Old 11-08-2011, 11:39 PM   #811
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 170
Originally Posted by olec View Post
Guys,
One of the dealers up here announces now on their website that they have got information from the factory (KTM) NOT TO USE the Shell V-power gas, because it destroys the gas tanks in some way and debris / particles from this is then further on destroying the EFi system. I dunno how much is 'destroys' the EFI system, but the message is clear enough: do NOT use the Shell V-Power gas.
Anyone else heard about this? I don't think they're just BS us and making up something themselves. I believe they have got this information through some internal service bulletin or similar.
I'm calling BS on this. Please send me the link and I'll see if I can get some detail from lab guys. I believe that if this was the case, there would be a dealer bulletin at least.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 11-09-2011, 08:56 AM   #812
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,076
+1 - Like Biped, I use a very high percentage of Shell Gas (nearest station to my home, not brand loyalty) and have 11+K miles with no filter, pump or EFI issues.
I'm calling BS.
HOWEVER... it's not completely impossible that a local station had some kind of contamination problem, which would lead a dealer to believe the basic chemistry of the gas was causing reliability issues.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 11-09-2011, 09:44 AM   #813
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,694
I'm calling BS.
Keep in mind, olec is in Norway. Their Shell gasoline formulation may be very different than ours.
We've been hearing for years that gasolines with a percentage of Ethanol can cause problems. Seems that this is mostly a problem with sitting for weeks at a time. Bottom line, if you generally let your bike sit for more than a few days at a time use a fuel conditioner to deal with the water that the alcohol attracts into the system. Not new information, but not BS either.
MINIMOUNT
Hard Shell Netbook Case & Mounts
R-dubb is offline   Reply With Quote
Old 11-09-2011, 10:20 AM   #814
Noyah
poser
Noyah's Avatar
Oddometer: 258
Nice
KTM 690 Enduro R
--> My Movies <--
Noyah is online now   Reply With Quote
Old 11-09-2011, 10:27 AM   #815
bayarearider
Oddometer: 52
Originally Posted by Velociraptor View Post
Thanks. The lower vent that comes out by the clutch is still hooked up and venting as usual The valve cover stuff is blocked off.
I saved this posting from the old KTM 690 mega thread and here is a way to do this. I have detailed pics as well but I am unable to attach more than 1 at a time.
Plug locations for sas removal/cannisterectomy
There's a few good resources out there for figuring out how to remove the SAS system including the resistors needed to wire into the system to keep the FI light from coming on. The only think i was unclear on was what ports need to be plugged and the size of said plugs since it is rather helpful to know before you dig into the project. The plugs i found in a multi pack at Pep Boys. I had taken the bike apart and measured the needed nipples to plug and non were exact so the multi pack let me choose the appropriate sizes. Also, i couldn't find just 1/2" plugs so i needed to buy these to get them. The plug locations and sizes are below:
3 plugs needed:
Top of Cylinder head (breather): 1/2" ID plug
Bottom of Airbox: 1/2" ID plug
Left side of throttle body: 1/4" ID plug
bayarearider is offline   Reply With Quote
Old 11-09-2011, 10:56 AM   #816
Velociraptor
TrackBum
Oddometer: 461
Thanks for the SAS info!
2009 KTM 690r Enduro in da house
2002 RC51 SOLD
2010 KTM 990 Supermoto R
Velociraptor is offline   Reply With Quote
Old 11-09-2011, 12:20 PM   #817
blakrj
Need to ride
Oddometer: 170
Absolutely on the water issue. Damn ethanol. In the USA, I believe that the EPA mandates a minimum of 10% ethanol in fuel, and there have/are talks of increasing it to 15%. Seem to recall the Scandinavian market had a 5% ethanol content (but may have changed). However, the fact remains that all fuels would most likely have the same/similar content ethanol, so no difference or reason to state that one brand vs. another is a problem. The difference at the pump is the additives in the fuel, and KTM. The only reason I can think of for them telling folks not to use V-Power is down to the octane. KTM specify a RON95, and depending on location V-Power runs up to RON100. i.e. per the exact letter of the Owner's Manual, it is not be 'recommended'
Old 11-09-2011, 01:21 PM   #818
Evil Invader
Evil Invader's Avatar
Oddometer: 593
Talking SAS removal info
This link still works;
http://www.advrider.com/forums/showthread.php?t=708813
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 11-09-2011, 02:15 PM   #819
Velociraptor
TrackBum
Oddometer: 461
Originally Posted by Evil Invader View Post
I found that one. There he totally blocks off the valve cover and runs the crankcase vent to the air box! So we have some that say you need to keep the valve cover vent functioning because it is involved with the crankcase pressure and others who say you can totally block the valve cover vent. I noticed on my 990 supermoto (and on the RC51 I used to have) that the SAS plate is NOT on the valve cover.
2002 RC51 SOLD
Old 11-09-2011, 03:31 PM   #820
Uller
Uller's Avatar
Oddometer: 558
I have mine setup to vent at both the crankcase and valve cover and then into the airbox.
Uller is online now   Reply With Quote
Old 11-09-2011, 03:44 PM   #821
Velociraptor
TrackBum
Oddometer: 461
Best idea so far! Thanks!
BTW are you doing the Griptwisters Baja trip in April 2012? I signed up for it and David McKay said there was another 690 signed up as well as a 990 Adventure.
2002 RC51 SOLD
Old 11-09-2011, 04:06 PM   #822
ramjet
ramjet's Avatar
Oddometer: 1,671
'11 was same as '09/'10. The side bar on that link clearly says 012, which will be coming very soon.
Didn't see that. Partly, truncated off on my browser for some reason. Thanks.
Qui Desiderant Pacem Preparate Bellum
ramjet is offline   Reply With Quote
Old 11-09-2011, 04:14 PM   #823
Uller
Uller's Avatar
Oddometer: 558
If i can get to the comp after work tonight I'll post up the part I made to make it work out cleaner than stock. It is a little hokey however, it works and uses parts that came from the original SAS system.
No, I hadn't heard of it yet. I have done his Oly loop a couple of times... I bet he does a great trip of Baja.
I don't know if my funds would allow a trip like that this upcoming year. (I need a raise)
I have been thinking of getting into racing and a Baja trip would just about take the entire years racing budget.
I owe you a PM. Sorry for the delay.
Old 11-09-2011, 09:28 PM   #824
Roadracer_Al
Oddometer: 1,076
I have an '08 which suffered from stuck-brake-lever syndrome and depleted the rear brake rotor prematurely.
I did several searches and found that DP offers one, and I bought it off Amazon. Despite being listed for the bike, It's not the right size - 220mm instead of 240mm. Looks like the 08 240mm rear rotor is a one-year part. I expect it is the same as the 950/990 rear rotors, although the 990 rotor has an ABS tone ring).
09 and later seem to use the 220. Is this accurate?
I'm wondering if the 09 brake hanger is a bolt-on, and will accept the 08 caliper.
Anyone have data on that?
Old 11-09-2011, 11:06 PM   #825
LukasM
Oddometer: 4,911
I am pretty sure all 690s use the 240mm disc, as do the 950 and 990.
Everthing smaller than 690 (including the old LC4) uses 220mm.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Times are GMT -7.   It's 01:15 PM.
