Old 05-26-2013, 08:51 AM   #8941
jonnykilo
Traveller
Oddometer: 205
Can someone tell me how many links on a 690 enduro chain-with stock gearing. Cut mine off and threw it out before I thought to check. Trying to install the new one. Thanks in advance
Sent from my iPhone
jonnykilo screwed with this post 05-26-2013 at 09:14 AM
jonnykilo is offline   Reply With Quote
Old 05-26-2013, 09:09 AM   #8942
CoolHands
travelling
CoolHands's Avatar
Oddometer: 36
Originally Posted by NovaMoto View Post
What brand wheels are those? Lovely looking tard BTW!
apparently made by saxess (a german company) for ktm.
http://www.saxess-crossthelimits.com....php?id=90&L=1
CoolHands is offline   Reply With Quote
Old 05-26-2013, 09:24 AM   #8943
ramjet
ramjet's Avatar
Oddometer: 2,171
Cleanspeed brake lever install?
Just got one of these. Anyone know torque spec for the pivot bolt?
And as i recall, it's a lefty thread, right?
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 05-26-2013, 09:31 AM   #8944
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Left hand thread-yes. Torque. I dunno. I don't use a TW for small bolts.
When I did my Cleanspeed, I did take some emery cloth to the bolt so it slid into the bearings easy. Also plenty of grease.
I recall putting some blue loctite on the threads.
Edit- Noted later by others there was a change to right hand thread in the later years.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike screwed with this post 05-26-2013 at 06:01 PM
dad2bike is online now   Reply With Quote
Old 05-26-2013, 09:56 AM   #8945
bayarearider
Oddometer: 135
Originally Posted by Noyah View Post
When you say handlebars do you mean your barkbusters?
Correct. I have the cycra pro bend.
bayarearider is offline   Reply With Quote
Old 05-26-2013, 11:37 AM   #8946
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 187
Careful - depends on the year. 2011 is NOT a left hand thread
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 05-26-2013, 12:02 PM   #8947
ramjet
ramjet's Avatar
Oddometer: 2,171
Oops, forgot about that-2012. And can't get a 10mm socket in the lower bolts and of course a # 40 Torx is the only one didn't have.
Old 05-26-2013, 12:11 PM   #8948
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,584
Originally Posted by bayarearider View Post
The only issue I had was when fitting the roadbook plate. There is an adjustable T-post held by 2 screws. The roadbook plate is mounted to the T-post. See the pic below.
With the T-post in the original position, my handlebars are hitting the roadbook plate. Look at the pic below. You cant tell that the handlebars hit the roadbook plate but they do.
Can you add a spacer between the T-post and the RB plate? Looks like the mounting bolts are plenty long.
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 05-26-2013, 12:54 PM   #8949
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Whoops. Good point.
Tom
My2Wheels
690 WIKI
Old 05-26-2013, 01:22 PM   #8950
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,465
Damn.
After 5200miles with no problems of any significance suddenly I'm getting the backfire and stall issue - three times today, each occasion the bike restarted fine while I was still rolling in traffic (that bang sure scares the locals). Why now after so long with no problems? Looks like I've got a lot of reading to do in the Wunderfest.
MeinMotorrad is offline   Reply With Quote
Old 05-26-2013, 01:47 PM   #8951
jonnykilo
Traveller
Oddometer: 205
Sent from my iPhone
Can anyone please help with this?
Old 05-26-2013, 02:04 PM   #8952
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,125
Sent from my iPhone
118
see page 20
http://www.bickersplc.com/Catalogues...0Catalogue.pdf
KTM 1190 Adventure
OhBoy is online now   Reply With Quote
Old 05-26-2013, 03:39 PM   #8953
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 962
The first thing that I would try is backflushing the injector, mine starting acting up at ~6200 miles and by ~6300 was unrideable, this fixed it:
Originally Posted by The Letter J View Post
Pull the injector out (keeping fuel line and electrical attached) turn the ignition on and press the starter. It should spray an extremely fine mist of fuel in a cone pattern. If it does not do so, or it drips instead of sprays, (assuming you could feel the fuel line pressurize before hitting the starter) completely remove the injector and backflush it. The easiest way to do this (or at least how I have done it as instructed by a KTM mechanic) is to use compressed air. About 90psi through the nozzle will cause the injector to open and blast out any gunk that may have accumulated in the injector, back the way it came from instead of forcing it through the nozzle.
I use a small piece of fuel line (you can fill this short section of fuel line with carb cleaner if you like) attached to the nozzle with a hose clamp and the other end of the hose attached to my blow gun. If you put a paper towel on the inlet side of the injector while doing this it will catch any debris that comes out so you can inspect it. After doing this, reattach the fuel line and electrical and double check for a good spray pattern, if it is still not perfect just repeat the flushing process until all is well.
This has made my bike go from unrideable and unable to idle for more than 15 seconds, to running perfectly normal. All you have to do to access the injector is remove the seat and the airbox, so it is really easy and definitely worth a try.
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Old 05-26-2013, 04:01 PM   #8954
blakrj
Need to ride
Oddometer: 187
I am converting my 690 with RR EVO1 adventure kit to EVO2 rally kit (minus the new headlight kit, as I decided to use the old KTM990 headlight kit). I got the new cockpit support fitted on the bike. The only issue I had was when fitting the roadbook plate. There is an adjustable T-post held by 2 screws. The roadbook plate is mounted to the T-post....
I have a different RB plate, and it required adjusting the stops (yup, even further reduced turning circle, but not when riding) slightly. Also, you are missing the clamps to bole the plate to the horizontal rod. These will raise it a little more. Some further tweaks and adjustments and you should be good to go. Will post some pics of my setup when i get a chance.
Old 05-26-2013, 04:15 PM   #8955
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,203
Letter J's injector flush is a good idea, I started there when your situation was mine. Also check grounds.
You running stock leg burner? I've got Wings and what did eventually fix mine was going to the Euro map, not sure why it didn't show up for three thousand miles after install but remap made it fantastic again.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Times are GMT -7.   It's 07:29 AM.
