Old 05-28-2013, 08:10 AM   #8956
Baja Dad
Baja Dad's Avatar
Oddometer: 1,981
I want to know more about this !!!!
I know RR was testing a new shock 275 mm travel!!!!
will it match up with my 300mm front forks?
How much $$$ How soon can I get one ???
I am going to start working on a 690/450 mod this would be a great thing
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 05-28-2013, 08:20 AM   #8957
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,735
Sure you saw this. Rally version lists 300mm rear travel.
http://www.rally-raidproducts.co.uk/...in-production/
v8toilet is offline   Reply With Quote
Old 05-28-2013, 09:12 AM   #8958
Sobiloff
Sobiloff's Avatar
Oddometer: 11
Last September I ordered rbott's 2" risers and Scotts damper, but then got hit with a bunch of travel for work and no time to ride. Work has eased off a bit, so this past weekend I found the time to install both and go for a short street ride. Wow! When seated I don't really notice a huge difference, but I can finally stand without being hunched over too far and always fighting for balance. I didn't even notice the damper (set at eight turns out, per the manual).
I'm heading up to the Lost Coast this coming weekend to do some motorcycle camping so I should get a better feel for these bits soon, but first impressions are great!
The install was pretty straight-forward, although I did have to search the forum here for how to re-route (rotate, really) the throttle cables. Having the throttle grip rotated 180 is bothering my O/C, but it's time for new grips anyway so I figure I can fix that soon enough. :) I took my time with a Dremel cut-off wheel to trim the plastic shroud around the ignition switch and I think it turned out OK.
The only thing I've noticed is that the pin slot on the damper interferes with the ignition key when the handlebars are locked to the left and I'm trying to remove the key. Not a big deal, and some trimming of the key would eliminate the issue.
KTM 690E riser and stabliizer by sobiloff, on Flickr
Blake Sobiloff
2008 KTM 690 Enduro
Sobiloff is offline   Reply With Quote
Old 05-28-2013, 09:29 AM   #8959
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
I had the same issue when I installed the Scotts post on mine. I did some filing off of some material on the post. It was causing the key unit to cock back at an angle. I think it was where the post was contacting the frame tubes up top. I took off some material on both sides so it was able to lay flat without contact.
You can see the flats I filed into the sides in this pic.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 05-28-2013, 09:30 AM   #8960
sprouty115
sprouty115's Avatar
Oddometer: 1,488
Originally Posted by Sobiloff View Post
Last September I ordered rbott's 2" risers and Scotts damper...When seated I don't really notice a huge difference, but I can finally stand without being hunched over too far and always fighting for balance...
Same problem I have when standing. Can I ask how tall you are?
sprouty115 is offline   Reply With Quote
Old 05-28-2013, 10:20 AM   #8961
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Seeking the knowledge.
I just got done riding the Pamir highway and i'm in Dushanbe now. About 50 times today I am riding and the bike starts to run like shit. It gets really loud, backfires a lot and shows the FI fault. I turn the bike off, turn it back on and it runs great for the next 5 hours or 3 seconds and everywhere in between. I had this problem 1 time in Croatia about 10,000 km ago and not again till yesterday evening.
9x long. "Throttle valve position not plausible"
Its looking like I need to run through the TPS adjustment? I am really hoping I don't need new parts.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 05-28-2013, 10:26 AM   #8962
jorich
jorich's Avatar
Oddometer: 75
Is anybody using this mount?
http://www.scottsonline.com/Stabiliz...o&BI_ID=169137
The Scott's rubber SUB mount. Are there any opinions about it?
A ship is safe in the harbor, but that's not why ships are built...
'10 KTM 690R:)
jorich is offline   Reply With Quote
Old 05-28-2013, 10:57 AM   #8963
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 977
I broke my lower bar clamps in a high speed crash in the desert around thanksgiving, and had been considering a submount to go with my Scott's that had been sitting on my work bench anyway, so I bought the BRP rubber mounted SUB mount. Very clean looking (especially with the Fastway FIT handgaurds that I traded from my other bike) and straight forward install. I won't lie and tell you that I can tell a difference in vibration in my hands, but I can see out of the mirrors on my dual sport much more clearly so the rubber mount had to of reduced vibrations.
