Old 06-18-2013, 02:33 PM   #9346
Biped
NooB Again
Biped's Avatar
Oddometer: 327
Originally Posted by Yellow Pig View Post
My 2013 Speedometer is not working right. Every thing functions properly but the speed and mileage displays. Is there a way to test the speed sensor wire to try and isolate the problem?
I would like to see if it's the display or possibly the cable. Also where is the speed pickup coming from? Is one of the disk brake bolts magnetized? I do not see any other magnet down there.
The 690 wheel pickup is non-magnetic in simple terms. It appears the sensor has three wires, two provide power to a coil in the sensor and one returns a pulse from the coil induced by the passing of the rotor bolt head. Six pulses per revolution. It could be one of the wires is broken.
My interpretation of the wireing diagram would be to check with a meter for voltage on pin 23 and pin 3 to frame ground. One pin should be power to the coil and the other the pluse. You will need to check this by back probing the connector while attached to the cluster and powered on, and the ability to spin the front wheel. Sounds like a three hand job. This is just theory, have not done this myself.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 06-18-2013, 03:08 PM   #9347
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,022
good will
In the spirit of this forum and the great people here If you need an extra cable I have one, but it is off an 08 690E. I can dig it out and send you a pic of it if you want.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 06-18-2013, 04:40 PM   #9348
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
Thanks for the offer. Let me do some more diagnostics using Biped's info first.
Old 06-18-2013, 06:18 PM   #9349
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 325
Anyone put a 150/18 on the back???
Will it fit?
Bigbugberg is offline   Reply With Quote
Old 06-18-2013, 09:42 PM   #9350
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,993
How'd everyone fix the gas boiling issue with the RR evo-2 tanks? I'm going to order some heat tape but if that doesn't solve it is a ceramic coated header the way to go?
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 06-18-2013, 10:19 PM   #9351
TheMuffinMan
Oddometer: 5,993
Also what has anyone tried doing to reduce the vibrations that come through the evo-2 tanks?
Old 06-18-2013, 10:25 PM   #9352
Canadian_Bacon
Oddometer: 194
Holy smokes! Gas boiling issue?! I'm going to be picking these up myself and the gas.... Boils.... ? Ummm... What?
2010 KTM 690 Enduro r (Current)
LOADED 2008 KLR (Sold)
2000 Ducati Monster 750 (Sold)
Canadian_Bacon is offline   Reply With Quote
Old 06-18-2013, 10:40 PM   #9353
Hoots
Hoots's Avatar
Oddometer: 1,452
I haven't seen this ...
Rode some hot days, before the season turned ...
Others ... ?
Hoots is offline   Reply With Quote
Old 06-18-2013, 11:18 PM   #9354
ktmmitch
Oddometer: 627
We have ridden both EVO1 & EVO2 in many hot countries,Morrocco,Tunisia,and Australia,and not experienced any gas boiling issues,can you give an idea of what has happened,and what temperatures etc,as it is not something our customers have informed us about
ktmmitch is online now   Reply With Quote
Old 06-18-2013, 11:27 PM   #9355
Baja Dad
Baja Dad's Avatar
Oddometer: 1,981
What vibes are you talking about???
Maybe you are ridding to slow!!!!!
Turn your right wrist and make that 690 RUN !!!!!!!!
just joking
Never had it happen ,
What pipe are you running????
I ran a FMF and Akra with carbon gaurds
I would just wrap the Head pipe if you Ceramic coat the Head Pipe you will KILL your muffler 5times as fast
But then you could install a Rally Low pipe.
" I do have a custom LOW Rally pipe I will sell you
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 06-19-2013, 12:05 AM   #9356
Hoots
Hoots's Avatar
Oddometer: 1,452
No vibrations at all for me ...
Tanks full or empty ...
Old 06-19-2013, 04:06 AM   #9357
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Originally Posted by MrHix View Post
Hi,
Tried posting this under a new thread, but got no replies.
I am running the Wings silencer with small tip and the stock air filter with desmog. I am going to try a K&N filter. Is the flow of the K&N different enough to require a remap to a more open filter setting? Is there anyone in the STL area that can do a remap?
Thanks,
MrHix
Probably wont, but the K&N does not filter worth a crap.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 06-19-2013, 04:59 AM   #9358
touser
canned fruit
Oddometer: 358
is there a small inline fuel filter on the 690? Not the one in the tank.
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 06-19-2013, 05:13 AM   #9359
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
Mine did not boil, this was preventative:
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 06-19-2013, 06:45 AM   #9360
SKINNY
SKINNY's Avatar
Oddometer: 645
I was concerned that the exhaust pipe would heat up the tank, but I can put my fingers between the pipe & tank and it doesn't radiate enough heat to be a problem...
SKINNY is offline   Reply With Quote
Times are GMT -7.   It's 11:09 AM.
