Old 05-22-2013, 10:29 PM   #8821
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,159
Originally Posted by v8toilet View Post
Chopper evac $800 USD - $2500 USD per hour. Why sling it when you can just toss it in the back of most of the mid-size helicopters out there?
Wow that would be a great deal! Is that a real number? If you and your bike were stuck somewhere a 4 wheel vehicle couldn't get to say somewhere in the Grand Canyon would they really do that? "Drop me at Providence and take the bike on to Munn racing!"
I'd love a number for next time I'm there if anyone's got one.
rickypanecatyl is offline   Reply With Quote
Old 05-23-2013, 06:16 AM   #8822
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,710
Originally Posted by Hoots View Post
MT43 Trials Tyre on 690
I put an MT43 trials tyre (DOT approved) on the 690 as a bit of an experiment ...
At about 400km, it didn't look as though it would get me home from that ride - central knobs flaking, and a general trackside thumbs down ...
At that point I was running a little over 20psi (we had some section on tar, as well as a fair bit of hard gravel), and I think this was a mistake ...
Unlike a knobby, the tyre really needs to be run on all surfaces at about 10psi - this lets the whole breadth of the tyre stay on the ground - not just the central knobs ...
Having taken the plunge and lowered the pressure to about 10psi I noticed a huge improvement in both handling and knob wear - the pics below show it now at about 2,000km - really not bad considering the weight and HP of the 690, and the speeds it travels at ...
And I'd have to say that it gives the best feeling allround of any rear tyre I've tried - traction on rocks is sensational - can be squirmy on the hard gravel, but way more predictable than the D606 I've been running to date ....
Anyway, an interesting result given the generally poor prognosis at about 400km - this tyre should get me to about 3,000km, which is what I'd generally get out of a D606 - at that point I'll try another one, and this time run it from new at 10psi ...
Trials tires give superior traction in all sorts of terrain...with the exception of rocks covered in mud or wet leaves, deep mud...tacky mud, and some river beds can be a real eye opener. They allow you to climb hills with ease where a traditional knobby tire can make it seem impossible.
Seth S
Seth S is offline   Reply With Quote
Old 05-23-2013, 06:47 AM   #8823
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Triple Clamp Offset
Anyone know what the triple clamp offset is on the stock 690e.
What are the R's offsets.
Who's tried aftermarket triples and what offsets have you tried.
While I like the great braking of the stock front system, it's a little much
in the dirt and I'm considering using the rotor and caliper from a 450sx.
This will reduce the unsprung weight by quite a bit.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 05-23-2013, 06:51 AM   #8824
Swap
Swap's Avatar
Oddometer: 29
+1 for the Lynx
and you can put the screen in your bag for the track section
Swap is offline   Reply With Quote
Old 05-23-2013, 06:54 AM   #8825
Swap
Swap's Avatar
Oddometer: 29
Old 05-23-2013, 06:59 AM   #8826
Swap
Swap's Avatar
Oddometer: 29
and have a lot of gruppy !
https://plus.google.com/photos/10131...CLPnnODnk4GxEA
Old 05-23-2013, 07:04 AM   #8827
wsmc831
wsmc831's Avatar
Oddometer: 796
Interesting, thanks for posting your results. I put a 43 on this weekend and am running about 13lbs, nice to know it will last that long. I used a trials on my 530 last year in Baja and worked great but didn't last, though was a cheap shinko.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 05-23-2013, 08:14 AM   #8828
ktmmitch
Oddometer: 692
Max
It depends what year 690 they are,as the later ones(2012 0n) have different clamps.
If you need to reduce braking force,just file lots of slots in the pads for less contact area.
ktmmitch is offline   Reply With Quote
Old 05-23-2013, 09:47 AM   #8829
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,223
Has anyone gone from the RR Evo 1 tanks to the newer Evo 2 tanks?
Are they noticeably thinner? They look fatter at the rear but look like they don't flare out as much in the front.
I am contemplating swapping over but not sure at this point.
My studs that bolt to the side on the frame and hold my tanks are pretty bent from a couple of get offs (damnm bike stalling). Are parts for the Evo1 & Evo 2 available separately?
Wide! Hard to slide forward...
Maxacceleration is offline   Reply With Quote
Old 05-23-2013, 10:57 AM   #8830
Velociraptor
TrackBum
Oddometer: 1,128
I switched. The Evo2 tanks are much narrower and easier to remove. Also the gas is carried lower so once you fill up all tanks you can turn on the taps on the Evo2 tanks.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 05-23-2013, 10:58 AM   #8831
bayarearider
Oddometer: 139
Toggle switches to mount on RR roadbook plate
I just upgraded to the rally kit from RR. My roadbook plate has four 1/2 " mounting holes for auxiliary toggle switches. The 1/2" mount is a common size for automotive toggle switches. But the problem with the switches I found so far is the base is too wide and I cannot fit all 4 at the same time. The 4 mounting holes on the plate are too close to each other I cannot fit more than 2 at the same time. Can anyone here with a rally kit from RR suggest some ideas ?
bayarearider is offline   Reply With Quote
Old 05-23-2013, 11:02 AM   #8832
rickypanecatyl
Oddometer: 1,159
Whose the big guy in bronze standing on the rock?
Old 05-23-2013, 11:30 AM   #8833
Maxacceleration
Awol
Oddometer: 2,223
Thank you Velociraptor. I will order a set up.
Old 05-23-2013, 11:31 AM   #8834
kiffernathan
kiffernathan's Avatar
Oddometer: 140
Are you looking to sell your old ones? I might be interested for the right price...
Chris
2009 F800GS
kiffernathan is offline   Reply With Quote
Old 05-23-2013, 11:35 AM   #8835
kiffernathan
Oddometer: 140
I had a closer look, and seeing as mine is an '09 I'm not sure your tanks would fit anyway. Sorry.
Chris
2009 F800GS
Times are GMT -7.   It's 10:34 AM.