To be fair, I never really noticed much vibration in the bars on this bike to begin with. I don't notice the Scott's anymore either but I sure notice when I turn it off, so I may have just got used to it.
If I get on the bike while it is up on the stand, I can push down on one side or the other of the bars and see that they are "flexing" with the rubber mounts. That tells me that they can deflect/absorb shock similar to (but not in quite the same manner as) how Flexx bars do. It does not feel like the same mushy rubber bar mount design that my Honda's had which allowed the bars to twist left to right in relation to the forks. The BRP RMSUB also keeps the stabilizer solid mounted which in theory would improve it's responsiveness.
I looked at it as another small improvement in suspension, kind of like race car builders look for 100 places to loose 1lb vs 1 place to lose 100lbs... very small incremental gains that may go unnoticed alone but add up to a substantial improvement.
...Oh yeah, and I just liked the way it looks!
I can also attest to it's durability. I ate it in the snow going ~40mph earlier this year and I "jogged it out" (I stepped off the bike on the way down and proceeded to jog away while the bike took a nap in some trailside rubble) while laying the bike down on the right side a few months ago. Neither were particularly bad crashes but the bars stayed right were they should have. My buddy's Husky didn't fair quite as well, he took almost identical spills on the same 2 rides and both resulted in us having to unbolt upper and lower bar mounts to realign and then retighten. The time in the snow actually bent one of his through bolts that hold the bar mount to the top triple so he just dealt with it for the rest of the ride and replaced the bolt when he got home. In other words, this rubber mounting works much better than most factory rubber mounted bar setups.
The ONLY thing that I don't like is that I cannot slide my forks up in the clamps very far (11mm including the cap) but that probably isn't an issue in most applications. I 100% recommend this setup!
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is online now   Reply With Quote
Old 05-28-2013, 11:03 AM   #8964
v8toilet
v8toilet's Avatar
Oddometer: 1,735
I'm getting some dust getting past the UNI foam filter installed in my 690 in the same way I suspect it leaks past the paper filter. I greased the sides heavily and will give it one more go.
If after my next ride I still find the fine dust on the sides of the box I'll be looking for a new solution. Is the Rally Raid the way to go to solve this?
Old 05-28-2013, 11:32 AM   #8965
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 798
I suspect the grease will resolve your issue. I keep 2 of the foam filters, the UNI from KTMtwins, and the orange version from hard parts. I swapped them out last week and certainly found dust on the top side of the UNI where the snorkel dumps air into the filter, but the airbox under the filter had no dirt at all. I used a liberal coating of waterproof grease on the lower mating surface of the filter to help seal it.
sdd04 is offline   Reply With Quote
Old 05-28-2013, 11:39 AM   #8966
Kirkster
Parts Murderer
Oddometer: 296
Is this the same problem that Luke had with the bike???
Voltage Regulator??? Page 69 of Luke's 25,000 miles thread...
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 05-28-2013, 11:42 AM   #8967
Kirkster
Parts Murderer
Oddometer: 296
Ok, Has anyone found the part number for a generic Fuel injector for the 690 as I wanted to have one of those for a spare.
It looks like I waited a bit too long to order a spare fuel pump as they are out of stock just about everywhere and my trip starts on 17 ~ 21 June...
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Old 05-28-2013, 11:49 AM   #8968
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
I guess i'll be checking that tomorrow. Thanks man. I knew there was a reason I swapped in a Yami R1 regulator into my bike that was stolen. Fooking pikeys!
Old 05-28-2013, 11:49 AM   #8969
Velociraptor
TrackBum
Oddometer: 1,118
I guess you tried California Cycleworks for their replacement pump for the 690?
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 05-28-2013, 12:23 PM   #8970
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,995
I ordered one from ktm-parts.com and it arrived a week.5 later even though it was on back-order.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Times are GMT -7.   It's 10:55 AM.
