Old 05-23-2013, 11:54 AM   #8836
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,653
I have a set of the EVO 1 tanks on my 08 that I might sell that would work on your 09.
Seth S
Seth S is offline   Reply With Quote
Old 05-23-2013, 12:10 PM   #8837
poondangle
Slow
poondangle's Avatar
Oddometer: 1,517
Originally Posted by wsmc831 View Post
Interesting, thanks for posting your results. I put a 43 on this weekend and am running about 13lbs, nice to know it will last that long. I used a trials on my 530 last year in Baja and worked great but didn't last, though was a cheap shinko.
Question for the group, I've always been reluctant to drop pressures below 18 pounds or so since the bike didn't come with rim locks. I see a bunch of posts here where people are running these really low pressures. Are the people that are running these low pressures adding rim locks, or am I just misinformed and needlessly paranoid about running pressure that low.
poondangle is offline   Reply With Quote
Old 05-23-2013, 12:31 PM   #8838
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,091
I have always run rim locks on my wheels. We run about 25psi on pavement and then drop to about 15-18 when we get to dirt. I adjust to feel. I wouldn't feel comfortable running low pressures without rim locks.
I also use the stem nut as a jam nut for the cap NOT to lock the stem on the wheel. This way if the tires slips the stem just goes to the side. I don't waste the time putting it back straight. By the time it gets really really over to the side it's time for a new tire.
I'm unable to run rim locks on my 950 due to the huge rim size. No rim locks available. Pavement queen anyway.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 05-23-2013, 12:42 PM   #8839
SKINNY
SKINNY's Avatar
Oddometer: 648
I've run 15 PSI in the rear & 18 in the front for years with no rim locks...
haven't pulled a valve stem out yet...
I've had tubes that glued themselves to the inside of the tire from doing long pavement rides with 15 PSI in 100 + deg. weather
SKINNY screwed with this post 05-23-2013 at 12:48 PM
SKINNY is online now   Reply With Quote
Old 05-23-2013, 01:14 PM   #8840
Hoots
Hoots's Avatar
Oddometer: 1,522
I'd take some air out of it ...
Took a leap of faith to run it at low pressure, but in my case the difference in wear was immediate and enormous ...
Not what we're used to doing, but I think it needs to be run at around 10psi - ie whole profile flat on the ground, without pressure on the central knobs which will otherwise flake and peel off ...
Hoots is offline   Reply With Quote
Old 05-23-2013, 01:16 PM   #8841
goosecreek
a desk prop
Oddometer: 2,495
I just got a clean speed brake and needed the new bolt . I ordered the bolt and a windscreen from KTM World Highland Park in Georgia. That is the best service I have ever recieved from a KTM dealer. Just wanted to give them an at-a-boy.
Shipped it very quick and the price was more than fare.
goosecreek is online now   Reply With Quote
Old 05-23-2013, 01:21 PM   #8842
Hoots
Hoots's Avatar
Oddometer: 1,522
At least one other here has said differently, but I wouldn't run sub-15psi without a rim lock - I also run ultra-heavy-duty tubes front and back - low pressures increase risk of a pinch flat ...
Torpedo 7 make a nice light aluminium rim lock in 2.5".
Costs very little, and only downside is the additional need for good balancing - but you'd be doing this on a 69 anyway ...
Old 05-23-2013, 03:01 PM   #8843
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
Originally Posted by bayarearider View Post
I just upgraded to the rally kit from RR. My roadbook plate has four 1/2 " mounting holes for auxiliary toggle switches. The 1/2" mount is a common size for automotive toggle switches. But the problem with the switches I found so far is the base is too wide and I cannot fit all 4 at the same time. The 4 mounting holes on the plate are too close to each other I cannot fit more than 2 at the same time. Can anyone here with a rally kit from RR suggest some ideas ?
Guess it depends on which plate you got. I fitted some TE (Tyco) switches and I've got all 4 installed. Was these if I remember correctly. Originally was trying to source some from APEM, but couldn't get my hands on any at the time.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj screwed with this post 05-23-2013 at 03:08 PM
blakrj is offline   Reply With Quote
Old 05-23-2013, 03:21 PM   #8844
bayarearider
Oddometer: 139
Well mine is a RB730 roadbook plate with 2 ICOs. But all of their roadbook plates have mounting holes for toggle switches. Thanks for the suggestion though.
bayarearider is offline   Reply With Quote
Old 05-23-2013, 04:01 PM   #8845
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by MAXVERT View Post
Anyone know what the triple clamp offset is on the stock 690e.
What are the R's offsets.
Who's tried aftermarket triples and what offsets have you tried.
While I like the great braking of the stock front system, it's a little much
in the dirt and I'm considering using the rotor and caliper from a 450sx.
This will reduce the unsprung weight by quite a bit.
Max
Max, look at this post. My 2008 690e top triple clamp has the numbers 22 24 (presumably mm). Also, this post may help.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 05-23-2013, 04:04 PM   #8846
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by ktmmitch View Post
It depends what year 690 they are,as the later ones(2012 0n) have different clamps.
If you need to reduce braking force,just file lots of slots in the pads for less contact area.
Correct, 2012 on do not have adjustable offset (I think; haven't seen one apart).
2008 KTM 690 Enduro
Old 05-23-2013, 04:38 PM   #8847
SKINNY
SKINNY's Avatar
Oddometer: 648
I can confirm that there is nothing in the 2012 owners manual about changing the offset on the steering stem.
Haven't had mine apart yet...
Old 05-23-2013, 05:02 PM   #8848
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,212
Three to six months on Rally Raid Evo2 tanks and upper/lower bolts sets from KTMtwins.
Its a RR thing - small production outfit. I was recommended to order in the dead of winter to get RR stuff by riding season.
Merry Christmas
Maxacceleration is offline   Reply With Quote
Old 05-23-2013, 05:21 PM   #8849
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 768
Merry Christmas
Can't you order direct from RR in UK?
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 05-23-2013, 06:18 PM   #8850
Canadian_Bacon
Oddometer: 204
Yikes! I was planning ordering a ton of stuff from them (evo 2 tanks, evo 2 fairing, exhaust, and a few other bits and bobs). Ugh... So looks like I won't have them for this season...
Is it any faster to order straight from the UK?
Merry Christmas
2010 KTM 690 Enduro r (Current)
LOADED 2008 KLR (Sold)
2000 Ducati Monster 750 (Sold)
Canadian_Bacon is offline   Reply With Quote
Times are GMT -7.   It's 12:10 PM.
