rep at the SCORE races for 5 years.
I have mounted 1000' of Bibs!!!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 04-11-2013, 06:18 PM   #8201
MrHix
MrHix's Avatar
Oddometer: 384
How about running pinned rims instead? Will the beads remain seated on them with the bibs?
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 04-11-2013, 07:48 PM   #8202
invisible monster
invisible monster's Avatar
Oddometer: 484
Any of the US 690 owners on here have a stock taillight/turn signal assembly laying around they want to get rid of? My taillight/brakelight is getting wonky and I figured someone would have one based on how many posts I see about people replacing them with an LED unit. Shoot me a PM if you can help.
And just to keep in time with the recent posts about rim locks. I run one on the rear wheel of my 690. I don't run my tire pressures lower than maybe 18-20 lbs in the rear so I guess I probably don't really need one but I like the insurance against tearing a valve stem.
invisible monster is offline   Reply With Quote
Old 04-11-2013, 08:12 PM   #8203
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
I have an almost new brake light minus signals. Send PM with email and I can shoot you over a photo.
modeselector is offline   Reply With Quote
Old 04-11-2013, 09:32 PM   #8204
Seth S
Seth S's Avatar
Oddometer: 4,469
Ran the rally bibs at the safari rally in 2011a and did not run rim locks. Never spun a tire or had any issues. None of my team mates ran rim locks either. We pulled and relubed them every day.
I do run rim locks with the enduro bibs though as they are much smaller
Seth S
Old 04-11-2013, 10:19 PM   #8205
Baja Dad
Baja Dad's Avatar
Oddometer: 1,973
Cheers,
MrHix
We did run Pins in our CR250 in the 1986 Baja 1000 the Rim came apart and left me standing on the Beach for 5 hours.
Times are GMT -7.   It's 05:19 PM.
