Old 07-11-2013, 03:30 PM   #9661
Hoots
Hoots's Avatar
Oddometer: 1,589
Originally Posted by Albie View Post
I was thinking the same thing, my XRR's felt way heavier then my 690 even though they were actually lighter. Mainly because the damn things were so top heavy.
The 690 feels heavier to me than the 625 did ...
But I haven't weighed either ...
EDIT: but there are different ways of perceiving weight - the 690 carries itself well and sits really well on the road - it just feels heavy in the shed, or when it has a little nap on a hill ...
Hoots is offline   Reply With Quote
Old 07-11-2013, 03:54 PM   #9662
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by CoolHands View Post
carrying one bag.
In front, or behind? Strangley in front seems to be better for my seating position. Shame about the total lack of fixing hooks / crannies anywhere?
Well, mate.....that depends....
Some like it up front ....while others find it more comfortable with it behind...
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 07-11-2013, 04:15 PM   #9663
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,159
rickypanecatyl is offline   Reply With Quote
Old 07-11-2013, 04:29 PM   #9664
rickypanecatyl
Oddometer: 1,159
If they can bring a 390 E in under 280 lbs I'd be all over it.
Well I'm suppossed to be working on writing up something important now... number of civilian casulties inflicted by the Burmese military in the Kachin province last month BUT I'd rather not think about that now and instead I'll try to tackle this question!
The latest specs I have from KTM's "Orange day poster" put the
690 enduro @ 138.5 KG and the
690 duke @ 149.5 KG
So according to KTM, the 690 enduro is 11 KG lighter than the 690 Duke.
The same sheet has the 390 Duke @ 139 KG & no specs on the 390 enduro.
If the 390 Enduro was 11 KG lighter than Duke that would make the "ready to race" weight 128 KG or 281 lbs by their specs. That's probably dry with no fluids and battery as that is what it would take to get our 690's to 138.5. (Incidently I'm pretty happy with a Shorai battery I picked up a few months ago - that and a lighter pipe could get you down to 280 with oil and some gas!)
That's close to WR250R/KLX250 weight but with a claimed 44 hp and what I'm hoping is that it'll be as reliable as those 2.
Old 07-11-2013, 04:38 PM   #9665
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 850
front fork installation.
My search engine skills are failing me. Picking my forks up tomorrow. On other bikes, I've snugged up the lower triple clamp bolts, then installed the wheel, then torque the lower triple clamp bolts, and finally the upper triple clamp bolts.
That work here?
Thanks.
sdd04 is offline   Reply With Quote
Old 07-11-2013, 05:40 PM   #9666
DirtJack
DirtJack's Avatar
Oddometer: 1,600
That work here?
Thanks.
I usually put the axle in before tightening the triple clamp bolts to insure that both sides are equal distant from the top. Then the procedure you describe works ok. Be sure to not over torque the lower triple clamp bolts (12 NM on my 08 690e). The top are 17NM. The torque values should be embossed on the triple clamps.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-11-2013, 10:40 PM   #9667
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 488
Wiring fused led auxillary lights
I am trying to figure out how to run my auxillary lights so they turn off with the ignition switch. I am afraid with my current setup I will forget one time and kill my battery. Anyone know how to do this? The lights have a hot wire that should be easy enough for setting this up. Just cant figure out if I should try to remove the fusebox and wire it into the back or what?
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 07-11-2013, 10:48 PM   #9668
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 770
There are 2 accessory power outlets behind the headlight mask. ACC1 and ACC2 - one is switched, but I can't remember which, but it easy to try and see.
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 07-11-2013, 11:45 PM   #9669
palmstatecrawler
Oddometer: 488
Thank you!
Old 07-12-2013, 12:27 AM   #9670
Hoots
Hoots's Avatar
Oddometer: 1,589
I think that's my brother ...
Old 07-12-2013, 03:56 AM   #9671
sdd04
Oddometer: 850
Thanks. The book for the 13 calls for the same torque values. Though both upper and lower triple clamp bolts "felt" like they had been torqued the same and to a higher value than that when I removed them. May have been the dry threads.
Old 07-12-2013, 09:24 AM   #9672
motoged
motoged's Avatar
Oddometer: 908
Mounting Tires:
Now that we have solved the issue as to how to mount bags ....
Here is an interesting article as to how the red and yellow dots on a tire correlate with the rim....this is true for bikes as well as cars/trucks:
http://www.bridgestonetrucktires.com...0ask%20doc.pdf
Ged Schwartz
Kamloops , BC
Old 07-12-2013, 09:43 AM   #9673
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Ahhh, so who's the guy behind him?
Old 07-12-2013, 09:44 AM   #9674
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,995
12 nm = 106 in/lbs
17 nm = 150 in/lbs
Work gave me a conversion calculator application on the PC-an uber handy thing to have loaded.
Any other conversions anyone needs?
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 07-12-2013, 10:09 AM   #9675
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,694
Pitching or catching?
CanadianX is offline   Reply With Quote
Times are GMT -7.   It's 12:03 PM.
